[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Thu Oct 8 00:57:18 PDT 2020
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by laopsahl):
I used this patch on another project now and the result was accepted as
good with no errors, when checked by the users who should use the result.
I have done some more checking and as far I can see this patch makes the
method more robust and does not seem to have any big problem side effects.
Maybe this patch could be added to Postgis 3.1 ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:8>
