[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
PostGIS trac at osgeo.org
Fri Oct 9 03:45:57 PDT 2020
  Reporter:  laopsahl  |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  blocker   |  Milestone:  PostGIS 3.1.0
 Component:  topology  |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by strk):
 There's also a TODO comment in code about doing this:
   /* TODO: refactor to first add all nodes (re-snapping edges if
    * needed) and then check all edges for existing already
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:12>
