[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-89-g13f821e
Fri Oct 9 05:57:00 PDT 2020
the project "PostGIS".
       via  13f821e5906e1a2663eb43b410bb6bd1deba88b6 (commit)
      from  15cc1a3f0c54a6dbfdb275881e8db66aa1ca9cae (commit)
revisions in full, below.
commit 13f821e5906e1a2663eb43b410bb6bd1deba88b6
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Oct 9 14:55:37 2020 +0200
    Berrie: Disable protobuf and fix init script
    Berrie doesn't have protobuf-c installed so, for now,
    disable it in the configure script. Once it has the proper
    packages installed this could be re-enabled
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
index 64566b6..d38d85b 100644
--- a/ci/berrie/pg_init_start.sh
+++ b/ci/berrie/pg_init_start.sh
@@ -20,10 +20,10 @@ PGCTL="$PGPATH/bin/pg_ctl"
 # remove cluster if exists
 if [ -d $PGDATA ] ; then
-    if [ -d $PGDATA/postmaster.pid] ; then
+    if [ -d $PGDATA/postmaster.pid ] ; then
     	$PGCTL stop -D $PGDATA -s -m fast
     fi;
     rm -rf $PGDATA
 fi;
@@ -35,4 +35,4 @@ $DAEMON &
 #sleep a bit because sometimes postgres takes a bit to start up
 sleep 20
 echo "ok"
-exit 0
\ No newline at end of file
+exit 0
diff --git a/ci/berrie/postgis_regress.sh b/ci/berrie/postgis_regress.sh
index 7832355..92f3ae4 100644
--- a/ci/berrie/postgis_regress.sh
+++ b/ci/berrie/postgis_regress.sh
@@ -18,7 +18,7 @@ export PGDATA=$PGPATH/data_${PGPORT}
 export PGHOST=localhost
 sh autogen.sh
-./configure --with-pgconfig=${PGPATH}/bin/pg_config
+./configure --with-pgconfig=${PGPATH}/bin/pg_config --without-protobuf
 #make clean
 make
 export err_status=0
@@ -30,4 +30,4 @@ err_status=$?
 fi
-exit $err_status
+exit $err_status
Summary of changes:
 ci/berrie/pg_init_start.sh   | 6 +++---
 ci/berrie/postgis_regress.sh | 4 ++--
 2 files changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
