[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Fri Oct 16 23:29:07 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: fixed | Keywords:
Changes (by laopsahl):
* Attachment "ar5_solution_4758.png" added.
The red is before and the green after the final fix.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758>
