[postgis-tickets] [PostGIS] #4766: GDAL_DATA not found for windows with GDAL 3.0.4
PostGIS trac at osgeo.org
Sat Oct 17 09:14:44 PDT 2020
 Reporter:  robe                   |      Owner:  robe
     Type:  defect                 |     Status:  assigned
 Priority:  high                   |  Milestone:  PostGIS 3.0.3
Component:  build/upgrade/install  |    Version:  3.0.x
 Keywords:  windows                |
 As noted on https://lists.osgeo.org/pipermail/postgis-
 devel/2020-October/028652.html
 PostgreSQL 13 PostGIS 3.0.2 installer (first ot have GDAL 3+ on it) is
 registering a
 POSTGIS="3.0.2 3.0.2" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
 SFCGAL="1.3.8" PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28
 *GDAL_DATA
 not found*" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3
 (Internal)" TOPOLOGY RASTER
 this is with having env variables set.  Need to investigate what triggers
 this error, and remedy or make sure it's working properly on windows.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4766>
