[postgis-tickets] [PostGIS] #4771: Calling st_mlinefromwkb() crashes the server
PostGIS trac at osgeo.org
Sat Oct 17 13:12:50 PDT 2020
 Reporter:  Robins           |      Owner:  pramsey
     Type:  defect           |     Status:  new
 Priority:  medium           |  Milestone:  PostGIS 3.1.0
Component:  postgis          |    Version:  3.0.x
 Keywords:  st_mlinefromwkb  |
 **Brief**
 Calling st_mlinefromwkb() crashes the server.
 **Repro**
 SELECT st_mlinefromwkb('\x'::bytea);
 SELECT st_mlinefromwkb('\x'::bytea,1);
 **SQL Output**
 db=> SELECT version();
 -[ RECORD 1
 version | PostgreSQL 13.0 on x86_64-pc-linux-gnu, compiled by gcc (GCC)
 7.3.1 20180712 (Red Hat 7.3.1-6), 64-bit
 db=> SELECT postgis_full_version();
 -[ RECORD 1
 postgis_full_version | POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="130"
 GEOS="3.8.0-CAPI-1.13.1 " PROJ="Rel. 5.2.0, September 15th, 2018"
 GDAL="GDAL 2.4.4, released 2020/01/08" LIBXML="2.9.1" LIBJSON="0.13.1"
 LIBPROTOBUF="1.3.2" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
 db=> SELECT st_mlinefromwkb('\x'::bytea);
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4771>
