[postgis-tickets] [PostGIS] #4772: Calling functions with '\x'::BYTEA crashes server
trac at osgeo.org
Sat Oct 17 14:50:32 PDT 2020
Reporter: Robins | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS
| 3.1.0
Component: postgis | Version: 3.0.x
Keywords: st_mpointfromwkb geometry |
st_geomcollfromwkb st_geomfromewkb |
st_wkbtosql |
**Brief**
Calling these functions with '\x'::BYTEA crashes the server.
(Note that these functions are in addition to the recent bug reports with
similar '\x'::BYTEA issues)
**Repro**
SELECT st_mpointfromwkb('\x'::BYTEA);
SELECT geometry('\x'::bytea);
SELECT st_geomcollfromwkb('\x'::bytea);
select st_geomfromewkb('\x'::bytea);
SELECT st_wkbtosql('\x');
**SQL Output**
db=> SELECT version();
-[ RECORD 1
version | PostgreSQL 13.0 on x86_64-pc-linux-gnu, compiled by gcc (GCC)
7.3.1 20180712 (Red Hat 7.3.1-6), 64-bit
db=> SELECT postgis_full_version();
-[ RECORD 1
postgis_full_version | POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="130"
GEOS="3.8.0-CAPI-1.13.1 " PROJ="Rel. 5.2.0, September 15th, 2018"
GDAL="GDAL 2.4.4, released 2020/01/08" LIBXML="2.9.1" LIBJSON="0.13.1"
LIBPROTOBUF="1.3.2" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
db=> SELECT st_mpointfromwkb('\x'::BYTEA);
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4772>
