[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Mon Oct 19 03:14:17 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: fixed | Keywords:
Comment (by strk):
Thanks for the sum-up, but I don't think the behavior you're describing
matches the current implementation as snap-to-segment was NOT implemented.
The red node will be added as-is. The result should be having both the red
AND the blue node, effectively having 2 nodes closer-than-tolerance.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:23>
