[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-94-ga7851bb
git at osgeo.org
git at osgeo.org
Fri Oct 23 04:43:00 PDT 2020
the project "PostGIS".
via a7851bb0659a86ed63f183fd8f536aa83942add7 (commit)
from e7ed833b6a7d00f15d338aa2de38b0050a64928d (commit)
revisions in full, below.
commit a7851bb0659a86ed63f183fd8f536aa83942add7
Author: Raúl Marín <git at rmr.ninja>
Date: Sun Oct 18 00:01:33 2020 +0200
Fix segfault when parsing invalid WKB
References #4767 #4768 #4771 #4772
Closes https://github.com/postgis/postgis/pull/584
diff --git a/NEWS b/NEWS
index 49d9d96..9de0012 100644
--- a/NEWS
+++ b/NEWS
@@ -46,6 +46,7 @@ Only tickets not included in 3.1.0alpha2
- #4740, Round values in geography_distance_tree
as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina Obe)
- #4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)
+ - #4767, #4768, #4771, #4772, Fix segfault when parsing invalid WKB (Raúl Marín)
diff --git a/postgis/lwgeom_inout.c b/postgis/lwgeom_inout.c
index 8ce752d..e5e75af 100644
--- a/postgis/lwgeom_inout.c
+++ b/postgis/lwgeom_inout.c
@@ -349,6 +349,8 @@ Datum LWGEOMFromEWKB(PG_FUNCTION_ARGS)
uint8_t *wkb = (uint8_t*)VARDATA(bytea_wkb);
lwgeom = lwgeom_from_wkb(wkb, VARSIZE_ANY_EXHDR(bytea_wkb), LW_PARSER_CHECK_ALL);
+ if (!lwgeom)
+ lwpgerror("Unable to parse WKB");
if ((PG_NARGS() > 1) && (!PG_ARGISNULL(1)))
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index 6da4fe2..9d2f994 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -795,9 +795,8 @@ Datum LWGEOM_from_WKB(PG_FUNCTION_ARGS)
- if ( lwgeom_needs_bbox(lwgeom) )
- lwgeom_add_bbox(lwgeom);
+ if (!lwgeom)
geom = geometry_serialize(lwgeom);
lwgeom_free(lwgeom);
diff --git a/regress/core/wkb.sql b/regress/core/wkb.sql
index 9749db5..2fd59bf 100644
--- a/regress/core/wkb.sql
+++ b/regress/core/wkb.sql
@@ -533,3 +533,13 @@ select g, encode(st_asbinary(g::geometry, 'ndr'), 'hex'),
'TIN ZM EMPTY'
::text as g ) as foo;
+-- Crashes (#4767, #4768, #4771, #4772)
+SELECT st_mpointfromwkb('\x'::BYTEA);
+SELECT geometry('\x'::bytea);
+SELECT st_geomcollfromwkb('\x'::bytea);
+SELECT st_geomfromewkb('\x'::bytea);
+SELECT st_wkbtosql('\x');
+SELECT st_mpolyfromwkb('\x'::BYTEA);
+SELECT st_mlinefromwkb('\x'::bytea);
+SELECT st_mlinefromwkb('\x'::bytea,1);
\ No newline at end of file
diff --git a/regress/core/wkb_expected b/regress/core/wkb_expected
index 91fa0c8..090e646 100644
--- a/regress/core/wkb_expected
+++ b/regress/core/wkb_expected
@@ -99,3 +99,11 @@ TIN EMPTY|011000000000000000|t|000000001000000000
TIN Z EMPTY|01f803000000000000|t|00000003f800000000
TIN M EMPTY|01e007000000000000|t|00000007e000000000
TIN ZM EMPTY|01c80b000000000000|t|0000000bc800000000
+ERROR: Unable to parse WKB
Summary of changes:
NEWS | 1 +
postgis/lwgeom_inout.c | 2 ++
postgis/lwgeom_ogc.c | 5 ++---
regress/core/wkb.sql | 10 ++++++++++
regress/core/wkb_expected | 8 ++++++++
5 files changed, 23 insertions(+), 3 deletions(-)
hooks/post-receive
