[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-5-g279df53
git at osgeo.org
git at osgeo.org
Fri Oct 23 05:55:58 PDT 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
via 279df533083aaa5d8926bbdfb55a5fd43fefa1ea (commit)
from 4c8a7077d62de5eeb068b9aa271c7deab2276297 (commit)
revisions in full, below.
commit 279df533083aaa5d8926bbdfb55a5fd43fefa1ea
Author: Raúl Marín <git at rmr.ninja>
Date: Sun Oct 18 00:39:51 2020 +0200
Fix segfault in st_addband
References #4769
diff --git a/NEWS b/NEWS
index 140a60d..58758a1 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ YYYY/MM/DD
* Bug fixes *
- #4757, Handle line collapse due to snap-to-existing node (Sandro Santilli)
+ - #4769, Fix segfault in st_addband (Raúl Marín)
PostGIS 2.5.5
2020/08/15
diff --git a/raster/rt_pg/rtpg_create.c b/raster/rt_pg/rtpg_create.c
index 7dceed4..a1eeb6b 100644
--- a/raster/rt_pg/rtpg_create.c
+++ b/raster/rt_pg/rtpg_create.c
@@ -383,6 +383,17 @@ Datum RASTER_addBandRasterArray(PG_FUNCTION_ARGS)
POSTGIS_RT_DEBUG(4, "destination raster isn't NULL");
+ if (PG_ARGISNULL(1))
+ if (raster != NULL)
+ rt_raster_destroy(raster);
+ PG_RETURN_POINTER(pgraster);
+ else
+ PG_RETURN_NULL();
/* source rasters' band index, 1-based */
if (!PG_ARGISNULL(2))
srcnband = PG_GETARG_INT32(2);
diff --git a/raster/test/regress/tickets.sql b/raster/test/regress/tickets.sql
index 68c970b..b63d3a6 100644
--- a/raster/test/regress/tickets.sql
+++ b/raster/test/regress/tickets.sql
@@ -142,3 +142,6 @@ INSERT INTO ticket_4547 VALUES (null);
INSERT INTO ticket_4547 SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);
SELECT '#4547.2', AddRasterConstraints('ticket_4547', 'r');
DROP TABLE ticket_4547;
+-- #4769
+SELECT '#4769', st_addband(NULL, NULL::_raster, 1, 1);
\ No newline at end of file
diff --git a/raster/test/regress/tickets_expected b/raster/test/regress/tickets_expected
index d248573..2152be6 100644
--- a/raster/test/regress/tickets_expected
+++ b/raster/test/regress/tickets_expected
@@ -68,3 +68,4 @@ NOTICE: Adding nodata value constraint
NOTICE: Adding out-of-database constraint
NOTICE: Adding maximum extent constraint
#4547.2|t
+#4769|
Summary of changes:
NEWS | 1 +
raster/rt_pg/rtpg_create.c | 11 +++++++++++
raster/test/regress/tickets.sql | 3 +++
raster/test/regress/tickets_expected | 1 +
4 files changed, 16 insertions(+)
hooks/post-receive
