[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-96-g283a8c4
Sat Oct 24 10:18:24 PDT 2020
the project "PostGIS".
       via  283a8c4733bbcfd6fd0e9cae0eb02850dd0acc94 (commit)
      from  23c15ffa5e7e9a9e7783e859c5912cde51bcc592 (commit)
revisions in full, below.
commit 283a8c4733bbcfd6fd0e9cae0eb02850dd0acc94
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Oct 24 13:18:07 2020 -0400
    put geos requirement in with 3.1.0 note to denote only enabled is compiled with geos 3.9 or above
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index f40852d..1a4171a 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -3571,7 +3571,7 @@ MULTILINESTRING((1 3 2.75,1 4 2),(1 1 3,1 2 2.25))
         <para>Performed by the GEOS module.</para>
         <para>Availability: 2.2.0</para>
         <para>Enhanced: 2.5.0 reuses existing points on polygon split, vertex count is lowered from 8 to 5.</para>
-        <para>Enhanced: 3.1.0 accept a gridSize parameter.</para>
+        <para>Enhanced: 3.1.0 accept a gridSize parameter, requires GEOS >= 3.9.0 to use this new feature.</para>
       </refsection>
       <refsection>
Summary of changes:
 doc/reference_processing.xml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
