[postgis-tickets] [PostGIS] #4730: Overlay GEOS 3.9 regress failures
trac at osgeo.org
Mon Oct 26 12:29:22 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
From a fresh build of 3.9 with overlayng, it fails in makevalid unit
tests:
Test: test_geos_makevalid ...FAILED
1. cu_geos.c:152 - ASSERT_STRING_EQUAL
* Expected: GEOMETRYCOLLECTION(POLYGON((92114.014
463463.469,92115.51207431706 463462.206937429,92115.512
463462.207,92127.546 463452.075,92117.173 463439.755,92133.675
463425.942,92122.136 463412.82600000006,92092.377 463437.77,92114.014
463463.469)),MULTIPOINT(92115.51207431706 463462.2069374289,92122.136
463412.826))
* Obtained: POLYGON((92127.546 463452.075,92117.173
463439.755,92133.675 463425.942,92122.136 463412.826,92092.377
463437.77,92114.014 463463.469,92115.512 463462.207,92115.51207431706
463462.2069374289,92127.546 463452.075))
And from subdivide regress tests:
--- subdivide_expected 2020-10-23 15:17:08.024418827 +0200
+++ /tmp/pgis_reg/test_120_out 2020-10-26 20:27:02.046694188 +0100
@@ -4,7 +4,7 @@
ERROR: lwgeom_subdivide_prec: cannot subdivide to fewer than 5 vertices
per output
#3522|POINT(1 1)
#3744|1600000000000000
-4|29321996468.6|29321996468.6|1857|256
+4|29321996468.6|29321996468.6|1856|256
#4211|0.00008316000
#4217|0.00002463668
#4301|0.00213614552
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4730#comment:16>
