[postgis-tickets] [PostGIS] #4643: PostgreSQL 13 no longer supports FROM in CREATE EXTENSION
PostGIS trac at osgeo.org
Mon Oct 26 13:22:56 PDT 2020
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS PostgreSQL
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 How did it not work ? We provided a way to avoid the `FROM` part, if
 you're still calling FROM it's "your" fault, not a problem with the
 workaround...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4643#comment:15>
