[postgis-tickets] [PostGIS] #4643: PostgreSQL 13 no longer supports FROM in CREATE EXTENSION
PostGIS trac at osgeo.org
Mon Oct 26 14:08:58 PDT 2020
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS PostgreSQL
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"e7c3c7f2a5d46d27fa7a7a4b0886d263265e6b72/git"
 e7c3c7f2/git]:
 #!CommitTicketReference repository="git"
 revision="e7c3c7f2a5d46d27fa7a7a4b0886d263265e6b72"
 Drop duplicated and mis-scoped variable, fixing PG13 unpackaged test
 Fixes #4643 for real
 Closes #4773
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4643#comment:17>
