[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-100-g50b1e70
git at osgeo.org
git at osgeo.org
Tue Oct 27 15:02:35 PDT 2020
the project "PostGIS".
via 50b1e70b1a9d14b2e152dce4416247149ac3f77c (commit)
from c1b8d14d8900dc835fd5782f364364ffa963919e (commit)
revisions in full, below.
commit 50b1e70b1a9d14b2e152dce4416247149ac3f77c
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 27 23:01:50 2020 +0100
Check existence of init script, show upgrade dump log if any
diff --git a/utils/check_cluster_upgrade.sh b/utils/check_cluster_upgrade.sh
index 8b530a6..adb8cd7 100755
--- a/utils/check_cluster_upgrade.sh
+++ b/utils/check_cluster_upgrade.sh
@@ -15,7 +15,9 @@ usage() {
cleanup() {
- ${BIN_OLD}/pg_ctl -D ${DATADIR} stop || exit 1
+ if test -f ${DATADIR}/cluster/postmaster.pid; then
+ ${BIN_OLD}/pg_ctl -D ${DATADIR} stop
+ fi
rm -rf ${TMPDIR}
@@ -27,6 +29,12 @@ while test -n "$1"; do
if test "$1" = "-i"; then
shift
INIT_SCRIPT=$1
+ if test -f ${INIT_SCRIPT}; then
+ else
+ echo "${INIT_SCRIPT} is not a file" >&2
+ exit 1
+ fi
shift
elif test -z "$PG_CONFIG_OLD"; then
PG_CONFIG_OLD="$1"
@@ -102,7 +110,13 @@ ${BIN_NEW}/initdb ${PGDATANEW} > ${LOGFILE} 2>&1 || {
echo "Upgrading cluster"
cd ${TMPDIR}
${BIN_NEW}/pg_upgrade --link -b ${BIN_OLD} -B ${BIN_NEW} > ${LOGFILE} 2>&1 || {
- cat ${LOGFILE} && exit 1
+ cat ${LOGFILE}
+ DUMPLOG=$(grep 'pg_upgrade_dump.*log' ${LOGFILE} | cut -d'"' -f2)
+ if test -n "${DUMPLOG}"; then
+ echo "${DUMPLOG} follows:"
+ tail ${TMPDIR}/${DUMPLOG}
+ fi
+ exit 1
echo "Starting TO cluster"
Summary of changes:
utils/check_cluster_upgrade.sh | 18 ++++++++++++++++--
1 file changed, 16 insertions(+), 2 deletions(-)
hooks/post-receive
