[postgis-tickets] [PostGIS] #4777: core tests are using \copy with hard-coded relative paths
trac at osgeo.org
Wed Oct 28 12:39:32 PDT 2020
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by strk):
One solution would be to have run_test.pl perform keyword substitution on
the .sql files
(psql variables do not work with \copy)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4777#comment:2>
