[postgis-tickets] [PostGIS] #4777: core tests are using \copy with hard-coded relative paths
trac at osgeo.org
Wed Oct 28 14:15:36 PDT 2020
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: build/upgrade/install | Version: 2.5.x
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"47e75c49349ad1b89a9b93605cfe98211744180f/git" 47e75c4/git]:
#!CommitTicketReference repository="git"
revision="47e75c49349ad1b89a9b93605cfe98211744180f"
Load each regress test in its own directory
Closes #4777 by making it allowed to use hard-coded paths
Update topology tests so hard-coded paths are relative to the
script file rather than the supposed calling path, allowing
them to be run from any directory too
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4777#comment:4>
