[postgis-tickets] [PostGIS] #4207: Allow running loader tests in isolation from the rest
PostGIS trac at osgeo.org
Wed Oct 28 17:04:38 PDT 2020
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.2.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"8d3cf31a3a13c0ce2e4d5025389d6a023dd63848/git" 8d3cf31/git]:
 #!CommitTicketReference repository="git"
 revision="8d3cf31a3a13c0ce2e4d5025389d6a023dd63848"
 Refactor autotools configuration for regression tests
 - Runs sfcgal tests in the same db with core tests
 - Allow running loader/dumper tests in isolation
 Closes #4207
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4207#comment:4>
