[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-112-gda75327
git at osgeo.org
git at osgeo.org
Thu Oct 29 04:04:00 PDT 2020
the project "PostGIS".
via da7532753681e680fd3de7893f2aeb52f4caf4e2 (commit)
from d781ecf29220b0a09ec3484db7f24f3ed08d7d2d (commit)
revisions in full, below.
commit da7532753681e680fd3de7893f2aeb52f4caf4e2
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Oct 29 12:03:42 2020 +0100
Have topology regress test re-use global checker rule
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index 4ec466e..9783b03 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -35,61 +35,12 @@ load_topology-4326.sql: load_topology.sql.in
clean distclean:
rm -f topo_predicates.sql load_topology.sql load_topology-4326.sql
-TESTS = regress/legacy_validate.sql regress/legacy_predicate.sql \
- regress/legacy_invalid.sql regress/sqlmm.sql \
- regress/legacy_query.sql regress/addnode.sql \
- regress/addedge.sql regress/addface.sql \
- regress/addface2.5d.sql \
- regress/addtopogeometrycolumn.sql \
- regress/polygonize.sql \
- regress/st_addisoedge.sql \
- regress/st_addisonode.sql \
- regress/st_addedgemodface.sql \
- regress/st_addedgenewfaces.sql \
- regress/st_changeedgegeom.sql \
- regress/st_createtopogeo.sql \
- regress/st_getfacegeometry.sql \
- regress/st_getfaceedges.sql \
- regress/st_modedgeheal.sql \
- regress/st_modedgesplit.sql \
- regress/st_newedgeheal.sql \
- regress/st_newedgessplit.sql \
- regress/st_remedgenewface.sql \
- regress/st_remedgemodface.sql \
- regress/st_simplify.sql \
- regress/topoelement.sql \
- regress/topoelementarray_agg.sql \
- regress/topogeo_addlinestring.sql \
- regress/topogeo_addpoint.sql \
- regress/topogeo_addpolygon.sql \
- regress/topogeom_edit.sql \
- regress/topogeometry_type.sql \
- regress/topojson.sql \
- regress/topologysummary.sql \
- regress/topo2.5d.sql \
- regress/totopogeom.sql \
- regress/droptopology.sql \
- regress/droptopogeometrycolumn.sql \
- regress/copytopology.sql \
- regress/createtopogeom.sql \
- regress/createtopology.sql \
- regress/gml.sql \
- regress/getnodebypoint.sql \
- regress/getedgebypoint.sql \
- regress/getfacebypoint.sql \
- regress/getringedges.sql \
- regress/gettopogeomelements.sql \
- regress/layertrigger.sql \
- regress/validatetopology.sql
+check-regress: check
+check: topo_predicates.sql load_topology.sql load_topology-4326.sql
-TESTS_EXPECTED = $(TESTS:.sql=_expected)
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
-check: check-regress
+topsrcdir = $(realpath ../../)
-check-regress: topo_predicates.sql load_topology.sql load_topology-4326.sql $(TESTS) $(TESTS_EXPECTED)
- $(MAKE) -C ../../regress staged-install
- $(PERL) ../../regress/run_test.pl --topology $(RUNTESTFLAGS) $(TESTS)
- # only run upgrade test if RUNTESTFLAGS was not already doing that
- if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
- $(PERL) ../../regress/run_test.pl --upgrade --topology $(RUNTESTFLAGS) $(TESTS); \
- fi
+include tests.mk
+include ../../regress/runtest.mk
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
new file mode 100644
index 0000000..f46097a
--- /dev/null
+++ b/topology/test/tests.mk
@@ -0,0 +1,64 @@
+# * PostGIS - Spatial Types for PostgreSQL
+# * http://postgis.net
+# * Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
+# * This is free software; you can redistribute and/or modify it under
+# * the terms of the GNU General Public Licence. See the COPYING file.
+TESTS += \
+ $(topsrcdir)/topology/test/regress/addedge.sql \
+ $(topsrcdir)/topology/test/regress/addface2.5d.sql \
+ $(topsrcdir)/topology/test/regress/addface.sql \
+ $(topsrcdir)/topology/test/regress/addnode.sql \
+ $(topsrcdir)/topology/test/regress/addtopogeometrycolumn.sql \
+ $(topsrcdir)/topology/test/regress/copytopology.sql \
+ $(topsrcdir)/topology/test/regress/createtopogeom.sql \
+ $(topsrcdir)/topology/test/regress/createtopology.sql \
+ $(topsrcdir)/topology/test/regress/droptopogeometrycolumn.sql \
+ $(topsrcdir)/topology/test/regress/droptopology.sql \
+ $(topsrcdir)/topology/test/regress/getedgebypoint.sql \
+ $(topsrcdir)/topology/test/regress/getfacebypoint.sql \
+ $(topsrcdir)/topology/test/regress/getnodebypoint.sql \
+ $(topsrcdir)/topology/test/regress/getringedges.sql \
+ $(topsrcdir)/topology/test/regress/gettopogeomelements.sql \
+ $(topsrcdir)/topology/test/regress/gml.sql \
+ $(topsrcdir)/topology/test/regress/layertrigger.sql \
+ $(topsrcdir)/topology/test/regress/legacy_invalid.sql \
+ $(topsrcdir)/topology/test/regress/legacy_predicate.sql \
+ $(topsrcdir)/topology/test/regress/legacy_query.sql \
+ $(topsrcdir)/topology/test/regress/legacy_validate.sql \
+ $(topsrcdir)/topology/test/regress/polygonize.sql \
+ $(topsrcdir)/topology/test/regress/sqlmm.sql \
+ $(topsrcdir)/topology/test/regress/st_addedgemodface.sql \
+ $(topsrcdir)/topology/test/regress/st_addedgenewfaces.sql \
+ $(topsrcdir)/topology/test/regress/st_addisoedge.sql \
+ $(topsrcdir)/topology/test/regress/st_addisonode.sql \
+ $(topsrcdir)/topology/test/regress/st_changeedgegeom.sql \
+ $(topsrcdir)/topology/test/regress/st_createtopogeo.sql \
+ $(topsrcdir)/topology/test/regress/st_getfaceedges.sql \
+ $(topsrcdir)/topology/test/regress/st_getfacegeometry.sql \
+ $(topsrcdir)/topology/test/regress/st_modedgeheal.sql \
+ $(topsrcdir)/topology/test/regress/st_modedgesplit.sql \
+ $(topsrcdir)/topology/test/regress/st_newedgeheal.sql \
+ $(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
+ $(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
+ $(topsrcdir)/topology/test/regress/st_remedgenewface.sql \
+ $(topsrcdir)/topology/test/regress/st_simplify.sql \
+ $(topsrcdir)/topology/test/regress/topo2.5d.sql \
+ $(topsrcdir)/topology/test/regress/topoelementarray_agg.sql \
+ $(topsrcdir)/topology/test/regress/topoelement.sql \
+ $(topsrcdir)/topology/test/regress/topogeo_addlinestring.sql \
+ $(topsrcdir)/topology/test/regress/topogeo_addpoint.sql \
+ $(topsrcdir)/topology/test/regress/topogeo_addpolygon.sql \
+ $(topsrcdir)/topology/test/regress/topogeom_edit.sql \
+ $(topsrcdir)/topology/test/regress/topogeometry_type.sql \
+ $(topsrcdir)/topology/test/regress/topojson.sql \
+ $(topsrcdir)/topology/test/regress/topologysummary.sql \
+ $(topsrcdir)/topology/test/regress/totopogeom.sql \
+ $(topsrcdir)/topology/test/regress/validatetopology.sql
Summary of changes:
topology/test/Makefile.in | 61 +++++---------------------------------------
topology/test/tests.mk | 64 +++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 70 insertions(+), 55 deletions(-)
create mode 100644 topology/test/tests.mk
hooks/post-receive
