[postgis-tickets] [PostGIS] #4779: server process (PID 49666) was terminated by signal 6: Aborted, munmap_chunk(): invalid pointer
trac at osgeo.org
Thu Oct 29 06:25:53 PDT 2020
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Keywords: |
Hi
Postgres crashes right after this command.
pg_restore --section=pre-data --format=d -d sl
data/sl/schema_sl_rest_ofd/ 2> log/sl/restore_sl_rest_ofdata_pre_data.log
There are no error in the restore_sl_rest_ofdata_pre_data.log
The pre-data input is little bit more than 200.000 lines with more than
6000 CREATE statements, if I test with the first 100 lines it does not
crash. It seems like no data are lost here because the server does
recovery at startup.
This happens on with Postgres 12 and Postgres 13 for Os I use CentOS Linux
release 8 on all the severs. It seems to work on Postgis 2.5 but it seems
to fail on any Postgis 3 version.
I have tried to find out what commands that are causeing this problem ,
but have not been able to find it, but I will get some help on Friday to
see if we can find out more and make a simple SQL that fails.
The test 1 with Postgis 3.0 :
POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3"
SFCGAL="1.3.7" PROJ="7.1.1" GDAL="GDAL 3.1.3, released 2020/09/01"
LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.4.3
(Internal)" TOPOLOGY RASTER
In the postgres log I see this :
< , , 2020-10-28 06:37:37.215 CET >LOG: server process (PID 49666) was
< , , 2020-10-28 06:37:37.215 CET >LOG: terminating any other active
server processes
< , , 2020-10-28 06:37:37.215 CET >WARNING: terminating connection
because of crash of another server process
< , , 2020-10-28 06:37:37.215 CET >DETAIL: The postmaster has commanded
this server process to roll back the current transaction and exit, because
another server process exited abnormally and possibly corrupted shared
memory.
< , , 2020-10-28 06:37:37.215 CET >HINT: In a moment you should be able
to reconnect to the database and repeat your command.
< , , 2020-10-28 06:37:37.216 CET >LOG: all server processes terminated;
reinitializing
< , , 2020-10-28 06:37:37.618 CET >LOG: database system was interrupted;
last known up at 2020-10-28 06:37:34 CET
< , , 2020-10-28 06:37:37.628 CET >LOG: database system was not properly
shut down; automatic recovery in progress
< , , 2020-10-28 06:37:37.628 CET >LOG: redo starts at 0/164B250
< , , 2020-10-28 06:37:37.662 CET >LOG: invalid record length at
0/21C9FE8: wanted 24, got 0
< , , 2020-10-28 06:37:37.662 CET >LOG: redo done at 0/21C6478
< , , 2020-10-28 06:37:37.768 CET >LOG: database system is ready to
accept connections
Here is the stacktrace :
gdb /usr/pgsql-12/bin/postmaster
/var/lib/systemd/coredump/core.postmaster.26.3d2c9cba8e9e4eefb0831fc9d85d7a4f.50446.1603863575000000
Program terminated with signal SIGABRT, Aborted.
#0 0x00007f0929bf970f in raise () from /lib64/libc.so.6
Missing separate debuginfos, use: yum debuginfo-install
SuperLU-5.2.0-7.el8.x86_64 atlas-3.10.3-7.el8.x86_64 audit-
libs-3.0-0.17.20191104git1c2f876.el8.x86_64 blas-3.8.0-8.el8.x86_64 boost-
atomic-1.66.0-7.el8.x86_64 boost-chrono-1.66.0-7.el8.x86_64 boost-date-
time-1.66.0-7.el8.x86_64 boost-serialization-1.66.0-7.el8.x86_64 boost-
system-1.66.0-7.el8.x86_64 boost-thread-1.66.0-7.el8.x86_64
brotli-1.0.6-1.el8.x86_64 bzip2-libs-1.0.6-26.el8.x86_64 cyrus-sasl-
lib-2.1.27-1.el8.x86_64 expat-2.2.5-3.el8.x86_64
fontconfig-2.13.1-3.el8.x86_64 freetype-2.9.1-4.el8.x86_64
gdal31-libs-3.1.3-2.rhel8.x86_64 geos38-3.8.1-2.rhel8.x86_64
giflib-5.1.4-3.el8.x86_64 glibc-2.28-101.el8.x86_64
gmp-6.1.2-10.el8.x86_64 jasper-libs-2.0.14-4.el8.x86_64
json-c-0.13.1-0.2.el8.x86_64 keyutils-libs-1.5.10-6.el8.x86_64
krb5-libs-1.17-18.el8.x86_64 lapack-3.8.0-8.el8.x86_64
libblkid-2.32.1-22.el8.x86_64 libcap-2.26-3.el8.x86_64 libcap-
ng-0.7.9-5.el8.x86_64 libcom_err-1.45.4-3.el8.x86_64
libcurl-7.61.1-12.el8.x86_64 libgcc-8.3.1-5.el8.0.2.x86_64
libgcrypt-1.8.3-4.el8.x86_64 libgfortran-8.3.1-5.el8.0.2.x86_64
libgomp-8.3.1-5.el8.0.2.x86_64 libgpg-error-1.31-1.el8.x86_64
libicu-60.3-2.el8_1.x86_64 libidn2-2.2.0-1.el8.x86_64 libjpeg-
turbo-1.5.3-10.el8.x86_64 libmount-2.32.1-22.el8.x86_64
libnghttp2-1.33.0-3.el8_2.1.x86_64 libpng-1.6.34-5.el8.x86_64
libpsl-0.20.2-5.el8.x86_64 libquadmath-8.3.1-5.el8.0.2.x86_64
libselinux-2.9-3.el8.x86_64 libssh-0.9.0-4.el8.x86_64
libstdc++-8.3.1-5.el8.0.2.x86_64 libtiff-4.0.9-17.el8.x86_64
libuuid-2.32.1-22.el8.x86_64 libwebp-1.0.0-1.el8.x86_64
libxcrypt-4.1.1-4.el8.x86_64 libxml2-2.9.7-7.el8.x86_64
libzstd-1.4.2-2.el8.x86_64 lz4-libs-1.8.1.2-4.el8.x86_64
mpfr-3.1.6-1.el8.x86_64 nspr-4.25.0-2.el8_2.x86_64 ogdi-4.1.0-1.el8.x86_64
openblas-openmp-0.3.3-5.el8.x86_64 openblas-threads-0.3.3-5.el8.x86_64
openldap-2.4.46-11.el8_1.x86_64 openssl-libs-1.1.1c-15.el8.x86_64
pam-1.3.1-8.el8.x86_64 pcre-8.42-4.el8.x86_64 poppler-0.66.0-26.el8.x86_64
postgis30_12-3.0.2-2.rhel8.x86_64 proj-6.3.2-4.el8.x86_64
proj71-7.1.1-1.rhel8.x86_64 protobuf-c-1.3.0-4.el8.x86_64 sqlite-
libs-3.26.0-6.el8.x86_64 sssd-client-2.2.3-20.el8.x86_64 systemd-
libs-239-31.el8_2.2.x86_64 xz-libs-5.2.4-3.el8.x86_64
zlib-1.2.11-16.el8_2.x86_64
(gdb) bt
#1 0x00007f0929be3b25 in abort () from /lib64/libc.so.6
#2 0x00007f0929c3c897 in __libc_message () from /lib64/libc.so.6
#3 0x00007f0929c42fdc in malloc_printerr () from /lib64/libc.so.6
#4 0x00007f0929c448dc in _int_free () from /lib64/libc.so.6
#5 0x00007f09224fe285 in
osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() () from
/usr/proj71/lib/libproj.so.19
#6 0x00007f0929bfbe9c in __run_exit_handlers () from /lib64/libc.so.6
#7 0x00007f0929bfbfd0 in exit () from /lib64/libc.so.6
#8 0x000000000075beb0 in proc_exit (code=code at entry=0) at ipc.c:152
#9 0x000000000077fd21 in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x111c218, dbname=<optimized out>, username=<optimized
out>) at postgres.c:4455
#10 0x00000000007085a1 in BackendRun (port=0x1119df0, port=0x1119df0) at
postmaster.c:4448
#11 BackendStartup (port=0x1119df0) at postmaster.c:4139
#12 ServerLoop () at postmaster.c:1704
#13 0x00000000007094d0 in PostmasterMain (argc=argc at entry=3,
argv=argv at entry=0x10e87f0) at postmaster.c:1377
#14 0x0000000000482c7e in main (argc=3, argv=0x10e87f0) at main.c:228
Test 2 with Postgis 3.1 :
POSTGIS="3.1.0alpha2 b6f415d" [EXTENSION] PGSQL="120"
GEOS="3.8.1-CAPI-1.13.3" SFCGAL="1.3.7" PROJ="7.1.1" GDAL="GDAL 3.1.3,
released 2020/09/01" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0"
WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
free(): invalid pointer
< , , 2020-10-29 09:27:51.215 CET >LOG: server process (PID 352306) was
< , , 2020-10-29 09:27:51.215 CET >LOG: terminating any other active
server processes
< , , 2020-10-29 09:27:51.215 CET >WARNING: terminating connection
< , , 2020-10-29 09:27:51.215 CET >DETAIL: The postmaster has commanded
memory.
< , , 2020-10-29 09:27:51.215 CET >HINT: In a moment you should be able
< , , 2020-10-29 09:27:51.216 CET >LOG: all server processes terminated;
reinitializing
< , , 2020-10-29 09:27:51.618 CET >LOG: database system was interrupted;
last known up at 2020-10-29 09:27:48 CET
< , , 2020-10-29 09:27:51.628 CET >LOG: database system was not properly
< , , 2020-10-29 09:27:51.629 CET >LOG: redo starts at 0/7BD37E0
< , , 2020-10-29 09:27:51.758 CET >LOG: invalid record length at
0/8736410: wanted 24, got 0
< , , 2020-10-29 09:27:51.758 CET >LOG: redo done at 0/8736368
< , , 2020-10-29 09:27:51.867 CET >LOG: database system is ready to
accept connections
/var/lib/systemd/coredump/core.postmaster.26.3d2c9cba8e9e4eefb0831fc9d85d7a4f.352306.1603960069000000
#0 0x00007fcea664a70f in raise () from /lib64/libc.so.6
postgis31_12-3.1.0-alpha2_2.rhel8.x86_64 proj-6.3.2-4.el8.x86_64
(gdb) bt
#1 0x00007fcea6634b25 in abort () from /lib64/libc.so.6
#2 0x00007fcea668d897 in __libc_message () from /lib64/libc.so.6
#3 0x00007fcea6693fdc in malloc_printerr () from /lib64/libc.so.6
#4 0x00007fcea66958dc in _int_free () from /lib64/libc.so.6
#5 0x00007fbe13f8e285 in
#6 0x00007fcea664ce9c in __run_exit_handlers () from /lib64/libc.so.6
#7 0x00007fcea664cfd0 in exit () from /lib64/libc.so.6
argv=argv at entry=0x1820138, dbname=<optimized out>, username=<optimized
#10 0x00000000007085a1 in BackendRun (port=0x181dc80, port=0x181dc80) at
postmaster.c:4448
#11 BackendStartup (port=0x181dc80) at postmaster.c:4139
argv=argv at entry=0x17ed800) at postmaster.c:1377
#14 0x0000000000482c7e in main (argc=3, argv=0x17ed800) at main.c:228
The test 3 with Postgis Compiled code :
POSTGIS="3.1.0dev 3.1.0alpha2-100-g50b1e70b1" [EXTENSION] PGSQL="120"
< , , 2020-10-29 13:34:29.525 CET >LOG: server process (PID 418670) was
< , , 2020-10-29 13:34:29.525 CET >LOG: terminating any other active
server processes
< , , 2020-10-29 13:34:29.525 CET >WARNING: terminating connection
< , , 2020-10-29 13:34:29.525 CET >DETAIL: The postmaster has commanded
memory.
< , , 2020-10-29 13:34:29.525 CET >HINT: In a moment you should be able
< , , 2020-10-29 13:34:29.526 CET >LOG: all server processes terminated;
reinitializing
< , , 2020-10-29 13:34:29.933 CET >LOG: database system was interrupted;
last known up at 2020-10-29 13:34:06 CET
< , , 2020-10-29 13:34:30.063 CET >LOG: database system was not properly
< , , 2020-10-29 13:34:30.091 CET >LOG: redo starts at 0/14F4F038
< , , 2020-10-29 13:34:30.624 CET >LOG: invalid record length at
0/1A56E4A0: wanted 24, got 0
< , , 2020-10-29 13:34:30.624 CET >LOG: redo done at 0/1A56E428
< , , 2020-10-29 13:34:30.893 CET >LOG: database system is ready to
accept connections
/var/lib/systemd/coredump/core.postmaster.26.3d2c9cba8e9e4eefb0831fc9d85d7a4f.418670.1603974867000000
#0 0x00007f5b7f80270f in raise () from /lib64/libc.so.6
gmp-6.1.2-10.el8.x86_64 jasper-libs-2.0.14-4.el8.x86_64 jbigkit-
libs-2.1-14.el8.x86_64 json-c-0.13.1-0.2.el8.x86_64 keyutils-
libs-1.5.10-6.el8.x86_64 krb5-libs-1.17-18.el8.x86_64
lapack-3.8.0-8.el8.x86_64 libaec-1.0.2-3.el8.x86_64
pgrouting_12-3.1.0-2.rhel8.x86_64 poppler-0.66.0-26.el8.x86_64
proj-6.3.2-4.el8.x86_64 protobuf-c-1.3.0-4.el8.x86_64 sqlite-
(gdb) bt
#1 0x00007f5b7f7ecb25 in abort () from /lib64/libc.so.6
#2 0x00007f5b7f845897 in __libc_message () from /lib64/libc.so.6
#3 0x00007f5b7f84bfdc in malloc_printerr () from /lib64/libc.so.6
#4 0x00007f5b7f84d8dc in _int_free () from /lib64/libc.so.6
#5 0x00007f5b77adf285 in __gnu_cxx::new_allocator<char>::deallocate
(this=0x16a6840, __p=<optimized out>) at
/usr/include/c++/8/ext/new_allocator.h:116
#6 std::allocator_traits<std::allocator<char> >::deallocate (__a=...,
__n=<optimized out>, __p=<optimized out>) at
/usr/include/c++/8/bits/alloc_traits.h:462
#7 std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >::_M_destroy (__size=<optimized out>,
this=0x16a6840) at /usr/include/c++/8/bits/basic_string.h:226
#8 std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >::_M_dispose (this=0x16a6840) at
/usr/include/c++/8/bits/basic_string.h:221
#9 std::__cxx11::basic_string<char, std::char_traits<char>,
std::allocator<char> >::~basic_string (this=0x16a6840,
__in_chrg=<optimized out>) at /usr/include/c++/8/bits/basic_string.h:657
#10 osgeo::proj::common::UnitOfMeasure::Private::~Private (this=0x16a6840,
__in_chrg=<optimized out>) at iso19111/common.cpp:72
#11
std::default_delete<osgeo::proj::common::UnitOfMeasure::Private>::operator()
(this=0x7f5b77f2dfc0
<osgeo::proj::common::UnitOfMeasure::PPM_PER_YEAR+16>, __ptr=0x16a6840)
at /usr/include/c++/8/bits/unique_ptr.h:81
#12 std::unique_ptr<osgeo::proj::common::UnitOfMeasure::Private,
>::~unique_ptr (
this=0x7f5b77f2dfc0
__in_chrg=<optimized out>) at /usr/include/c++/8/bits/unique_ptr.h:269
#13 osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure
(this=0x7f5b77f2dfb0 <osgeo::proj::common::UnitOfMeasure::PPM_PER_YEAR>,
__in_chrg=<optimized out>) at ../include/proj/common.hpp:60
#14 0x00007f5b7f804e9c in __run_exit_handlers () from /lib64/libc.so.6
#15 0x00007f5b7f804fd0 in exit () from /lib64/libc.so.6
#16 0x000000000075beb0 in proc_exit (code=code at entry=0) at ipc.c:152
#17 0x000000000077fd21 in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x123c4b8, dbname=<optimized out>, username=<optimized
#18 0x00000000007085a1 in BackendRun (port=0x122bd50, port=0x122bd50) at
postmaster.c:4448
#19 BackendStartup (port=0x122bd50) at postmaster.c:4139
#20 ServerLoop () at postmaster.c:1704
#21 0x00000000007094d0 in PostmasterMain (argc=argc at entry=3,
argv=argv at entry=0x11f8800) at postmaster.c:1377
#22 0x0000000000482c7e in main (argc=3, argv=0x11f8800) at main.c:228
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4779>
