[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-117-g5770ad5
git at osgeo.org
git at osgeo.org
Fri Oct 30 05:09:56 PDT 2020
the project "PostGIS".
via 5770ad5b141ffaf31dcc06226ef948741ce829c5 (commit)
from 5d6bc59868f6c15237e76377c7b91b7b154f12c6 (commit)
revisions in full, below.
commit 5770ad5b141ffaf31dcc06226ef948741ce829c5
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Oct 30 13:09:32 2020 +0100
Disable fsync when starting PG cluster for testing purpose
Should save some time
diff --git a/ci/berrie/pg_init_start.sh b/ci/berrie/pg_init_start.sh
index d38d85b..6bc4a8e 100644
--- a/ci/berrie/pg_init_start.sh
+++ b/ci/berrie/pg_init_start.sh
@@ -13,7 +13,7 @@ export PGPORT=55432
export PGDATA=$PGPATH/data_${PGPORT}
export PGLOG="$PGDATA/pgsql.log"
# What to use to start up the postmaster
-DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -l logfile start"
+DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o "-F" -l logfile start"
# What to use to shut down the postmaster
PGCTL="$PGPATH/bin/pg_ctl"
diff --git a/ci/berrie64/pg_init_start.sh b/ci/berrie64/pg_init_start.sh
index 6959641..9c86bda 100644
--- a/ci/berrie64/pg_init_start.sh
+++ b/ci/berrie64/pg_init_start.sh
@@ -11,7 +11,7 @@ export PGPORT=55432
+DAEMON="$PGPATH/bin/pg_ctl -D $PGDATA -o '-F' -l logfile start"
diff --git a/ci/dronie/postgis_regress_alpine.sh b/ci/dronie/postgis_regress_alpine.sh
index 9e75823..dad522a 100644
--- a/ci/dronie/postgis_regress_alpine.sh
+++ b/ci/dronie/postgis_regress_alpine.sh
@@ -3,7 +3,7 @@
# Exit on first error
set -e
-su - postgres -c "export PGDATA=/var/lib/postgresql/data && pg_ctl -l /var/lib/postgresql/data/pg.log start"
+su - postgres -c "export PGDATA=/var/lib/postgresql/data && pg_ctl -l -o '-F' /var/lib/postgresql/data/pg.log start"
#export PGPORT=`grep ^port /var/lib/postgresql/postgresql.conf | awk '{print $3}'`
export PGPORT=5432
psql --version
diff --git a/ci/travis/run_coverage.sh b/ci/travis/run_coverage.sh
index 70b473c..13bd7e0 100644
--- a/ci/travis/run_coverage.sh
+++ b/ci/travis/run_coverage.sh
@@ -5,7 +5,7 @@ set -e
CFLAGS_COV="-g -O0 --coverage"
LDFLAGS_COV="--coverage"
-/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
+/usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile -o '-F' start
./autogen.sh
./configure CFLAGS="${CFLAGS_COV}" LDFLAGS="${LDFLAGS_COV}" --enable-debug
make -j check
diff --git a/ci/travis/run_garden.sh b/ci/travis/run_garden.sh
index 33b5627..e922b58 100644
--- a/ci/travis/run_garden.sh
+++ b/ci/travis/run_garden.sh
CFLAGS_STD="-g -O0 -mtune=generic -fno-omit-frame-pointer --coverage"
LDFLAGS_STD="--coverage"
./autogen.sh
./configure CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}" --enable-debug
make -j
diff --git a/ci/travis/run_nowagyu.sh b/ci/travis/run_nowagyu.sh
index 830cfb5..160afae 100644
--- a/ci/travis/run_nowagyu.sh
+++ b/ci/travis/run_nowagyu.sh
@@ -8,7 +8,7 @@ WARNINGS_DISABLED="-Wno-unused-parameter -Wno-implicit-fallthrough -Wno-cast-fun
CFLAGS="-g -O0 --coverage -mtune=generic -fno-omit-frame-pointer ${WARNINGS} ${WARNINGS_DISABLED}"
LDFLAGS="--coverage"
./autogen.sh
# Standard build
diff --git a/ci/travis/run_tests.sh b/ci/travis/run_tests.sh
index e4d5fae..bad7a77 100644
--- a/ci/travis/run_tests.sh
+++ b/ci/travis/run_tests.sh
@@ -11,7 +11,7 @@ LDFLAGS_STD="-Wl,-Bsymbolic-functions -Wl,-z,relro"
export CUNIT_WITH_VALGRIND=YES
export CUNIT_VALGRIND_FLAGS="--leak-check=full --error-exitcode=1"
./autogen.sh
# Standard build
diff --git a/ci/travis/run_usan_clang.sh b/ci/travis/run_usan_clang.sh
index 515176f..3357345 100644
--- a/ci/travis/run_usan_clang.sh
+++ b/ci/travis/run_usan_clang.sh
@@ -10,7 +10,8 @@ export ASAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
export MSAN_OPTIONS=halt_on_error=false,leak_check_at_exit=false,exitcode=0
#Run postgres preloading sanitizer libs
-LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so /usr/local/pgsql/bin/pg_ctl -c -l /tmp/logfile start
+LD_PRELOAD=/usr/lib/clang/9/lib/linux/libclang_rt.asan-x86_64.so \
+/usr/local/pgsql/bin/pg_ctl -c -o '-F' -l /tmp/logfile start
# Build with Clang and usan flags
diff --git a/ci/travis/run_usan_gcc.sh b/ci/travis/run_usan_gcc.sh
index 8943dd7..333cb3c 100644
--- a/ci/travis/run_usan_gcc.sh
+++ b/ci/travis/run_usan_gcc.sh
CFLAGS_STD="-g3 -O0 -mtune=generic -fno-omit-frame-pointer -fsanitize=undefined -fsanitize-undefined-trap-on-error"
./autogen.sh
# Build with GCC and usan flags
Summary of changes:
ci/berrie/pg_init_start.sh | 2 +-
ci/berrie64/pg_init_start.sh | 2 +-
ci/dronie/postgis_regress_alpine.sh | 2 +-
ci/travis/run_coverage.sh | 2 +-
ci/travis/run_garden.sh | 2 +-
ci/travis/run_nowagyu.sh | 2 +-
ci/travis/run_tests.sh | 2 +-
ci/travis/run_usan_clang.sh | 3 ++-
ci/travis/run_usan_gcc.sh | 2 +-
9 files changed, 10 insertions(+), 9 deletions(-)
hooks/post-receive
