[postgis-tickets] [PostGIS] #4779: server process (PID 49666) was terminated by signal 6: Aborted, munmap_chunk(): invalid pointer
trac at osgeo.org
Sat Oct 31 01:50:46 PDT 2020
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by laopsahl):
I got help from Magnus Hagender he found out that the problem was related
this [https://stackoverflow.com/questions/42912038/what-is-the-difference-
between-cxa-atexit-and-atexit]. He also that this does not happen all
systems. Hen had run it on CentOs before i failed.
Then I managed to make a simple test cases that fails.
Run this command
psql postgres -c "drop DATABASE test1"
psql postgres -c "CREATE DATABASE test1 template=template0;"
psql test1 -c "create extension pg_stat_statements; create extension
postgis; create extension postgis_topology; create extension
postgis_raster ;"
and I find this in my postgres log
free(): invalid pointer
2020-10-31 10:50:50.857 CET [25765] LOG: server process (PID 28736) was
2020-10-31 10:50:50.857 CET [25765] LOG: terminating any other active
server processes
2020-10-31 10:50:50.857 CET [28731] WARNING: terminating connection
because of crash of another server process
2020-10-31 10:50:50.857 CET [28731] DETAIL: The postmaster has commanded
this server process to roll back the current transaction and exit, because
another server process exited abnormally and possibly corrupted shared
memory.
2020-10-31 10:50:50.857 CET [28731] HINT: In a moment you should be able
to reconnect to the database and repeat your command.
2020-10-31 10:50:50.858 CET [25765] LOG: all server processes terminated;
reinitializing
2020-10-31 10:50:50.906 CET [28740] LOG: database system was interrupted;
last known up at 2020-10-31 10:50:49 CET
2020-10-31 10:50:51.404 CET [28740] LOG: database system was not properly
shut down; automatic recovery in progress
2020-10-31 10:50:51.427 CET [28740] LOG: redo starts at 0/EF5E570
2020-10-31 10:50:51.470 CET [28740] LOG: invalid record length at
0/FA38A08: wanted 24, got 0
2020-10-31 10:50:51.470 CET [28740] LOG: redo done at 0/FA207A0
2020-10-31 10:50:52.021 CET [25765] LOG: database system is ready to
accept connections
Then run this
psql test1 -c "CREATE SCHEMA test_topo_ar50;
CREATE UNLOGGED TABLE
test_topo_ar50.ar50_utvikling_flate_border_line_many_points (
id integer NOT NULL,
log_time timestamp without time zone DEFAULT now(),
geo public.geometry(LineString,25833)
CREATE SEQUENCE
test_topo_ar50.ar50_utvikling_flate_border_line_many_points_id_seq
AS integer
START WITH 1
INCREMENT BY 1
NO MINVALUE
NO MAXVALUE
CACHE 1;
CREATE SCHEMA tmp_jm_raster;
CREATE TABLE tmp_jm_raster.dem25_norge_raster (
rid integer NOT NULL,
rast public.raster,
filename text,
CONSTRAINT enforce_height_rast CHECK ((public.st_height(rast) = 100)),
CONSTRAINT enforce_max_extent_rast CHECK
(public.st_coveredby(public.st_convexhull(rast),
'0103000020E96400000100000005000000000000001803FCC0000000A01C6C5841000000001803FCC0000000A06E645E4100000080DA483141000000A06E645E4100000080DA483141000000A01C6C5841000000001803FCC0000000A01C6C5841'::public.geometry)),
CONSTRAINT enforce_nodata_values_rast CHECK
(((public._raster_constraint_nodata_values(rast))::numeric(16,10)[] =
'{32767}'::numeric(16,10)[])),
CONSTRAINT enforce_num_bands_rast CHECK ((public.st_numbands(rast) =
1)),
CONSTRAINT enforce_out_db_rast CHECK
((public._raster_constraint_out_db(rast) = '{f}'::boolean[])),
CONSTRAINT enforce_pixel_types_rast CHECK
((public._raster_constraint_pixel_types(rast) = '{16BSI}'::text[])),
CONSTRAINT enforce_same_alignment_rast CHECK
(public.st_samealignment(rast,
'0100000000000000000000394000000000000039C0000000001803FCC0000000A06E645E4100000000000000000000000000000000E964000001000100'::public.raster)),
CONSTRAINT enforce_scalex_rast CHECK
(((public.st_scalex(rast))::numeric(16,10) = (25)::numeric(16,10))),
CONSTRAINT enforce_scaley_rast CHECK
(((public.st_scaley(rast))::numeric(16,10) =
('-25'::integer)::numeric(16,10))),
CONSTRAINT enforce_srid_rast CHECK ((public.st_srid(rast) = 25833)),
CONSTRAINT enforce_width_rast CHECK ((public.st_width(rast) = 100))
CREATE SCHEMA ok_grl;
CREATE TABLE ok_grl.ok_kommkyst_flate (
gid integer NOT NULL,
ftema integer,
komid integer,
kartblad_5 character varying(9),
kartblad_10 character varying(9),
kartblad_20 character varying(9),
kartblad_dmk character varying(9),
dmk_kode integer,
areal numeric,
objectid integer,
area numeric,
len numeric,
geo public.geometry,
CONSTRAINT enforce_dims_geo CHECK ((public.st_ndims(geo) = 2)),
CONSTRAINT enforce_geotype_geo CHECK (((public.geometrytype(geo) =
'POLYGON'::text) OR (geo IS NULL))),
CONSTRAINT enforce_srid_geo CHECK ((public.st_srid(geo) = 4258))
CREATE SEQUENCE ok_grl.ok_kommkyst_flate_gid_seq
START WITH 1
INCREMENT BY 1
NO MINVALUE
NO MAXVALUE
CACHE 1;"
and you see this again
2020-10-31 10:51:20.530 CET [25765] LOG: server process (PID 28753) was
2020-10-31 10:51:20.530 CET [25765] LOG: terminating any other active
server processes
2020-10-31 10:51:20.530 CET [28750] WARNING: terminating connection
2020-10-31 10:51:20.530 CET [28750] DETAIL: The postmaster has commanded
memory.
2020-10-31 10:51:20.530 CET [28750] HINT: In a moment you should be able
2020-10-31 10:51:20.531 CET [25765] LOG: all server processes terminated;
reinitializing
2020-10-31 10:51:20.624 CET [28756] LOG: database system was interrupted;
last known up at 2020-10-31 10:50:51 CET
2020-10-31 10:51:20.894 CET [28756] LOG: database system was not properly
2020-10-31 10:51:20.920 CET [28756] LOG: redo starts at 0/FA38A80
2020-10-31 10:51:20.921 CET [28756] LOG: invalid record length at
0/FA79D40: wanted 24, got 0
2020-10-31 10:51:20.921 CET [28756] LOG: redo done at 0/FA78988
2020-10-31 10:51:21.322 CET [25765] LOG: database system is ready to
accept connections
(sorry wrong time on my test server)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4779#comment:2>
