[postgis-tickets] [PostGIS] #4750: Performance issue with computed columns
trac at osgeo.org
Sat Sep 5 07:37:10 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.0.3
Component: postgis | Version: 3.0.x
Keywords: |
As discussed in this blog post:
https://blog.rustprooflabs.com/2019/12/postgres12-generated-columns-
postgis
Using generated columns seems to be much slower than using on the fly
computation. I was able to replicate similar results on my tiger data.
In my case, I was using tiger colorado state boundary and edges.
PostgreSQL 12.4, compiled by Visual C++ build 1914, 64-bit POSTGIS="3.0.2
3.0.2" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3" SFCGAL="1.3.8"
PROJ="Rel. 5.2.0, September 15th, 2018" LIBXML="2.9.9" LIBJSON="0.12"
LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)"
A computed query such as this
-- took 6 secs 314 msec
SELECT COUNT(p.*)
FROM test.co_random_points p
INNER JOIN test.co_road_line r
ON ST_Contains(ST_Buffer(ST_Transform(way_4326, 3857), 500),
r.way);
In contrast,
way_buffer created using:
ALTER TABLE test.co_random_points
ADD way_buffer GEOMETRY (POLYGON, 3857)
GENERATED ALWAYS AS (ST_Buffer(ST_Transform(way_4326, 3857), 500))
STORED ;
-- 30 secs
SELECT COUNT(p.*)
ON ST_Contains(p.way_buffer, r.way);
-- manual buffer create using
ADD way_buffer_manual GEOMETRY (POLYGON, 3857);
UPDATE test.co_random_points
SET way_buffer_manual = way_buffer;
CREATE INDEX ix_random_points_way_buffer_manual_gist ON
USING GIST (way_buffer_manual);
-- returns in 1 secs 227ms
SELECT COUNT(p.*)
ON ST_Contains(p.way_buffer_manual, r.way)
Can think of a reason why a computed column should be any worse than a
manual column.
I'll try to come up with a smaller test case we can easily fit in our
testing
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4750>
