[postgis-tickets] [PostGIS] #4752: PostGIS 3.0.2 build error on ppc64le
trac at osgeo.org
Fri Sep 11 05:57:14 PDT 2020
Reporter: devrimgunduz | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.3
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
There is 2 things I see from those logs:
- Lots of warnings coming from the stdlib (/opt/at10.0/include/). The path
doesn't look standard to me, but every distribution and installation is
different so there isn't much I can say about it.
- cpp having issues generating the .sql files (postgis.sql) for example.
The full command executed to generate postgis.sql from postgis/postgis is:
/usr/bin/cpp -traditional-cpp -w -P -I../libpgcommon postgis.sql.in | grep
-v '^#' | \
/usr/bin/perl -lpe
"s'MODULE_PATHNAME'\$libdir/postgis-3'g;s'@extschema@\.''g" > postgis.sql
Can you check manually (`make postgis.sql` in the postgis/ directory) to
see what command is being executed in that machine?
I think there isn't anything in that cpp call that depends on the
architecture. Is there a chance that the issue is in the machine setup and
not in the project code itself?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4752#comment:1>
