[postgis-tickets] [PostGIS] #4759: PostGIS Workshop page is broken
trac at osgeo.org
Sat Sep 26 10:15:34 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Website Management, Bots
Component: management | Version: master
Resolution: | Keywords:
Comment (by robe):
ssh robe at postgis.net
cd /var/www
#edit postgis_workshop_update.sh #uncomment out the exit
sh postgis_workshop_update.sh
Yields error
Running Sphinx v3.2.1
building [mo]: targets for 0 po files that are out of date
building [html]: targets for 38 source files that are out of date
updating environment: [new config] 38 added, 0 changed, 0 removed
reading sources... [100%] welcome
/var/www/postgis-workshops/postgis-intro/sources/en/joins.rst:263:
WARNING: Footnote [#] is not referenced.
/var/www/postgis-workshops/postgis-intro/sources/en/loading_data.rst:70:
WARNING: Unexpected indentation.
/var/www/postgis-workshops/postgis-intro/sources/en/loading_data.rst:66:
WARNING: Inline literal start-string without end-string.
/var/www/postgis-workshops/postgis-intro/sources/en/loading_data.rst:72:
WARNING: Block quote ends without a blank line; unexpected unindent.
WARNING: Inline interpreted text or phrase reference start-string without
end-string.
/var/www/postgis-workshops/postgis-intro/sources/en/loading_data.rst:162:
looking for now-outdated files... none found
pickling environment... done
checking consistency... done
preparing documents... done
writing output... [ 2%] 3d
Theme error:
An error happened in rendering the page 3d.
Reason: TemplateNotFound('sphinxdoc/layout.html')
make: *** [Makefile:31: html] Error 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4759#comment:1>
