[postgis-tickets] [PostGIS] #4890: ST_Transform large slow down from upgrade to 3.1.1 from 2.4
PostGIS trac at osgeo.org
Sun Apr 18 14:02:41 PDT 2021
  Reporter:  SAbernethy  |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  blocker     |  Milestone:  PostGIS 3.1.2
 Component:  postgis     |    Version:  3.1.x
Resolution:              |   Keywords:
Comment (by mboeringa):
 Paul, does this also affect casts to geography of WGS1984, SRID 4326
 stored data?
 I am wondering, because I also seem to be hit this massive slow down, in a
 similar - in my case multi-threaded - processing workflow doing millions
 of separate updates.
 The code includes, as just one of many things, a calculation of geodesic
 area:
 ST_Area(<GEOMETRY_COLUMN_IN_4236>::geography,True)
 Would this possibly also be affected by the same issue, even though not
 explicitely calling ST_Transform?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4890#comment:6>
