[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta3-3-g705d3a3c7
git at osgeo.org
git at osgeo.org
Thu Dec 9 21:44:18 PST 2021
the project "PostGIS".
via 705d3a3c78f595da0a26b6033ef29d9ae502f719 (commit)
from 0b32bdd142b43124edef7736ec1a676046c613a3 (commit)
revisions in full, below.
commit 705d3a3c78f595da0a26b6033ef29d9ae502f719
Author: Regina Obe <lr at pcorp.us>
Date: Fri Dec 10 00:44:12 2021 -0500
Add note that ST_PixelAsCentroid(s) is now implemented in C so should be faster
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 9a0710157..9a4710cac 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1503,6 +1503,7 @@ digits | encode | st_astext
<para>Removes a point from a LineString, given its index (0-based).
Useful for turning a closed line (ring) into an open linestring.
</para>
+ <para>Enhanced: 3.2.0</para>
<para>Availability: 1.1.0</para>
<para>&Z_support;</para>
</refsection>
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 7018a7cba..96715fcb9 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -4741,6 +4741,7 @@ SELECT x, y, val, ST_AsText(geom) FROM (SELECT (ST_PixelAsPoints(rast, 1)).* FRO
<refsection>
<title>Description</title>
<para>Returns the centroid (point geometry) of the area represented by a pixel.</para>
+ <para>Enhanced: 3.2.0 Faster now implemented in C.</para>
<para>Availability: 2.1.0</para>
</refsection>
@@ -4801,8 +4802,9 @@ SELECT ST_AsText(ST_PixelAsCentroid(rast, 1, 1)) FROM dummy_rast WHERE rid = 1;
</para>
</note>
- <para>Availability: 2.1.0</para>
<para>Changed: 2.1.1 Changed behavior of exclude_nodata_value.</para>
+ <para>Availability: 2.1.0</para>
</refsection>
<refsection>
Summary of changes:
doc/reference_editor.xml | 1 +
doc/reference_raster.xml | 4 +++-
2 files changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
