[postgis-tickets] [PostGIS] #5032: ST_EstimatedExtent gives bogus results on combined gist indexes
PostGIS trac at osgeo.org
Fri Dec 10 12:32:23 PST 2021
  Reporter:  Björn Harrtell  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Description changed by Björn Harrtell:
Old description:
> Reproduction:
> drop table test;
> with vals(k, geom) as (values (1, 'POINT(1 1)'::geometry), (2, 'POINT(1
> 2)'::geometry))
> select * into table test from vals;
> analyze test;
> select st_estimatedextent('test', 'geom');
> -- BOX(1 0.995000004768372,1 2.005000114440918)
> create index test_geom_idx on test using gist (geom);
> -- BOX(1 1,1 2)
> drop index test_geom_idx;
> create index test_k_geom_idx on test using gist (k, geom);
> -- BOX(1.401298464324817E-45 1,2.802596928649634E-45 1)
> This is on:
> POSTGIS="3.2.0dev 3.2.0beta2-11-g27f44ecf6" [EXTENSION] PGSQL="120"
> GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.12" LIBJSON="0.15"
> (core procs from "3.2.0dev 3.2.0beta2-3-geda70258f" need upgrade)
> But I think it's an old bug.
New description:
 Reproduction:
 drop table if exists test;
 2)'::geometry))
 analyze test;
 -- BOX(1 1,1 2)
 This is on:
 GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.12" LIBJSON="0.15" (core
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5032#comment:1>
