[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-7-ge65292b7b
Wed Dec 22 10:26:07 PST 2021
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  e65292b7b9384ae4039a2920fdde7e5a07baf70b (commit)
       via  89949433f40e6586c8fa2568f8d26ccba268fd16 (commit)
       via  034dae8055786d7d968930bde9afacc3e383a209 (commit)
      from  7020472ed0a763fa22ac2309a151f92b79d9a436 (commit)
revisions in full, below.
commit e65292b7b9384ae4039a2920fdde7e5a07baf70b
Author: Sandro Santilli <strk at kbt.io>
Date:   Sun Dec 19 23:29:53 2021 +0100
    Update docs about ST_AsKML
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index f58c3d37b..1c55f2bb7 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -979,7 +979,7 @@ SELECT ST_AsGML(3, ST_GeomFromEWKT('POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0
 	  <refnamediv>
 		<refname>ST_AsKML</refname>
-		<refpurpose>Return the geometry as a KML element. Several variants. Default version=2, default maxdecimaldigits=15</refpurpose>
+		<refpurpose>Return the geometry as a KML element.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -1005,9 +1005,9 @@ SELECT ST_AsGML(3, ST_GeomFromEWKT('POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0
 	  <refsection>
 		<title>Description</title>
-		<para>Return the geometry as a Keyhole Markup Language (KML) element. There are several variants of this function.
-			maximum number of decimal places used in
-			output (defaults to 15), version default to 2 and default namespace is no prefix.</para>
+		<para>Return the geometry as a Keyhole Markup Language (KML) element.
+			default maximum number of decimal places is 15,
+			default namespace is no prefix.</para>
       <warning>
 			<para>Using the <parameter>maxdecimaldigits</parameter> parameter
@@ -1017,9 +1017,6 @@ SELECT ST_AsGML(3, ST_GeomFromEWKT('POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0
             </para>
       </warning>
-		<para>Version 1: ST_AsKML(geom_or_geog, maxdecimaldigits) / version=2 / maxdecimaldigits=15 </para>
-		<para>Version 2: ST_AsKML(version, geom_or_geog, maxdecimaldigits, nprefix) maxdecimaldigits=15 / nprefix=NULL </para>
 		<note>
 		  <para>Requires PostGIS be compiled with Proj support.  Use <xref linkend="PostGIS_Full_Version" /> to confirm you have proj support compiled in.</para>
 		</note>
@@ -1028,10 +1025,10 @@ SELECT ST_AsGML(3, ST_GeomFromEWKT('POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0
 		  <para>Availability: 1.2.2 - later variants that include version param came in 1.3.2</para>
 		</note>
 		<note>
-		  <para>Enhanced: 2.0.0 - Add prefix namespace. Default is no prefix</para>
+		  <para>Enhanced: 2.0.0 - Add prefix namespace, use default and named args</para>
 		</note>
 		<note>
-		  <para>Changed: 2.0.0 - uses default args and supports named args</para>
+		  <para>Changed: 3.0.0 - Removed the "versioned" variant signature</para>
 		</note>
 		<note>
commit 89949433f40e6586c8fa2568f8d26ccba268fd16
Date:   Sun Dec 19 22:48:45 2021 +0100
    Replace ST_AsKML deprecated signatures drop with Replaces comments
    Includes regression test
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 7d7b6da5f..90ca01723 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -452,6 +452,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(text)
 -- AsKML(geography,precision)
 -- Changed: 2.0.0 to use default args and named args
+-- Replaces ST_AsKML(geography, int4) deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsKML(geog geography, maxdecimaldigits int4 DEFAULT 15, nprefix text DEFAULT '')
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_kml'
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 0beca01aa..5c8ef4c2b 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4789,6 +4789,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(version int4, geom geometry, maxdecimaldigit
 -- Availability: 1.2.2
 -- Changed: 2.0.0 to use default args and allow named args
+-- Replaces ST_AsKML(geometry, int4) deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits int4 DEFAULT 15, nprefix TEXT default '')
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asKML'
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index a7b929ffd..bab8d358e 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -197,7 +197,6 @@ DROP FUNCTION IF EXISTS ST_Distance(geography, geography, float8, boolean);
 DROP FUNCTION IF EXISTS ST_Buffer(geometry, float8, cstring);
 DROP FUNCTION IF EXISTS ST_IsValidDetail(geometry);
 DROP FUNCTION IF EXISTS ST_AsKML(int4, geometry, int4, text);
-DROP FUNCTION IF EXISTS ST_AsKML(geometry, int4);
 DROP FUNCTION IF EXISTS ST_AsGeoJson(int4, geometry, int4, int4);
 DROP FUNCTION IF EXISTS _ST_AsGeoJson(int4, geometry, int4, int4);
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 3ba6956bf..ea84c524f 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -195,12 +195,6 @@ SELECT _postgis_drop_function_if_needed
--- FUNCTION st_askml changed to add defaults in 3.0 / r17357
--- These signatures were superseeded
-DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- Does not conflict
-DROP FUNCTION IF EXISTS st_askml(geography, integer); -- Does not conflict
 -- FUNCTION st_buffer changed to add defaults in 3.0
 -- This signature was superseeded
 DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not conflict
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 231f3c972..4343f448a 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -3,6 +3,7 @@ DROP VIEW IF EXISTS upgrade_view_test_unaryunion;
 DROP VIEW IF EXISTS upgrade_view_test_subdivide;
 DROP VIEW IF EXISTS upgrade_view_test_union;
 DROP VIEW IF EXISTS upgrade_view_test_force_dims;
+DROP VIEW IF EXISTS upgrade_view_test_askml;
 DROP TABLE upgrade_test;
 -- Drop functions deprecated on upgrade
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 07c54dda1..e5e541888 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -58,3 +58,11 @@ SELECT
 	ST_Force3DM(g1) as geometry_force3dm,
 	ST_Force4D(g1) as geometry_force4d
 FROM upgrade_test;
+-- Add view using ST_AsKML function
+-- NOTE: 2.0.0 changed them to add default params
+CREATE VIEW upgrade_view_test_askml AS
+SELECT
+	ST_AsKML(g1) as geometry_askml,
+	ST_AsKML(g2) as geography_askml
+FROM upgrade_test;
commit 034dae8055786d7d968930bde9afacc3e383a209
Date:   Sun Dec 19 19:38:19 2021 +0100
    Allow upgrades from <3.1 when using ST_Force{3D,3DM,3DZ,4D} in views
index 003d8b60f..0beca01aa 100644
@@ -1382,6 +1382,7 @@ CREATE OR REPLACE FUNCTION ST_Force2D(geometry)
 -- Availability: 2.1.0
 -- Changed: 3.1.0 - add zvalue=0.0 parameter
+-- Replaces ST_Force3DZ(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3DZ(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dz'
@@ -1390,6 +1391,7 @@ CREATE OR REPLACE FUNCTION ST_Force3DZ(geom geometry, zvalue float8 default 0.0)
+-- Replaces ST_Force3D(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3D(geom geometry, zvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'SELECT @extschema at .ST_Force3DZ($1, $2)'
@@ -1398,6 +1400,7 @@ CREATE OR REPLACE FUNCTION ST_Force3D(geom geometry, zvalue float8 default 0.0)
 -- Changed: 3.1.0 - add mvalue=0.0 parameter
+-- Replaces ST_Force3DM(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force3DM(geom geometry, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dm'
@@ -1406,6 +1409,7 @@ CREATE OR REPLACE FUNCTION ST_Force3DM(geom geometry, mvalue float8 default 0.0)
 -- Changed: 3.1.0 - add zvalue=0.0 and mvalue=0.0 parameters
+-- Replaces ST_Force4D(geometry) deprecated in 3.1.0
 CREATE OR REPLACE FUNCTION ST_Force4D(geom geometry, zvalue float8 default 0.0, mvalue float8 default 0.0)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_4d'
index fd104bc8e..3ba6956bf 100644
@@ -194,13 +194,6 @@ SELECT _postgis_drop_function_if_needed
     'zoom integer, x integer, y integer, bounds geometry DEFAULT ''0102000020110F00000200000052107C45F81B73C152107C45F81B73C152107C45F81B734152107C45F81B7341''::geometry'
--- FUNCTION ST_Force3D, ST_Force3DZ, ST_Force3DM, ST_Force4DZ changed to add defaults in 3.1
-DROP FUNCTION IF EXISTS ST_Force3D(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force3DZ(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force3DM(geometry); -- Does not conflict
-DROP FUNCTION IF EXISTS ST_Force4D(geometry); -- Does not conflict
index 775e0239d..231f3c972 100644
@@ -2,6 +2,7 @@ DROP VIEW IF EXISTS upgrade_view_test_overlay;
+DROP VIEW IF EXISTS upgrade_view_test_force_dims;
index de661643d..07c54dda1 100644
@@ -47,3 +47,14 @@ CREATE VIEW upgrade_view_test_subdivide AS
 SELECT
 	ST_Subdivide(g1, 256) as geometry_subdivide
 FROM upgrade_test;
+-- Add view using ST_ForceX function
+-- NOTE: 3.1.0 changed them from taking only geometry
+--       to also take optional zvalue/mvalue params
+CREATE VIEW upgrade_view_test_force_dims AS
+SELECT
+	ST_Force3D(g1) as geometry_force3d,
+	ST_Force3DZ(g1) as geometry_force3dz,
+	ST_Force3DM(g1) as geometry_force3dm,
+	ST_Force4D(g1) as geometry_force4d
+FROM upgrade_test;
Summary of changes:
 doc/reference_output.xml              | 15 ++++++---------
 postgis/geography.sql.in              |  1 +
 postgis/postgis.sql.in                |  5 +++++
 postgis/postgis_after_upgrade.sql     |  1 -
 postgis/postgis_before_upgrade.sql    | 13 -------------
 regress/hooks/hook-after-upgrade.sql  |  2 ++
 regress/hooks/hook-before-upgrade.sql | 19 +++++++++++++++++++
 7 files changed, 33 insertions(+), 23 deletions(-)
hooks/post-receive
