[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-13-g5f0640152
Sun Dec 26 13:59:49 PST 2021
the project "PostGIS".
       via  5f0640152cecc35712c7818011a8f4e0c59feab7 (commit)
       via  f52d3daa6b5bdafe67f1fa161ee025316de9013f (commit)
      from  96906a919d3cdeac3125ed2cdb224cb247b2884a (commit)
revisions in full, below.
commit 5f0640152cecc35712c7818011a8f4e0c59feab7
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 26 16:57:50 2021 -0500
    Add ST_3DConvexHull. Closes #5037 Closes
    https://git.osgeo.org/gitea/postgis/postgis/pulls/62
diff --git a/NEWS b/NEWS
index d05ba5f62..c710b74de 100644
--- a/NEWS
+++ b/NEWS
@@ -5,7 +5,7 @@ PostGIS 3.3.0dev
  * Enhancements *
+  - #5037, add convexhull 3D (Loïc Bartoletti)
 PostGIS 3.2.0 (Olivier Courtin Edition)
 2021/12/17
commit f52d3daa6b5bdafe67f1fa161ee025316de9013f
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Mon Nov 15 21:54:02 2021 +0100
    add convexhull3D
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index b4a0afdb8..a917e4189 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -1105,5 +1105,39 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
 	</refentry>
+	<refentry id="ST_3DConvexHull">
+	  <refnamediv>
+		<refname>ST_3DConvexHull</refname>
+		<refpurpose>Computes the 3D convex hull of a geometry.</refpurpose>
+	  </refnamediv>
+	  <refsynopsisdiv>
+		<funcsynopsis>
+		  <funcprototype>
+			<funcdef>geometry<function>ST_3DConvexHull</function></funcdef>
+			<paramdef><type>geometry</type> <parameter>geom1</parameter></paramdef>
+		  </funcprototype>
+		</funcsynopsis>
+	  </refsynopsisdiv>
+	  <refsection>
+		<title>Description</title>
+		<para>Availability: 3.3.0</para>
+		<para>&sfcgal_required;</para>
+		<para>&Z_support;</para>
+		<para>&P_support;</para>
+		<para>&T_support;</para>
+	  </refsection>
+	  <refsection>
+	      <title>Example</title>
+          <programlisting>SELECT ST_AsText(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)')) As 3DHull;</programlisting>
+          <para>ST_AsText output</para>
+          <screen>POLYHEDRALSURFACE Z (((1 5 3,9 5 3,0 0 5,1 5 3)),((1 5 3,0 0 5,5 7 6,1 5 3)),((5 7 6,5 7 5,1 5 3,5 7 6)),((0 0 5,6 3 5,5 7 6,0 0 5)),((6 3 5,9 5 3,5 7 6,6 3 5)),((0 0 5,9 5 3,6 3 5,0 0 5)),((9 5 3,5 7 5,5 7 6,9 5 3)),((1 5 3,5 7 5,9 5 3,1 5 3)))</screen>
+	  </refsection>
+	</refentry>
 </sect1>
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 3e3729bc5..23cfc783b 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -117,6 +117,7 @@ Datum sfcgal_minkowski_sum(PG_FUNCTION_ARGS);
 Datum sfcgal_make_solid(PG_FUNCTION_ARGS);
 Datum sfcgal_is_solid(PG_FUNCTION_ARGS);
 Datum postgis_sfcgal_noop(PG_FUNCTION_ARGS);
+Datum sfcgal_convexhull3D(PG_FUNCTION_ARGS);
 GSERIALIZED *geometry_serialize(LWGEOM *lwgeom);
 char *text_to_cstring(const text *textptr);
@@ -617,3 +618,27 @@ Datum postgis_sfcgal_noop(PG_FUNCTION_ARGS)
 	PG_FREE_IF_COPY(input, 0);
 	PG_RETURN_POINTER(output);
+PG_FUNCTION_INFO_V1(sfcgal_convexhull3D);
+	GSERIALIZED *input, *output;
+	sfcgal_geometry_t *geom;
+	sfcgal_geometry_t *result;
+	srid_t srid;
+	sfcgal_postgis_init();
+	input = PG_GETARG_GSERIALIZED_P(0);
+	srid = gserialized_get_srid(input);
+	geom = POSTGIS2SFCGALGeometry(input);
+	PG_FREE_IF_COPY(input, 0);
+	result = sfcgal_geometry_convexhull_3d(geom);
+	sfcgal_geometry_delete(geom);
+	output = SFCGALGeometry2POSTGIS(result, 0, srid);
+	sfcgal_geometry_delete(result);
+	PG_RETURN_POINTER(output);
diff --git a/sfcgal/lwgeom_sfcgal.h b/sfcgal/lwgeom_sfcgal.h
index e3ffec2af..7340cf10e 100644
--- a/sfcgal/lwgeom_sfcgal.h
+++ b/sfcgal/lwgeom_sfcgal.h
@@ -49,6 +49,7 @@ Datum sfcgal_distance(PG_FUNCTION_ARGS);
 Datum sfcgal_distance3D(PG_FUNCTION_ARGS);
 /* Initialize sfcgal with PostGIS error handlers */
 void sfcgal_postgis_init(void);
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 6853ec4d3..a337793b6 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -31,3 +31,4 @@ SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYG
 SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
 SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
 SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
+SELECT 'ST_3DConvexHull', ST_AsText(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'));
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index a67ed5660..347a8e749 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -11,3 +11,4 @@ ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
 ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
 ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
 postgis_sfcgal_noop|33
+ST_3DConvexHull|POLYHEDRALSURFACE Z (((1 5 3,9 5 3,0 0 5,1 5 3)),((1 5 3,0 0 5,5 7 6,1 5 3)),((5 7 6,5 7 5,1 5 3,5 7 6)),((0 0 5,6 3 5,5 7 6,0 0 5)),((6 3 5,9 5 3,5 7 6,6 3 5)),((0 0 5,9 5 3,6 3 5,0 0 5)),((9 5 3,5 7 5,5 7 6,9 5 3)),((1 5 3,5 7 5,9 5 3,1 5 3)))
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 5d8a629f3..d5af9de3d 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -147,3 +147,11 @@ CREATE OR REPLACE FUNCTION ST_ConstrainedDelaunayTriangles(geometry)
        LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
        COST 100;
 COMMIT;
+-- Availability: 3.3.0
+CREATE OR REPLACE FUNCTION ST_3DConvexHull(geometry)
+       RETURNS geometry
+       AS 'MODULE_PATHNAME', 'sfcgal_convexhull3D'
+       LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+       COST 100;
+COMMIT;
Summary of changes:
 NEWS                                   |  2 +-
 doc/reference_sfcgal.xml               | 34 ++++++++++++++++++++++++++++++++++
 sfcgal/lwgeom_sfcgal.c                 | 25 +++++++++++++++++++++++++
 sfcgal/lwgeom_sfcgal.h                 |  1 +
 sfcgal/regress/regress_sfcgal.sql      |  1 +
 sfcgal/regress/regress_sfcgal_expected |  1 +
 sfcgal/sfcgal.sql.in                   |  8 ++++++++
 7 files changed, 71 insertions(+), 1 deletion(-)
hooks/post-receive
