[postgis-tickets] [PostGIS] #4837: GEOS 3.10dev failure on make valid - winnie
trac at osgeo.org
Tue Feb 2 19:02:38 PST 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
Just noticed this failing on Winnie. She's running with GEOS 3.10dev.
PostGIS 3.1 branch which runs against GEOS 3.9 branch is fine, so assume
this is just a change in 3.10 dev
Test: test_geos_makevalid ...FAILED
1. cu_geos.c:157 - ASSERT_STRING_EQUAL
* Expected: POLYGON((92127.546 463452.075,92117.173
463439.755,92133.675 463425.942,92122.136 463412.826,92092.377
463437.77,92114.014 463463.469,92115.512 463462.207,92115.51207431706
463462.2069374289,92127.546 463452.075))
* Obtained: POLYGON((92115.512 463462.207,92115.51207431706
463462.2069374289,92127.546 463452.075,92117.173 463439.755,92133.675
463425.942,92122.136 463412.826,92092.377 463437.77,92114.014
463463.469,92115.512 463462.207))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4837>
