[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-56-g52f9425
git at osgeo.org
git at osgeo.org
Wed Feb 3 22:23:06 PST 2021
the project "PostGIS".
via 52f942583b5b9c975799bf8eefadc756a5f56215 (commit)
from e7973308de3df4515c6456880e162040e285ee2b (commit)
revisions in full, below.
commit 52f942583b5b9c975799bf8eefadc756a5f56215
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Feb 3 22:22:58 2021 -0800
Dcc Reference editing
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 482d85c..1590373 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -66,10 +66,6 @@ Returns a geometry covering all points within a given distance from a geometry.
fits the bounding box of the geography object (favoring UTM, Lambert Azimuthal Equal Area (LAEA) north/south pole, and falling back on mercator in worst case scenario) and then buffers in that planar spatial ref and retransforms back to WGS84 geography.</para></note>
<warning><para>
For geography this may not behave as expected if object is sufficiently large that it falls between two UTM zones or crosses the dateline</para></warning>
- <para>Enhanced: 2.5.0 - ST_Buffer geometry support was enhanced to allow for side buffering specification <code>side=both|left|right</code>.</para>
- <para>Availability: 1.5 - ST_Buffer was enhanced to support different endcaps and join types. These are useful for example to convert road linestrings
- into polygon roads with flat or square edges instead of rounded edges. Thin wrapper for geography was added.
- </para>
<para>
The optional third parameter (currently only applies to geometry) can either specify number of segments used to approximate a quarter circle (integer case, defaults to 8) or a list of blank-separated key=value pairs (string case) to tweak operations as follows:
<itemizedlist>
@@ -94,14 +90,21 @@ This is only really relevant to LINESTRING geometry and does not affect POINT or
<para>Units of radius are measured in units of the spatial reference system.</para>
<para>The inputs can be POINTS, MULTIPOINTS, LINESTRINGS, MULTILINESTRINGS, POLYGONS, MULTIPOLYGONS, and GeometryCollections.</para>
- <note><para>This function ignores the third dimension (z) and will always give a 2-d buffer even when presented with a 3d-geometry.</para></note>
+ <note><para>Creating a buffer to do a radius search is inefficient. Use <xref linkend="ST_DWithin" /> instead.</para></note>
+ <note><para>This function ignores the Z dimension.
+It always gives a 2D result even when used on a 3D geometry.</para></note>
+ <para>Enhanced: 2.5.0 - ST_Buffer geometry support was enhanced to allow for side buffering specification <code>side=both|left|right</code>.</para>
+ <para>Availability: 1.5 - ST_Buffer was enhanced to support different endcaps and join types. These are useful for example to convert road linestrings
+ into polygon roads with flat or square edges instead of rounded edges. Thin wrapper for geography was added.
+ </para>
<para>Performed by the GEOS module.</para>
<para>&sfs_compliant; s2.1.1.3</para>
<para>&sqlmm_compliant; SQL-MM 3: 5.1.17</para>
- <note><para>People often make the mistake of using this function to try to do radius searches. Creating a
- buffer to a radius search is slow and pointless. Use <xref linkend="ST_DWithin" /> instead.</para></note>
</refsection>
<refsection>
@@ -1550,13 +1553,11 @@ and retains the same direction. For a negative distance it is on the right
side and in the opposite direction.
</para>
<para>
+Units of distance are measured in units of the spatial reference system.
+ </para>
+ <para>
Note that output may be a MULTILINESTRING or EMPTY for some jigsaw-shaped input geometries.
</para>
- <para>Performed by the GEOS module.</para>
- <para>Availability: 2.0</para>
- <para>Enhanced: 2.5 - added support for GEOMETRYCOLLECTION and MULTILINESTRING</para>
<para>
The optional third parameter allows specifying a list of blank-separated
key=value pairs to tweak operations as follows:
@@ -1573,15 +1574,12 @@ key=value pairs to tweak operations as follows:
</itemizedlist>
</para>
- <para>
-Units of distance are measured in units of the spatial reference system.
- </para>
+ <para>Performed by the GEOS module.</para>
+ <para>Availability: 2.0</para>
+ <para>Enhanced: 2.5 - added support for GEOMETRYCOLLECTION and MULTILINESTRING</para>
- <note><para>
-This function ignores the third dimension (z) and will always give a
-2-d result even when presented with a 3d-geometry.</para></note>
</refsection>
Summary of changes:
doc/reference_processing.xml | 38 ++++++++++++++++++--------------------
1 file changed, 18 insertions(+), 20 deletions(-)
hooks/post-receive
