[postgis-tickets] [PostGIS] #4841: find_topology
trac at osgeo.org
Thu Feb 4 08:18:44 PST 2021
Reporter: strk | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by robe):
Seems fine and fine to return a topology record.
Only thing that might be an issue is if you delete a column on the
topology table (which I assume would be rare), you'd have to drop this
function first. I forget if adding a column has similar affect. Like
with table types you need to do a CASCADE for dependent objects.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4841#comment:2>
