[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-57-g366d3b7
git at osgeo.org
git at osgeo.org
Thu Feb 4 10:10:10 PST 2021
the project "PostGIS".
via 366d3b7a036b6c8cec01242a655af4e365335460 (commit)
from 52f942583b5b9c975799bf8eefadc756a5f56215 (commit)
revisions in full, below.
commit 366d3b7a036b6c8cec01242a655af4e365335460
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Feb 4 10:09:59 2021 -0800
Improve doc ST_Buffer section
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 1590373..37612b7 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -15,7 +15,7 @@
<refname>ST_Buffer</refname>
<refpurpose>
-Returns a geometry covering all points within a given distance from a geometry.
+Computes a geometry covering all points within a given distance from a geometry.
</refpurpose>
</refnamediv>
@@ -56,42 +56,56 @@ Returns a geometry covering all points within a given distance from a geometry.
<refsection>
<title>Description</title>
- <para>Returns a geometry/geography that represents all points whose distance
- from this Geometry/geography is less than or equal to distance. </para>
- <para>Geometry: Calculations
- are in the Spatial Reference System of the geometry. Introduced in 1.5 support for
- different end cap and mitre settings to control shape.</para>
- <note><para>Negative radii: For polygons, a negative radius can be used, which will shrink the polygon rather than expanding it.</para></note>
- <note><para>Geography: For geography this is really a thin wrapper around the geometry implementation. It first determines the best SRID that
- fits the bounding box of the geography object (favoring UTM, Lambert Azimuthal Equal Area (LAEA) north/south pole, and falling back on mercator in worst case scenario) and then buffers in that planar spatial ref and retransforms back to WGS84 geography.</para></note>
- <warning><para>
- For geography this may not behave as expected if object is sufficiently large that it falls between two UTM zones or crosses the dateline</para></warning>
- <para>
-The optional third parameter (currently only applies to geometry) can either specify number of segments used to approximate a quarter circle (integer case, defaults to 8) or a list of blank-separated key=value pairs (string case) to tweak operations as follows:
+ <para>Computes a a POLYGON or MULTIPOLYGON that represents all points whose distance
+ from a geometry/geography is less than or equal to a given distance.
+ A negative distance shrinks the geometry rather than expanding it.
+ A negative distance may shrink a polygon completely, in which case POLYGON EMPTY is returned.
+ For points and lines negative distances always return empty results.
+ </para>
+ <para>For geometry, the distance is specified in the units of the
+ Spatial Reference System of the geometry.
+ For geography, the distance is specified in meters.</para>
+ <para>The optional third parameter controls the buffer accuracy and style.
+The accuracy of circular arcs in the buffer is specified as the number of line segments
+used to approximate a quarter circle (default is 8).
+The buffer style can be specifed by
+providing a list of blank-separated key=value pairs as follows:
<itemizedlist>
<listitem>
-<para>'quad_segs=#' : number of segments used to approximate a quarter circle (defaults to 8).</para>
+<para>'quad_segs=#' : number of line segments used to approximate a quarter circle (default is 8).</para>
</listitem>
<listitem>
-<para>'endcap=round|flat|square' : endcap style (defaults to "round"). 'butt' is also accepted as a synonym for 'flat'.</para>
+<para>'endcap=round|flat|square' : endcap style (defaults to "round"). 'butt' is accepted as a synonym for 'flat'.</para>
</listitem>
<listitem>
-<para>'join=round|mitre|bevel' : join style (defaults to "round"). 'miter' is also accepted as a synonym for 'mitre'.</para>
+<para>'join=round|mitre|bevel' : join style (defaults to "round"). 'miter' is accepted as a synonym for 'mitre'.</para>
</listitem>
<listitem>
-<para>'mitre_limit=#.#' : mitre ratio limit (only affects mitered join style). 'miter_limit' is also accepted as a synonym for 'mitre_limit'.</para>
+<para>'mitre_limit=#.#' : mitre ratio limit (only affects mitered join style). 'miter_limit' is accepted as a synonym for 'mitre_limit'.</para>
</listitem>
<listitem>
<para>'side=both|left|right' : 'left' or 'right' performs a single-sided buffer on the geometry, with the buffered side relative to the direction of the line.
-This is only really relevant to LINESTRING geometry and does not affect POINT or POLYGON geometries. By default end caps are square.</para>
+This is only applicable to LINESTRING geometry and does not affect POINT or POLYGON geometries. By default end caps are square.</para>
</listitem>
</itemizedlist>
</para>
- <para>Units of radius are measured in units of the spatial reference system.</para>
- <para>The inputs can be POINTS, MULTIPOINTS, LINESTRINGS, MULTILINESTRINGS, POLYGONS, MULTIPOLYGONS, and GeometryCollections.</para>
+ <note><para>For geography, this is a wrapper around the geometry implementation.
+ It determines a planar spatial reference system that best fits the bounding box of the geography object
+ (trying UTM, Lambert Azimuthal Equal Area (LAEA) North/South pole, and finally Mercator ).
+ The buffer is computed in the planar space, and then transformed back to WGS84.
+ This may not produce the desired behaviour if the input object is much larger than a UTM zone or crosses the dateline
+ </para></note>
+ <note><para>Buffer output is always a valid polygonal geometry.
+ Buffer can handle invalid inputs,
+ so buffering by distance 0 is sometimes used as a way of repairing invalid polygons.
+ <xref linkend="ST_MakeValid" /> can also be used for this purpose.
+ </para></note>
- <note><para>Creating a buffer to do a radius search is inefficient. Use <xref linkend="ST_DWithin" /> instead.</para></note>
+ <note><para>Buffering is sometimes used to perform a within-distance search.
+ For this use case it is more efficient to use <xref linkend="ST_DWithin" />.</para></note>
<note><para>This function ignores the Z dimension.
It always gives a 2D result even when used on a 3D geometry.</para></note>
@@ -361,7 +375,7 @@ POLYGON((236057.59057465 900908.759918696,236028.301252769 900838.049240578,235
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_Collect" />, <xref linkend="ST_DWithin" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_Transform" />, <xref linkend="ST_Union" /></para>
+ <para><xref linkend="ST_Collect" />, <xref linkend="ST_DWithin" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_Transform" />, <xref linkend="ST_Union" />, <xref linkend="ST_MakeValid" /></para>
</refsection>
</refentry>
Summary of changes:
doc/reference_processing.xml | 58 +++++++++++++++++++++++++++-----------------
1 file changed, 36 insertions(+), 22 deletions(-)
hooks/post-receive
