[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-62-ga2a5961
git at osgeo.org
git at osgeo.org
Mon Feb 8 14:58:51 PST 2021
the project "PostGIS".
via a2a5961828613c10796f72753cf70980d6b414a5 (commit)
via 04d167389116720f2889dcba2721f68ef979daef (commit)
from 20f4d1b9165c00c92e8682894961dc4522c354b9 (commit)
revisions in full, below.
commit a2a5961828613c10796f72753cf70980d6b414a5
Merge: 04d1673 20f4d1b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Feb 8 14:58:46 2021 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 04d167389116720f2889dcba2721f68ef979daef
Date: Mon Feb 8 14:58:29 2021 -0800
Only do axis flips on CRS that have a "Lat" as the first column. Otherwise just take the EPSG database order. References #4842, #4748
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index ed7d601..51d9c2d 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -277,7 +277,7 @@ proj_crs_is_swapped(const PJ *pj_crs)
const char *out_name, *out_abbrev, *out_direction;
double out_unit_conv_factor;
const char *out_unit_name, *out_unit_auth_name, *out_unit_code;
- /* Read only first axis, see if it is degrees / north */
+ /* Read only first axis */
proj_cs_get_axis_info(NULL,
pj_cs,
0,
@@ -288,13 +288,10 @@ proj_crs_is_swapped(const PJ *pj_crs)
&out_unit_name,
&out_unit_auth_name,
&out_unit_code);
- if (strcasecmp(out_abbrev, "E") == 0)
- rv = LW_FALSE;
- else if (strcasecmp(out_abbrev, "Lat") == 0)
- rv = LW_TRUE;
- else if (strcasecmp(out_direction, "north") == 0)
- rv = LW_TRUE;
- else if (strcasecmp(out_direction, "south") == 0)
+ /* Only swap Lat/Lon systems */
+ /* Use whatever ordering planar systems default to */
+ if (strcasecmp(out_abbrev, "Lat") == 0)
rv = LW_TRUE;
else
rv = LW_FALSE;
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 6acda49..da3ea27 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1298,7 +1298,9 @@ SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geomet
SELECT '#4689', _ST_DistanceTree('POLYGON ((30 10, 40 40, 20 40, 30 10))'::geography, 'POLYGON((81 6,140 35,-70 18,-51 0,-60 -46,106 -6,81 6))');
+-- Polar Stereographic Axis order issues
SELECT '#4748', ST_AsEWKT(ST_Transform(ST_SetSRID(ST_Point(-36.75, -54.25), 4326), 3031),1);
+SELECT '#4842', ST_AsEWKT(ST_Transform(ST_SetSRID(ST_Point(12.572, 66.081), 4326), 3413),1);
SELECT '#4718',
round(degrees(
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index bc1f71a..181f22f 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -435,6 +435,7 @@ ERROR: BOX2D_construct: args can not be empty points
ERROR: LWGEOM_addpoint: Invalid offset
#4689|0
#4748|SRID=3031;POINT(-2399498.7 3213318.5)
+#4842|SRID=3413;POINT(2218086.2 -1409161.3)
#4718|270.000|90.000
#4727|0
#4796|POLYGON((178632 397744,178738 397769,178745 397741,178749 397742,178752 397727,178748 397726,178759 397684,178699 397669,178694 397691,178646 397680,178632 397744))
Summary of changes:
liblwgeom/lwgeom_transform.c | 13 +++++--------
regress/core/tickets.sql | 2 ++
regress/core/tickets_expected | 1 +
3 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
