[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-66-gb02ff2d
git at osgeo.org
git at osgeo.org
Tue Feb 9 11:57:26 PST 2021
the project "PostGIS".
via b02ff2dd6d4962fb7984102cddf3560ea682ef4c (commit)
via 518ae076a8c6e6239b9f4c4b1808f5b10650bf1b (commit)
from 88b689c8f1d3e72dde2e3ee534d48b514ccf63f3 (commit)
revisions in full, below.
commit b02ff2dd6d4962fb7984102cddf3560ea682ef4c
Merge: 518ae07 88b689c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Feb 9 11:57:16 2021 -0800
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 518ae076a8c6e6239b9f4c4b1808f5b10650bf1b
Date: Tue Feb 9 11:57:04 2021 -0800
If pg_get_release is not present, test for proj_info instead when configuring.
diff --git a/configure.ac b/configure.ac
index 077a615..d0d944b 100644
--- a/configure.ac
+++ b/configure.ac
@@ -905,12 +905,15 @@ AC_SUBST([PROJ_LDFLAGS])
dnl Ensure we can link against libproj
LIBS_SAVE="$LIBS"
LIBS="$PROJ_LDFLAGS"
-AC_CHECK_LIB([proj], [pj_get_release],
- [AC_MSG_ERROR([could not find libproj - you may need to specify the directory of a PROJ installation using --with-projdir])],
+AC_CHECK_LIB([proj], [pj_get_release], [],
+ [AC_CHECK_LIB([proj], [proj_info], [],
+ [AC_MSG_ERROR([could not find libproj - you may need to specify the directory of a PROJ installation using --with-projdir])],
LIBS="$LIBS_SAVE"
dnl ===========================================================================
dnl Detect if json-c installed
Summary of changes:
configure.ac | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
hooks/post-receive
