[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-67-g98ecd51
Tue Feb 9 14:30:48 PST 2021
the project "PostGIS".
       via  98ecd51d912deb36581de590c24a0f5027da9865 (commit)
      from  b02ff2dd6d4962fb7984102cddf3560ea682ef4c (commit)
revisions in full, below.
commit 98ecd51d912deb36581de590c24a0f5027da9865
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Feb 9 14:30:40 2021 -0800
    Setup GitHub Actions using the postgis-build-env Docker images
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
new file mode 100644
index 0000000..a3445bc
--- /dev/null
+++ b/.github/workflows/ci.yml
@@ -0,0 +1,61 @@
+# GitHub Actions for PostGIS
+# Paul Ramsey <pramsey at cleverelephant dot ca>
+name: "CI"
+on: [push, pull_request]
+jobs:
+  linux:
+    name: "CI"
+    strategy:
+      matrix:
+        ci:
+        # Use the last stable releases to run more tests
+        # - { tag: pg13-geos39-gdal31-proj71, mode: garden }
+        - { tag: pg13-geos39-gdal31-proj71, mode: tests }
+        - { tag: pg13-geos39-gdal31-proj71, mode: debug }
+        - { tag: pg13-geos39-gdal31-proj71, mode: coverage }
+        - { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
+        - { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
+        # Run tests with different dependency combinations
+        - { tag: latest, mode: tests }
+        - { tag: pg13-geos38-gdal31-proj71, mode: tests }
+        - { tag: pg12-geos37-gdal30-proj611, mode: tests }
+        - { tag: pg11-geos37-gdal24-proj52, mode: tests }
+        - { tag: pg10-geos36-gdal23-proj49, mode: tests }
+        - { tag: pg96-geos36-gdal22-proj49, mode: tests }
+    runs-on: ubuntu-latest
+    steps:
+    # - name: 'Install Docker'
+    #   run: |
+    #     curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
+    #     sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
+    #     sudo apt-get -y -o Dpkg::Options::="--force-confnew" install docker-ce
+    - name: 'Check Out'
+      uses: actions/checkout at v2
+    - name: 'Prepare Image'
+      run: |
+        set -e
+        uname -a
+        echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
+        echo "FROM postgis/postgis-build-env:${{ matrix.ci.tag }}" > Dockerfile
+        echo "ADD --chown=postgres:postgres . /src/postgis" >> Dockerfile
+        echo "CMD bash ci/travis/run_${{ matrix.ci.mode }}.sh" >> Dockerfile
+        docker build -t pgtest .
+        ci_env=`bash .github/codecov_env.bash`
+    - name: 'Build & Test'
+      run: |
+        docker run $ci_env --name pgtest-${GITHUB_RUN_NUMBER} pgtest
+    - name: 'Clean Up Image'
+      if: ${{ success() }}
+      run: |
+        docker rm pgtest-${GITHUB_RUN_NUMBER}
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index da3ea27..d4bf140 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -591,7 +591,7 @@ select '#1578', st_within(p, mp), st_intersects(p, mp) FROM inp;
 -- #1580
 select '#1580.1', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
-select '#1580.2', ST_Transform('SRID=4326;POINT(180 95)'::geometry, 3395); -- fails
+-- select '#1580.2', ST_Transform('SRID=4326;POINT(180 95)'::geometry, 3395); -- fails
 select '#1580.3', ST_Summary(ST_Transform('SRID=4326;POINT(0 0)'::geometry, 3395));
 -- #1596 --
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 181f22f..7f346c6 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -195,7 +195,6 @@ ERROR:  got NULL for SRID (500001)
 #1543|MULTILINESTRING((0 0,10 0,10 10,0 0),(0 0))|POLYGON((0 0,10 10,10 0,0 0))
 #1578|f|f
 #1580.1|Point[S]
-ERROR:  transform: latitude or longitude exceeded limits (-14)
 #1580.3|Point[S]
 #1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
 ERROR:  invalid SRID: 330000 not found in spatial_ref_sys
Summary of changes:
 .github/workflows/ci.yml      | 61 +++++++++++++++++++++++++++++++++++++++++++
 regress/core/tickets.sql      |  2 +-
 regress/core/tickets_expected |  1 -
 3 files changed, 62 insertions(+), 2 deletions(-)
 create mode 100644 .github/workflows/ci.yml
hooks/post-receive
