[postgis-tickets] [PostGIS] #4844: Wrong st_transform EPSG 3575 North Pole LAEA Europe
trac at osgeo.org
Wed Feb 10 05:54:05 PST 2021
Reporter: richan | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.0.x
Keywords: st_transform 3575 |
Wrong transformation only happens in newer PostGIS versions.
Correct result in PostGIS 2.5.0:
select version();
--PostgreSQL 11.1 on x86_64-pc-mingw64, compiled by gcc.exe (Rev5, Built
by MSYS2 project) 4.9.2, 64-bit
select postgis_full_version();
--POSTGIS="2.5.0 r16836" [EXTENSION] PGSQL="110" GEOS="3.7.0-CAPI-1.11.0
3.7.0" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.4, released
2018/03/19 GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="0.12"
LIBPROTOBUF="1.2.1" RASTER
SELECT
st_asewkt(st_transform(ST_GeomFromEWKT('SRID=3575;POINT(370182.35945313
-2213980.8213281)'),4326));
--SRID=4326;POINT(19.4921714866834 69.7902178774315)
Wrong result in PostGIS 3.0.3:
select version();
--PostgreSQL 13.1 on x86_64-pc-linux-musl, compiled by gcc (Alpine 9.3.0)
9.3.0, 64-bit
--POSTGIS="3.0.3 0" [EXTENSION] PGSQL="130" GEOS="3.8.1-CAPI-1.13.3"
PROJ="7.0.1" LIBXML="2.9.10" LIBJSON="0.14" LIBPROTOBUF="1.3.3"
WAGYU="0.4.3 (Internal)" TOPOLOGY
SELECT
--SRID=4326;POINT(-89.4921714866835 69.7902178774315)
Might be related to: #4842
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4844>
