[postgis-tickets] [PostGIS] #4837: GEOS 3.10dev failure on make valid - winnie
trac at osgeo.org
Thu Feb 11 10:01:06 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
Okay the subdivide case is not a trivial fix with normalize:
I tried changing the query to this in hopes that GEOS 3.9 and GEOS 3.10
would agree:
SELECT 'subdivide', ST_AsText(geomn)
FROM ST_Subdivide(
'POLYGON((0 0,0 10,10 10,10 6,100 5.1, 100 10, 110 10, 110 0, 100
0,100 4.9,10 5,10 0,0 0))'::geometry,
5, 2) AS geom, ST_Normalize(geom) AS geomn
ORDER BY geomn;
-- 3.9.0 answer (haven't upgraded to 3.9.1 yet on my prod)
subdivide POLYGON((0 0,0 10,10 10,10 0,0 0))
subdivide POLYGON((100 4,100 10,110 10,110 4,100 4))
subdivide POLYGON((10 6,100 6,100 4,10 6))
subdivide POLYGON((100 0,100 4,110 4,110 0,100 0))
-- 3.10 (I forget what vintage -- going to upgrade in a bit to see if it
helps)
subdivide POLYGON((100 0,100 10,110 10,110 0,100 0))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4837#comment:2>
