the project "PostGIS".
via b5bf441e96ee86b958fcc3b3d0f265c6b7dd69fb (commit)
from d52fc5c03904a34df6f8695d4e9d674e5d443aab (commit)
revisions in full, below.
commit b5bf441e96ee86b958fcc3b3d0f265c6b7dd69fb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Feb 11 12:49:06 2021 -0800
Support build on PgSQL 14+, Closes #4845
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index a3445bc..a5c2f5e 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -19,7 +19,7 @@ jobs:
- { tag: pg13-geos39-gdal31-proj71, mode: usan_gcc }
- { tag: pg13-clang-geos39-gdal31-proj71, mode: usan_clang }
# Run tests with different dependency combinations
- - { tag: latest, mode: tests }
+ # - { tag: latest, mode: tests }
- { tag: pg13-geos38-gdal31-proj71, mode: tests }
- { tag: pg12-geos37-gdal30-proj611, mode: tests }
- { tag: pg11-geos37-gdal24-proj52, mode: tests }
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index ce53816..8c69e88 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -417,7 +417,11 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
* The comparison expression has to be a pseudo constant,
* (not volatile or dependent on the target index table)
+#if POSTGIS_PGSQL_VERSION >= 140
+ if (!is_pseudo_constant_for_index(req->root, (Node*)expandexpr, req->index))
+#else
if (!is_pseudo_constant_for_index((Node*)expandexpr, req->index))
+#endif
PG_RETURN_POINTER((Node*)NULL);
/* OK, we can make an index expression */
@@ -440,7 +444,11 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
* The comparison expression has to be a pseudoconstant
* (not volatile or dependent on the target index's table)
+ if (!is_pseudo_constant_for_index(req->root, rightarg, req->index))
+#else
if (!is_pseudo_constant_for_index(rightarg, req->index))
+#endif
Summary of changes:
.github/workflows/ci.yml | 2 +-
postgis/gserialized_supportfn.c | 8 ++++++++
2 files changed, 9 insertions(+), 1 deletion(-)
hooks/post-receive
