[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-76-gc050404
git at osgeo.org
git at osgeo.org
Sat Feb 13 21:47:34 PST 2021
the project "PostGIS".
via c05040400c0f166910f6c907e1c342b4ef4b9934 (commit)
from 639b2f9bc23836b5c32cf68c4375a7cca5df6325 (commit)
revisions in full, below.
commit c05040400c0f166910f6c907e1c342b4ef4b9934
Author: Regina Obe <lr at pcorp.us>
Date: Sun Feb 14 00:47:25 2021 -0500
Add costs and parallel safe, take out join_collapse seems to be often faster without it
diff --git a/extras/tiger_geocoder/geocode/geocode_address.sql b/extras/tiger_geocoder/geocode/geocode_address.sql
index 20dc783..f7598b3 100644
--- a/extras/tiger_geocoder/geocode/geocode_address.sql
+++ b/extras/tiger_geocoder/geocode/geocode_address.sql
@@ -432,5 +432,4 @@ BEGIN
END;
LANGUAGE 'plpgsql' STABLE COST 1000 ROWS 50 PARALLEL SAFE;
-ALTER FUNCTION geocode_address(IN norm_addy, IN integer, IN geometry) SET join_collapse_limit='2';
diff --git a/extras/tiger_geocoder/geocode/geocode_location.sql b/extras/tiger_geocoder/geocode/geocode_location.sql
index 8595ca3..c99ee3d 100644
--- a/extras/tiger_geocoder/geocode/geocode_location.sql
+++ b/extras/tiger_geocoder/geocode/geocode_location.sql
@@ -95,4 +95,4 @@ BEGIN
RETURN;
END;
-$_$ LANGUAGE plpgsql STABLE COST 100;
+$_$ LANGUAGE plpgsql STABLE COST 20 ROWS 5 PARALLEL SAFE;
diff --git a/extras/tiger_geocoder/geocode/includes_address.sql b/extras/tiger_geocoder/geocode/includes_address.sql
index 2637d1c..eac0f6d 100644
--- a/extras/tiger_geocoder/geocode/includes_address.sql
+++ b/extras/tiger_geocoder/geocode/includes_address.sql
@@ -90,4 +90,4 @@ BEGIN
-- The address is not within the range
RETURN FALSE;
END;
-$_$ LANGUAGE plpgsql IMMUTABLE COST 100;
+$_$ LANGUAGE plpgsql IMMUTABLE COST 20 PARALLEL SAFE;
diff --git a/extras/tiger_geocoder/geocode/interpolate_from_address.sql b/extras/tiger_geocoder/geocode/interpolate_from_address.sql
index 04f2f99..3587e97 100644
--- a/extras/tiger_geocoder/geocode/interpolate_from_address.sql
+++ b/extras/tiger_geocoder/geocode/interpolate_from_address.sql
@@ -91,7 +91,7 @@ BEGIN
--RAISE NOTICE 'start: %, center: %, new: %, side: %, offset: %, az: %', ST_AsText(ST_Transform(ST_StartPoint(road),ST_SRID(in_road))), ST_AsText(ST_Transform(center_pt,ST_SRID(in_road))),ST_AsText(result), in_side, in_offset_m, az;
RETURN result;
END;
-$_$ LANGUAGE plpgsql IMMUTABLE COST 10;
+$_$ LANGUAGE plpgsql IMMUTABLE COST 10 PARALLEL SAFE;
-- needed to ban stupid warning about how we are using deprecated functions
-- yada yada yada need this to work in 2.0 too bah
ALTER FUNCTION interpolate_from_address(integer, character varying, character varying, geometry, character varying, double precision)
diff --git a/extras/tiger_geocoder/geocode/other_helper_functions.sql b/extras/tiger_geocoder/geocode/other_helper_functions.sql
index 7d3d288..c7303e7 100644
--- a/extras/tiger_geocoder/geocode/other_helper_functions.sql
+++ b/extras/tiger_geocoder/geocode/other_helper_functions.sql
@@ -18,7 +18,7 @@ CREATE OR REPLACE FUNCTION greatest_hn(fromhn varchar, tohn varchar)
RETURNS integer AS
$$ SELECT greatest(to_number( CASE WHEN trim($1) ~ '^[0-9]+$' THEN $1 ELSE '0' END,'99999999'),to_number(CASE WHEN trim($2) ~ '^[0-9]+$' THEN $2 ELSE '0' END,'99999999') )::integer; $$
LANGUAGE sql IMMUTABLE
- COST 200;
+ COST 200 PARALLEL SAFE;
-- Returns an absolute difference between two zips
-- This is generally more efficient than doing levenshtein
@@ -28,7 +28,7 @@ CREATE OR REPLACE FUNCTION diff_zip(zip1 varchar, zip2 varchar)
RETURNS integer AS
$$ SELECT abs(to_number( CASE WHEN trim(substring($1,1,5)) ~ '^[0-9]+$' THEN $1 ELSE '0' END,'99999')::integer - to_number( CASE WHEN trim(substring($2,1,5)) ~ '^[0-9]+$' THEN $2 ELSE '0' END,'99999')::integer )::integer; $$
LANGUAGE sql IMMUTABLE STRICT
- COST 200;
-- function return true or false if 2 numeric streets are equal such as 15th St, 23rd st
-- it compares just the numeric part of the street for equality
@@ -44,7 +44,7 @@ $$
AND trim(substring($1, E'^[0-9\/\s]+')) = trim(substring($2, E'^[0-9\/\s]+')), false);
-COST 5;
+COST 5 PARALLEL SAFE;
-- Generate script to drop all non-primary unique indexes on tiger and tiger_data tables
CREATE OR REPLACE FUNCTION drop_indexes_generate_script(tiger_data_schema text DEFAULT 'tiger_data')
@@ -245,4 +245,4 @@ $$
SELECT lpad((to_number( CASE WHEN trim(substring($1,1,5)) ~ '^[0-9]+$' THEN $1 ELSE '0' END,'99999')::integer + i)::text, 5, '0')::varchar
FROM generate_series($2, $3) As i );
-LANGUAGE sql IMMUTABLE STRICT;
\ No newline at end of file
+LANGUAGE sql IMMUTABLE STRICT PARALLEL SAFE;
Summary of changes:
extras/tiger_geocoder/geocode/geocode_address.sql | 1 -
extras/tiger_geocoder/geocode/geocode_location.sql | 2 +-
extras/tiger_geocoder/geocode/includes_address.sql | 2 +-
extras/tiger_geocoder/geocode/interpolate_from_address.sql | 2 +-
extras/tiger_geocoder/geocode/other_helper_functions.sql | 8 ++++----
5 files changed, 7 insertions(+), 8 deletions(-)
hooks/post-receive
