[postgis-tickets] [PostGIS] #4850: ST_ClusterKMeans with M seems to do nothing
trac at osgeo.org
Sun Feb 14 17:50:05 PST 2021
Reporter: robe | Owner: komzpa
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> According to the docs, ST_ClusterKMeans in PostGIS 3.1 should support
> weights ergo - M coordinate.
> I thought I could use this to handle things like clustering by population
> density so that if I have a hi-rise with say 300 people and town houses
> with say 1-4 people, I should see my hi-rise area clusters have fewer
> records. It doesn't seem to make a difference whether I pass in M or
> not. Z does something.
> here is a revised example I was going to put in the docs.
> CREATE TABLE parcels AS
> SELECT lpad(g.ord::text,3,'0') As parcel_id, geom,
> ('{residential, commercial}'::text[])[1 + mod(g.ord,2)] As type,
> CASE WHEN g.ord < 3 THEN g.ord*3000 ELSE 1 END AS population
> FROM
> ST_Subdivide(ST_Buffer('SRID=3857;LINESTRING(40 100, 98 100, 100 150,
> 60 90)'::geometry,
> 40, 'endcap=square'),12) WITH ORDINALITY AS g(geom,ord);
> -- no weight
> SELECT ST_ClusterKMeans(geom, 5) OVER() AS cid, parcel_id, population
> FROM parcels
> ORDER BY cid, parcel_id;
> -- yields
> cid | parcel_id | population
> 0 | 002 | 6000
> 0 | 003 | 1
> 1 | 006 | 1
> 1 | 007 | 1
> 2 | 001 | 3000
> 3 | 004 | 1
> 4 | 005 | 1
> (7 rows)
> -- with weight by population
> SELECT ST_ClusterKMeans(ST_Force3DM(geom, population), 5) OVER() AS cid,
> FROM parcels
> yields:
> 0 | 002 | 6000
> 0 | 003 | 1
> 1 | 006 | 1
> 1 | 007 | 1
> 2 | 001 | 3000
> 3 | 004 | 1
> 4 | 005 | 1
> (7 rows)
> See answers are the same. I would have expected parcels 002 and 001 to
> have their own dedicated cluster cause they have such a huge population
New description:
records. It doesn't seem to make a difference whether I pass in M or not.
Z does something.
FROM
60 90)'::geometry,
-- no weight
SELECT ST_ClusterKMeans(ST_Centroid(geom), 5) OVER() AS cid, parcel_id,
population
FROM parcels
-- yields
0 | 002 | 6000
0 | 003 | 1
1 | 006 | 1
1 | 007 | 1
2 | 001 | 3000
3 | 004 | 1
4 | 005 | 1
(7 rows)
SELECT ST_ClusterKMeans(ST_Force3DM(ST_Centroid(geom), population), 5)
FROM parcels
yields:
0 | 002 | 6000
0 | 003 | 1
1 | 006 | 1
1 | 007 | 1
2 | 001 | 3000
3 | 004 | 1
4 | 005 | 1
(7 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4850#comment:1>
