[postgis-tickets] [PostGIS] #4851: toTopoGeom(TopoGeometry, TopoGeometry)
trac at osgeo.org
Mon Feb 15 00:43:48 PST 2021
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Keywords: |
A function adding components of the first TopoGeometry to the definition
of the second TopoGeometry.
This is similar to the existing toTopoGeom(Geometry, TopoGeometry) but
works on TopoGeometries directly.
The function as I see it should ONLY work at the topological level, so no
conversion of any kind. The two argument TopoGeometries MUST belong to the
SAME topology and need be of the same kind (simple or, hierarchically
defined by the SAME lower layer)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4851>
