[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-77-g4cc0051
git at osgeo.org
git at osgeo.org
Mon Feb 15 03:40:07 PST 2021
the project "PostGIS".
via 4cc00518ff38c3f7578c8f342b9e7698db0934eb (commit)
from c05040400c0f166910f6c907e1c342b4ef4b9934 (commit)
revisions in full, below.
commit 4cc00518ff38c3f7578c8f342b9e7698db0934eb
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Feb 5 16:53:16 2021 +0100
Implement FindTopology()
Closes #4841
Includes testcase and documentation
diff --git a/NEWS b/NEWS
index ed9584b..2b024e9 100644
--- a/NEWS
+++ b/NEWS
@@ -9,6 +9,9 @@ PostGIS 3.2.0
- #4830, ValidateTopology check for edges side face containment
(Sandro Santilli)
+ * New features*
+ - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
PostGIS 3.1.0
2020/12/18
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 388f735..574fa6e 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -641,6 +641,65 @@ face without edges | 0 |
<para><xref linkend="validatetopology_returntype"/>, <xref linkend="Topology_Load_Tiger" /></para>
</refsection>
</refentry>
+ <refentry id="FindTopology">
+ <refnamediv>
+ <refname>FindTopology</refname>
+ <refpurpose>Returns a topology record by different means.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>topology <function>FindTopology</function></funcdef>
+ <paramdef><type>TopoGeometry</type> <parameter>topogeom</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>regclass</type> <parameter>layerTable</parameter></paramdef>
+ <paramdef><type>name</type> <parameter>layerColumn</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>name</type> <parameter>layerSchema</parameter></paramdef>
+ <paramdef><type>name</type> <parameter>layerTable</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>text</type> <parameter>topoName</parameter></paramdef>
+ </funcprototype>
+ <funcprototype>
+ <paramdef><type>int</type> <parameter>id</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Takes a topology identifier or the identifier of
+a topology-related object and returns a topology.topology record.</para>
+ <!-- use this format if new function -->
+ <para>Availability: 3.2.0</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+<programlisting>
+SELECT name(findTopology('features.land_parcels', 'feature'));
+ name
+ city_data
+(1 row)
+</programlisting>
+ </refsection>
+ <!-- Optionally add a "See Also" section -->
+ </refentry>
</sect1>
<sect1 id="Topology_StatsManagement"
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 68ea0bd..0c48cd2 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -94,7 +94,7 @@ endif
-# Generate any .sql file from .sql.in.c files by running them through the SQL pre-processor
+# Generate any .sql file from .sql.in files by running them through the SQL pre-processor
%.sql: %.sql.in
$(SQLPP) $< | grep -v '^#' | \
$(PERL) -lpe "s'MODULE_PATHNAME'\$(MODULEPATH)'g" > $@
@@ -121,6 +121,7 @@ topology.sql: \
sql/query/GetNodeEdges.sql.in \
sql/manage/TopologySummary.sql.in \
sql/manage/CopyTopology.sql.in \
+ sql/manage/FindTopology.sql.in \
sql/manage/ManageHelper.sql.in \
sql/topoelement/topoelement_agg.sql.in \
sql/topogeometry/type.sql.in \
diff --git a/topology/sql/manage/FindTopology.sql.in b/topology/sql/manage/FindTopology.sql.in
new file mode 100644
index 0000000..484fe7c
--- /dev/null
+++ b/topology/sql/manage/FindTopology.sql.in
@@ -0,0 +1,85 @@
+-- PostGIS - Spatial Types for PostgreSQL
+-- http://postgis.net
+-- Copyright (C) 2021 Sandro Santilli <strk at kbt.io>
+-- This is free software; you can redistribute and/or modify it under
+-- the terms of the GNU General Public Licence. See the COPYING file.
+-- FindTopology(TopoGeometry)
+-- Return a topology.topology record from a TopoGeometry
+CREATE OR REPLACE FUNCTION topology.FindTopology(TopoGeometry)
+RETURNS topology.topology
+AS $$
+ SELECT * FROM topology.topology
+ WHERE id = topology_id($1);
+$$ LANGUAGE 'sql';
+-- FindTopology(layerRegclass, layerColumn)
+-- Return a topology.topology record from a layer
+CREATE OR REPLACE FUNCTION topology.FindTopology(regclass, name)
+AS $$
+ SELECT t.*
+ FROM topology.topology t
+ JOIN topology.layer l ON (t.id = l.topology_id)
+ WHERE format('%I.%I', l.schema_name, l.table_name)::regclass = $1
+ AND l.feature_column = $2;
+$$ LANGUAGE 'sql';
+-- FindTopology(layerSchema, layerTable, layerColumn)
+CREATE OR REPLACE FUNCTION topology.FindTopology(name, name, name)
+AS $$
+ SELECT t.*
+ WHERE l.schema_name = $1
+ AND l.table_name = $2
+ AND l.feature_column = $3;
+$$ LANGUAGE 'sql';
+-- FindTopology(topoName)
+-- Return a topology.topology record from a topology name
+CREATE OR REPLACE FUNCTION topology.FindTopology(text)
+AS $$
+ SELECT *
+ WHERE name = $1
+$$ LANGUAGE 'sql';
+-- FindTopology(topoId)
+-- Return a topology.topology record from a topology id
+CREATE OR REPLACE FUNCTION topology.FindTopology(integer)
+AS $$
+ SELECT *
+ WHERE id = $1
+$$ LANGUAGE 'sql';
diff --git a/topology/test/regress/findtopology.sql b/topology/test/regress/findtopology.sql
index 0000000..ff07707
--- /dev/null
+++ b/topology/test/regress/findtopology.sql
@@ -0,0 +1,27 @@
+BEGIN;
+CREATE SCHEMA s;
+SELECT NULL FROM CreateTopology('a');
+SELECT NULL FROM CreateTopology('b');
+SELECT 'by_name', name(findTopology('a'::text));
+SELECT 'by_id', name(findTopology( id(findTopology('a')) ));
+CREATE TABLE s.f(a int);
+SELECT NULL FROM AddTopoGeometryColumn('a', 's', 'f', 'ga', 'POINT');
+SELECT NULL FROM AddTopoGeometryColumn('b', 's', 'f', 'gb', 'POINT');
+SELECT 'a_by_layer', name(findTopology('s', 'f', 'ga'));
+SELECT 'b_by_layer', name(findTopology('s', 'f', 'gb'));
+SELECT 'by_layer_regclass', name(findTopology('s.f', 'ga'));
+SELECT 'a_by_topogeom', name(findTopology(
+ toTopoGeom('POINT(0 0)', 'a', 1, 0)
+SELECT 'b_by_topogeom', name(findTopology(
+ toTopoGeom('POINT(0 0)', 'b', 1, 0)
+ROLLBACK;
diff --git a/topology/test/regress/findtopology_expected b/topology/test/regress/findtopology_expected
index 0000000..b493a1e
--- /dev/null
+++ b/topology/test/regress/findtopology_expected
@@ -0,0 +1,7 @@
+by_name|a
+by_id|a
+a_by_layer|a
+b_by_layer|b
+by_layer_regclass|a
+a_by_topogeom|a
+b_by_topogeom|b
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index bf93774..89f86fc 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -2107,9 +2107,6 @@ $$
LANGUAGE 'plpgsql' VOLATILE STRICT;
--} DropTopology
-#include "sql/manage/TopologySummary.sql.in"
-#include "sql/manage/CopyTopology.sql.in"
-- Spatial predicates
#include "sql/predicates.sql.in"
@@ -2147,6 +2144,10 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
--general management --
#include "sql/manage/ManageHelper.sql.in"
+#include "sql/manage/TopologySummary.sql.in"
+#include "sql/manage/CopyTopology.sql.in"
+#include "sql/manage/FindTopology.sql.in"
CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed() RETURNS text
AS _POSTGIS_SQL_SELECT_POSTGIS_SCRIPTS_VERSION
Summary of changes:
NEWS | 3 +
doc/extras_topology.xml | 59 ++++++++++++++++++++
topology/Makefile.in | 3 +-
topology/sql/manage/FindTopology.sql.in | 85 +++++++++++++++++++++++++++++
topology/test/regress/findtopology.sql | 27 +++++++++
topology/test/regress/findtopology_expected | 7 +++
topology/topology.sql.in | 7 ++-
7 files changed, 187 insertions(+), 4 deletions(-)
create mode 100644 topology/sql/manage/FindTopology.sql.in
create mode 100644 topology/test/regress/findtopology.sql
create mode 100644 topology/test/regress/findtopology_expected
hooks/post-receive
