[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-78-g7e6e085
Wed Feb 17 08:40:20 PST 2021
the project "PostGIS".
       via  7e6e08512ade1c3ca14d191894d8737480e59ada (commit)
      from  4cc00518ff38c3f7578c8f342b9e7698db0934eb (commit)
revisions in full, below.
commit 7e6e08512ade1c3ca14d191894d8737480e59ada
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Feb 17 17:40:00 2021 +0100
    Be stricter in what run_test.pl skips in output
diff --git a/regress/run_test.pl b/regress/run_test.pl
index dc1ce00..d018ecd 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -809,7 +809,7 @@ sub run_simple_test
 	# Strip the lines we don't care about
 	@lines = grep(!/^\$/, @lines);
-	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT|COPY|DO)/, @lines);
+	@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT [0-9]*|COPY|DO)$/, @lines);
 	@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
 	@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
 	@lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
Summary of changes:
 regress/run_test.pl | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
