[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-83-g23b0eb5
Wed Feb 17 16:57:10 PST 2021
the project "PostGIS".
       via  23b0eb52b8f6480836fa99de55837ee6d1c2846f (commit)
       via  da2247270f960acb440938c77805c22926a7c500 (commit)
       via  83480f5befa9bb154c923791f15c5a4729b974c3 (commit)
      from  b124e4fecdd54d87e826845b997d89381bf379d1 (commit)
revisions in full, below.
commit 23b0eb52b8f6480836fa99de55837ee6d1c2846f
Merge: da22472 b124e4f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Feb 17 16:57:04 2021 -0800
    Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit da2247270f960acb440938c77805c22926a7c500
Date:   Wed Feb 17 16:56:56 2021 -0800
    Update news regarding NaN WKT input
diff --git a/NEWS b/NEWS
index 2b024e9..741ad29 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.2.0
   - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
   - #4830, ValidateTopology check for edges side face containment
            (Sandro Santilli)
+  - #4827, Allow NaN coordinates in WKT input (Paul Ramsey)
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
commit 83480f5befa9bb154c923791f15c5a4729b974c3
Date:   Wed Feb 17 16:55:31 2021 -0800
    Accept 'Nan' coordinates in WKT input, to allow for round-tripping of oddball bad geometry.
    Closes #4827
diff --git a/liblwgeom/cunit/cu_in_wkt.c b/liblwgeom/cunit/cu_in_wkt.c
index 5df57ca..dc25093 100644
--- a/liblwgeom/cunit/cu_in_wkt.c
+++ b/liblwgeom/cunit/cu_in_wkt.c
@@ -66,6 +66,14 @@ static char* cu_wkt_in(char *wkt, uint8_t variant)
 	return s;
+#include <ctype.h>
+static void cu_strtolower(char* str)
+	size_t i;
+	for (i = 0; i < strlen(str); ++i) {
+		str[i] = tolower(str[i]);
 static void test_wkt_in_point(void)
@@ -94,7 +102,13 @@ static void test_wkt_in_point(void)
 	CU_ASSERT_STRING_EQUAL(r,s);
 	lwfree(r);
-	//printf("\nIN:  %s\nOUT: %s\n",s,r);
+	s = "point(nan 10)";
+	r = cu_wkt_in(s, WKT_ISO);
+	cu_strtolower(r);
+	CU_ASSERT_STRING_EQUAL(r,s);
+	lwfree(r);
+	// printf("\nIN:  %s\nOUT: %s\n",s,r);
 static void test_wkt_in_linestring(void)
diff --git a/liblwgeom/lwin_wkt_lex.c b/liblwgeom/lwin_wkt_lex.c
index 9d918ae..6cd2fe2 100644
--- a/liblwgeom/lwin_wkt_lex.c
+++ b/liblwgeom/lwin_wkt_lex.c
@@ -1,6 +1,6 @@
-#line 1 "lwin_wkt_lex.c"
+#line 2 "lwin_wkt_lex.c"
-#line 3 "lwin_wkt_lex.c"
+#line 4 "lwin_wkt_lex.c"
 #define  YY_INT_ALIGNED short int
@@ -8,17 +8,11 @@
 #define yy_create_buffer wkt_yy_create_buffer
 #define yy_delete_buffer wkt_yy_delete_buffer
-#define yy_scan_buffer wkt_yy_scan_buffer
-#define yy_scan_string wkt_yy_scan_string
-#define yy_scan_bytes wkt_yy_scan_bytes
+#define yy_flex_debug wkt_yy_flex_debug
 #define yy_init_buffer wkt_yy_init_buffer
 #define yy_flush_buffer wkt_yy_flush_buffer
 #define yy_load_buffer_state wkt_yy_load_buffer_state
 #define yy_switch_to_buffer wkt_yy_switch_to_buffer
-#define yypush_buffer_state wkt_yypush_buffer_state
-#define yypop_buffer_state wkt_yypop_buffer_state
-#define yyensure_buffer_stack wkt_yyensure_buffer_stack
-#define yy_flex_debug wkt_yy_flex_debug
 #define yyin wkt_yyin
 #define yyleng wkt_yyleng
 #define yylex wkt_yylex
@@ -33,246 +27,12 @@
 #define FLEX_SCANNER
 #define YY_FLEX_MAJOR_VERSION 2
-#define YY_FLEX_MINOR_VERSION 6
-#define YY_FLEX_SUBMINOR_VERSION 4
+#define YY_FLEX_MINOR_VERSION 5
+#define YY_FLEX_SUBMINOR_VERSION 35
 #if YY_FLEX_SUBMINOR_VERSION > 0
 #define FLEX_BETA
 #endif
-#ifdef yy_create_buffer
-#define wkt_yy_create_buffer_ALREADY_DEFINED
-#else
-#define yy_create_buffer wkt_yy_create_buffer
-#endif
-#ifdef yy_delete_buffer
-#define wkt_yy_delete_buffer_ALREADY_DEFINED
-#else
-#define yy_delete_buffer wkt_yy_delete_buffer
-#endif
-#ifdef yy_scan_buffer
-#define wkt_yy_scan_buffer_ALREADY_DEFINED
-#else
-#endif
-#ifdef yy_scan_string
-#define wkt_yy_scan_string_ALREADY_DEFINED
-#else
-#endif
-#ifdef yy_scan_bytes
-#define wkt_yy_scan_bytes_ALREADY_DEFINED
-#else
-#endif
-#ifdef yy_init_buffer
-#define wkt_yy_init_buffer_ALREADY_DEFINED
-#else
-#define yy_init_buffer wkt_yy_init_buffer
-#endif
-#ifdef yy_flush_buffer
-#define wkt_yy_flush_buffer_ALREADY_DEFINED
-#else
-#define yy_flush_buffer wkt_yy_flush_buffer
-#endif
-#ifdef yy_load_buffer_state
-#define wkt_yy_load_buffer_state_ALREADY_DEFINED
-#else
-#define yy_load_buffer_state wkt_yy_load_buffer_state
-#endif
-#ifdef yy_switch_to_buffer
-#define wkt_yy_switch_to_buffer_ALREADY_DEFINED
-#else
-#define yy_switch_to_buffer wkt_yy_switch_to_buffer
-#endif
-#ifdef yypush_buffer_state
-#define wkt_yypush_buffer_state_ALREADY_DEFINED
-#else
-#endif
-#ifdef yypop_buffer_state
-#define wkt_yypop_buffer_state_ALREADY_DEFINED
-#else
-#endif
-#ifdef yyensure_buffer_stack
-#define wkt_yyensure_buffer_stack_ALREADY_DEFINED
-#else
-#endif
-#ifdef yylex
-#define wkt_yylex_ALREADY_DEFINED
-#else
-#define yylex wkt_yylex
-#endif
-#ifdef yyrestart
-#define wkt_yyrestart_ALREADY_DEFINED
-#else
-#define yyrestart wkt_yyrestart
-#endif
-#ifdef yylex_init
-#define wkt_yylex_init_ALREADY_DEFINED
-#else
-#define yylex_init wkt_yylex_init
-#endif
-#ifdef yylex_init_extra
-#define wkt_yylex_init_extra_ALREADY_DEFINED
-#else
-#define yylex_init_extra wkt_yylex_init_extra
-#endif
-#ifdef yylex_destroy
-#define wkt_yylex_destroy_ALREADY_DEFINED
-#else
-#define yylex_destroy wkt_yylex_destroy
-#endif
-#ifdef yyget_debug
-#define wkt_yyget_debug_ALREADY_DEFINED
-#else
-#define yyget_debug wkt_yyget_debug
-#endif
-#ifdef yyset_debug
-#define wkt_yyset_debug_ALREADY_DEFINED
-#else
-#define yyset_debug wkt_yyset_debug
-#endif
-#ifdef yyget_extra
-#define wkt_yyget_extra_ALREADY_DEFINED
-#else
-#define yyget_extra wkt_yyget_extra
-#endif
-#ifdef yyset_extra
-#define wkt_yyset_extra_ALREADY_DEFINED
-#else
-#define yyset_extra wkt_yyset_extra
-#endif
-#ifdef yyget_in
-#define wkt_yyget_in_ALREADY_DEFINED
-#else
-#define yyget_in wkt_yyget_in
-#endif
-#ifdef yyset_in
-#define wkt_yyset_in_ALREADY_DEFINED
-#else
-#define yyset_in wkt_yyset_in
-#endif
-#ifdef yyget_out
-#define wkt_yyget_out_ALREADY_DEFINED
-#else
-#define yyget_out wkt_yyget_out
-#endif
-#ifdef yyset_out
-#define wkt_yyset_out_ALREADY_DEFINED
-#else
-#define yyset_out wkt_yyset_out
-#endif
-#ifdef yyget_leng
-#define wkt_yyget_leng_ALREADY_DEFINED
-#else
-#define yyget_leng wkt_yyget_leng
-#endif
-#ifdef yyget_text
-#define wkt_yyget_text_ALREADY_DEFINED
-#else
-#define yyget_text wkt_yyget_text
-#endif
-#ifdef yyget_lineno
-#define wkt_yyget_lineno_ALREADY_DEFINED
-#else
-#define yyget_lineno wkt_yyget_lineno
-#endif
-#ifdef yyset_lineno
-#define wkt_yyset_lineno_ALREADY_DEFINED
-#else
-#define yyset_lineno wkt_yyset_lineno
-#endif
-#ifdef yywrap
-#define wkt_yywrap_ALREADY_DEFINED
-#else
-#define yywrap wkt_yywrap
-#endif
-#ifdef yyalloc
-#define wkt_yyalloc_ALREADY_DEFINED
-#else
-#define yyalloc wkt_yyalloc
-#endif
-#ifdef yyrealloc
-#define wkt_yyrealloc_ALREADY_DEFINED
-#else
-#define yyrealloc wkt_yyrealloc
-#endif
-#ifdef yyfree
-#define wkt_yyfree_ALREADY_DEFINED
-#else
-#define yyfree wkt_yyfree
-#endif
-#ifdef yytext
-#define wkt_yytext_ALREADY_DEFINED
-#else
-#define yytext wkt_yytext
-#endif
-#ifdef yyleng
-#define wkt_yyleng_ALREADY_DEFINED
-#else
-#define yyleng wkt_yyleng
-#endif
-#ifdef yyin
-#define wkt_yyin_ALREADY_DEFINED
-#else
-#define yyin wkt_yyin
-#endif
-#ifdef yyout
-#define wkt_yyout_ALREADY_DEFINED
-#else
-#define yyout wkt_yyout
-#endif
-#ifdef yy_flex_debug
-#define wkt_yy_flex_debug_ALREADY_DEFINED
-#else
-#endif
-#ifdef yylineno
-#define wkt_yylineno_ALREADY_DEFINED
-#else
-#define yylineno wkt_yylineno
-#endif
 /* First, we deal with  platform-specific or compiler-specific issues. */
 /* begin standard C headers. */
@@ -306,6 +66,7 @@ typedef int16_t flex_int16_t;
 typedef uint16_t flex_uint16_t;
 typedef int32_t flex_int32_t;
 typedef uint32_t flex_uint32_t;
+typedef uint64_t flex_uint64_t;
 #else
 typedef signed char flex_int8_t;
 typedef short int flex_int16_t;
@@ -313,6 +74,7 @@ typedef int flex_int32_t;
 typedef unsigned char flex_uint8_t;
 typedef unsigned short int flex_uint16_t;
 typedef unsigned int flex_uint32_t;
+#endif /* ! C99 */
 /* Limits of integral types. */
 #ifndef INT8_MIN
@@ -343,61 +105,63 @@ typedef unsigned int flex_uint32_t;
 #define UINT32_MAX             (4294967295U)
 #endif
-#ifndef SIZE_MAX
-#define SIZE_MAX               (~(size_t)0)
-#endif
+#endif /* ! FLEXINT_H */
-#endif /* ! C99 */
+#ifdef __cplusplus
-#endif /* ! FLEXINT_H */
+/* The "const" storage-class-modifier is valid. */
+#define YY_USE_CONST
-/* begin standard C++ headers. */
+#else	/* ! __cplusplus */
-/* TODO: this is always defined, so inline it */
-#define yyconst const
+/* C99 requires __STDC__ to be defined as 1. */
+#if defined (__STDC__)
-#if defined(__GNUC__) && __GNUC__ >= 3
-#define yynoreturn __attribute__((__noreturn__))
+#endif	/* defined (__STDC__) */
+#endif	/* ! __cplusplus */
+#ifdef YY_USE_CONST
+#define yyconst const
 #else
-#define yynoreturn
+#define yyconst
 #endif
 /* Returned upon end-of-file. */
 #define YY_NULL 0
-/* Promotes a possibly negative, possibly signed char to an
- *   integer in range [0..255] for use as an array index.
+/* Promotes a possibly negative, possibly signed char to an unsigned
+ * integer for use as an array index.  If the signed char is negative,
+ * we want to instead treat it as an 8-bit unsigned char, hence the
+ * double cast.
-#define YY_SC_TO_UI(c) ((YY_CHAR) (c))
+#define YY_SC_TO_UI(c) ((unsigned int) (unsigned char) c)
 /* Enter a start condition.  This macro really ought to take a parameter,
  * but we do it the disgusting crufty way forced on us by the ()-less
  * definition of BEGIN.
 #define BEGIN (yy_start) = 1 + 2 *
 /* Translate the current start state into a value that can be later handed
  * to BEGIN to return to the state.  The YYSTATE alias is for lex
  * compatibility.
 #define YY_START (((yy_start) - 1) / 2)
 #define YYSTATE YY_START
 /* Action number for EOF rule of a given start state. */
 #define YY_STATE_EOF(state) (YY_END_OF_BUFFER + state + 1)
 /* Special action meaning "start processing a new file". */
-#define YY_NEW_FILE yyrestart( yyin  )
+#define YY_NEW_FILE wkt_yyrestart(wkt_yyin  )
 #define YY_END_OF_BUFFER_CHAR 0
 /* Size of default input buffer. */
 #ifndef YY_BUF_SIZE
-#ifdef __ia64__
-/* On IA-64, the buffer size is 16k, not 8k.
- * Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
- * Ditto for the __ia64__ case accordingly.
-#define YY_BUF_SIZE 32768
-#else
 #define YY_BUF_SIZE 16384
-#endif /* __ia64__ */
 #endif
 /* The state buf must be large enough to hold one state per character in the main buffer.
@@ -414,30 +178,30 @@ typedef struct yy_buffer_state *YY_BUFFER_STATE;
 typedef size_t yy_size_t;
 #endif
-extern int yyleng;
+extern yy_size_t wkt_yyleng;
-extern FILE *yyin, *yyout;
+extern FILE *wkt_yyin, *wkt_yyout;
 #define EOB_ACT_CONTINUE_SCAN 0
 #define EOB_ACT_END_OF_FILE 1
 #define EOB_ACT_LAST_MATCH 2
     #define YY_LESS_LINENO(n)
-    #define YY_LINENO_REWIND_TO(ptr)
 /* Return all but the first "n" matched characters back to the input stream. */
 #define yyless(n) \
 	do \
-		/* Undo effects of setting up yytext. */ \
+		/* Undo effects of setting up wkt_yytext. */ \
         int yyless_macro_arg = (n); \
         YY_LESS_LINENO(yyless_macro_arg);\
 		*yy_cp = (yy_hold_char); \
 		YY_RESTORE_YY_MORE_OFFSET \
 		(yy_c_buf_p) = yy_cp = yy_bp + yyless_macro_arg - YY_MORE_ADJ; \
-		YY_DO_BEFORE_ACTION; /* set up yytext again */ \
+		YY_DO_BEFORE_ACTION; /* set up wkt_yytext again */ \
 	while ( 0 )
 #define unput(c) yyunput( c, (yytext_ptr)  )
 #ifndef YY_STRUCT_YY_BUFFER_STATE
@@ -452,12 +216,12 @@ struct yy_buffer_state
 	/* Size of input buffer in bytes, not including room for EOB
 	 * characters.
-	int yy_buf_size;
+	yy_size_t yy_buf_size;
 	/* Number of characters read into yy_ch_buf, not including EOB
 	 * characters.
-	int yy_n_chars;
+	yy_size_t yy_n_chars;
 	/* Whether we "own" the buffer - i.e., we know we created it,
 	 * and can realloc() it to grow it, and should free() it to
@@ -480,7 +244,7 @@ struct yy_buffer_state
     int yy_bs_lineno; /**< The line count. */
     int yy_bs_column; /**< The column count. */
 	/* Whether to try to fill the input buffer when we reach the
 	 * end of it.
@@ -497,8 +261,8 @@ struct yy_buffer_state
 	 * possible backing-up.
 	 * When we actually see the EOF, we change the status to "new"
-	 * (via yyrestart()), so that the user can continue scanning by
-	 * just pointing yyin at a new input file.
+	 * (via wkt_yyrestart()), so that the user can continue scanning by
+	 * just pointing wkt_yyin at a new input file.
 #define YY_BUFFER_EOF_PENDING 2
@@ -508,7 +272,7 @@ struct yy_buffer_state
 /* Stack of input buffers. */
 static size_t yy_buffer_stack_top = 0; /**< index of top of stack. */
 static size_t yy_buffer_stack_max = 0; /**< capacity of stack. */
-static YY_BUFFER_STATE * yy_buffer_stack = NULL; /**< Stack as an array. */
+static YY_BUFFER_STATE * yy_buffer_stack = 0; /**< Stack as an array. */
 /* We provide macros for accessing buffer states in case in the
  * future we want to put the buffer states in a more general
@@ -519,103 +283,108 @@ static YY_BUFFER_STATE * yy_buffer_stack = NULL; /**< Stack as an array. */
 #define YY_CURRENT_BUFFER ( (yy_buffer_stack) \
                           ? (yy_buffer_stack)[(yy_buffer_stack_top)] \
                           : NULL)
 /* Same as previous macro, but useful when we know that the buffer stack is not
  * NULL or when we need an lvalue. For internal use only.
 #define YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)]
-/* yy_hold_char holds the character lost when yytext is formed. */
+/* yy_hold_char holds the character lost when wkt_yytext is formed. */
 static char yy_hold_char;
-static int yy_n_chars;		/* number of characters read into yy_ch_buf */
-int yyleng;
+static yy_size_t yy_n_chars;		/* number of characters read into yy_ch_buf */
+yy_size_t wkt_yyleng;
 /* Points to current character in buffer. */
-static char *yy_c_buf_p = NULL;
+static char *yy_c_buf_p = (char *) 0;
 static int yy_init = 0;		/* whether we need to initialize */
 static int yy_start = 0;	/* start state number */
-/* Flag which is used to allow yywrap()'s to do buffer switches
- * instead of setting up a fresh yyin.  A bit of a hack ...
+/* Flag which is used to allow wkt_yywrap()'s to do buffer switches
+ * instead of setting up a fresh wkt_yyin.  A bit of a hack ...
 static int yy_did_buffer_switch_on_eof;
-void yyrestart ( FILE *input_file  );
-void yy_switch_to_buffer ( YY_BUFFER_STATE new_buffer  );
-YY_BUFFER_STATE yy_create_buffer ( FILE *file, int size  );
-void yy_delete_buffer ( YY_BUFFER_STATE b  );
-void yy_flush_buffer ( YY_BUFFER_STATE b  );
-void yypush_buffer_state ( YY_BUFFER_STATE new_buffer  );
-void yypop_buffer_state ( void );
+void wkt_yyrestart (FILE *input_file  );
+void wkt_yy_switch_to_buffer (YY_BUFFER_STATE new_buffer  );
+YY_BUFFER_STATE wkt_yy_create_buffer (FILE *file,int size  );
+void wkt_yy_delete_buffer (YY_BUFFER_STATE b  );
+void wkt_yy_flush_buffer (YY_BUFFER_STATE b  );
+void wkt_yypush_buffer_state (YY_BUFFER_STATE new_buffer  );
+void wkt_yypop_buffer_state (void );
+static void wkt_yyensure_buffer_stack (void );
+static void wkt_yy_load_buffer_state (void );
+static void wkt_yy_init_buffer (YY_BUFFER_STATE b,FILE *file  );
-static void yyensure_buffer_stack ( void );
-static void yy_load_buffer_state ( void );
-static void yy_init_buffer ( YY_BUFFER_STATE b, FILE *file  );
-#define YY_FLUSH_BUFFER yy_flush_buffer( YY_CURRENT_BUFFER )
+#define YY_FLUSH_BUFFER wkt_yy_flush_buffer(YY_CURRENT_BUFFER )
-YY_BUFFER_STATE yy_scan_buffer ( char *base, yy_size_t size  );
-YY_BUFFER_STATE yy_scan_string ( const char *yy_str  );
-YY_BUFFER_STATE yy_scan_bytes ( const char *bytes, int len  );
+YY_BUFFER_STATE wkt_yy_scan_buffer (char *base,yy_size_t size  );
+YY_BUFFER_STATE wkt_yy_scan_string (yyconst char *yy_str  );
+YY_BUFFER_STATE wkt_yy_scan_bytes (yyconst char *bytes,yy_size_t len  );
-void *yyalloc ( yy_size_t  );
-void *yyrealloc ( void *, yy_size_t  );
-void yyfree ( void *  );
+void *wkt_yyalloc (yy_size_t  );
+void *wkt_yyrealloc (void *,yy_size_t  );
+void wkt_yyfree (void *  );
+#define yy_new_buffer wkt_yy_create_buffer
-#define yy_new_buffer yy_create_buffer
 #define yy_set_interactive(is_interactive) \
 	if ( ! YY_CURRENT_BUFFER ){ \
-        yyensure_buffer_stack (); \
+        wkt_yyensure_buffer_stack (); \
 		YY_CURRENT_BUFFER_LVALUE =    \
-            yy_create_buffer( yyin, YY_BUF_SIZE ); \
+            wkt_yy_create_buffer(wkt_yyin,YY_BUF_SIZE ); \
 	YY_CURRENT_BUFFER_LVALUE->yy_is_interactive = is_interactive; \
 #define yy_set_bol(at_bol) \
 	if ( ! YY_CURRENT_BUFFER ){\
 	YY_CURRENT_BUFFER_LVALUE->yy_at_bol = at_bol; \
 #define YY_AT_BOL() (YY_CURRENT_BUFFER_LVALUE->yy_at_bol)
 /* Begin user sect3 */
-#define wkt_yywrap() (/*CONSTCOND*/1)
+#define wkt_yywrap(n) 1
 #define YY_SKIP_YYWRAP
-typedef flex_uint8_t YY_CHAR;
-FILE *yyin = NULL, *yyout = NULL;
+typedef unsigned char YY_CHAR;
+FILE *wkt_yyin = (FILE *) 0, *wkt_yyout = (FILE *) 0;
 typedef int yy_state_type;
-extern int yylineno;
-int yylineno = 1;
+extern int wkt_yylineno;
-extern char *yytext;
-#ifdef yytext_ptr
-#undef yytext_ptr
-#endif
-#define yytext_ptr yytext
+int wkt_yylineno = 1;
+extern char *wkt_yytext;
+#define yytext_ptr wkt_yytext
-static yy_state_type yy_get_previous_state ( void );
-static yy_state_type yy_try_NUL_trans ( yy_state_type current_state  );
-static int yy_get_next_buffer ( void );
-static void yynoreturn yy_fatal_error ( const char* msg  );
+static yy_state_type yy_get_previous_state (void );
+static yy_state_type yy_try_NUL_trans (yy_state_type current_state  );
+static int yy_get_next_buffer (void );
+static void yy_fatal_error (yyconst char msg[]  );
 /* Done after the current pattern has been matched and before the
- * corresponding action - sets up yytext.
+ * corresponding action - sets up wkt_yytext.
 #define YY_DO_BEFORE_ACTION \
 	(yytext_ptr) = yy_bp; \
-	yyleng = (int) (yy_cp - yy_bp); \
+	wkt_yyleng = (yy_size_t) (yy_cp - yy_bp); \
 	(yy_hold_char) = *yy_cp; \
 	*yy_cp = '\0'; \
 	(yy_c_buf_p) = yy_cp;
-#define YY_NUM_RULES 26
-#define YY_END_OF_BUFFER 27
+#define YY_NUM_RULES 27
+#define YY_END_OF_BUFFER 28
 /* This struct is not used in this scanner,
    but its presence is necessary. */
 struct yy_trans_info
@@ -623,30 +392,30 @@ struct yy_trans_info
 	flex_int32_t yy_verify;
 	flex_int32_t yy_nxt;
-static const flex_int16_t yy_accept[173] =
+static yyconst flex_int16_t yy_accept[177] =
     {   0,
-        0,    0,   27,   25,   24,   24,   20,   21,   22,   25,
-       25,   25,   23,   25,   25,   25,   25,   19,   25,   25,
-       25,   19,   24,    0,    0,    0,    1,    0,    0,    0,
+        0,    0,   28,   26,   25,   25,   21,   22,   23,   26,
+       26,   26,   24,   26,   26,   26,   26,   20,   26,   26,
+       26,   26,   20,   25,    0,    0,    0,    1,    0,    0,
         0,    0,    0,    0,    0,    0,    0,    0,    0,    0,
-       19,    0,    0,    0,    0,    0,    0,    0,    0,    0,
-        0,    0,    0,   16,    0,    0,    0,    0,    0,    0,
-        0,    0,    0,    0,    0,    0,    0,    0,    0,   18,
-        0,    0,    0,   17,    0,    0,    0,    0,    0,    0,
+        0,    0,   20,    0,    0,    0,    0,    0,    0,    0,
+        0,    0,    0,    0,    0,    0,   17,    0,    0,    0,
+        0,    0,    0,    0,    0,    2,    0,    0,    0,    0,
+        0,    0,    0,   19,    0,    0,    0,   18,    0,    0,
-        2,    0,    0,    0,    0,    0,    0,    0,    0,    0,
+        0,    0,    0,    0,    3,    0,    0,    0,    0,    0,
-        0,   10,    0,    0,    0,    0,    0,    0,    0,    0,
-        0,    0,    0,    0,    0,   15,    0,    0,    0,    0,
+        0,    0,    0,    0,    0,   11,    0,    0,    0,    0,
+        0,    0,    0,    0,    0,    0,    0,    0,    0,   16,
+        0,    0,    0,    0,    0,    0,    0,    0,    0,    0,
+        0,    0,    0,    0,    0,   14,    7,    0,    9,    0,
-        0,   13,    6,    0,    8,    0,    0,    0,    0,    0,
-        0,    0,    0,    0,    0,    0,    0,    0,    9,    0,
-        0,    5,    4,    0,    0,   11,    0,    0,    0,   12,
-        0,    0,    0,    0,    7,    0,    0,    0,    0,   14,
-        3,    0
+        0,    0,   10,    0,    0,    6,    5,    0,    0,   12,
+        0,    0,    0,   13,    0,    0,    0,    0,    8,    0,
+        0,    0,    0,   15,    4,    0
-static const YY_CHAR yy_ec[256] =
+static yyconst flex_int32_t yy_ec[256] =
     {   0,
         1,    1,    1,    1,    1,    1,    1,    1,    2,    3,
         1,    1,    2,    1,    1,    1,    1,    1,    1,    1,
@@ -678,7 +447,7 @@ static const YY_CHAR yy_ec[256] =
         1,    1,    1,    1,    1
-static const YY_CHAR yy_meta[53] =
+static yyconst flex_int32_t yy_meta[53] =
     {   0,
         1,    1,    1,    1,    1,    1,    1,    1,    1,    1,
@@ -688,105 +457,106 @@ static const YY_CHAR yy_meta[53] =
         1,    1
-static const flex_int16_t yy_base[173] =
+static yyconst flex_int16_t yy_base[177] =
     {   0,
-        0,    0,  202,  384,   51,   53,  384,  384,  384,   48,
-      190,   57,  384,   41,   41,   52,   49,   42,   48,   48,
-       56,   53,   75,  186,    0,   96,  384,  106,  109,   54,
-       62,   61,   80,   86,   91,   97,  100,  102,  100,  104,
-      384,  179,  126,  112,  102,  105,  109,  117,  129,  120,
-      126,  119,  136,  384,  139,  124,  130,  140,  127,  144,
-      134,  142,  135,  148,   85,  141,  154,  148,  154,  384,
-      157,  160,  195,  384,  166,  175,  184,  175,  185,  178,
-      179,  178,  180,  178,  192,  190,  186,  194,  204,   76,
-       69,  204,  202,  215,  210,  202,  218,  215,  220,  226,
-      218,  384,  223,  236,  227,  241,  225,  243,  236,  230,
-      246,  242,  237,  253,  258,  384,  245,  249,  263,  259,
-      266,  270,  260,  261,  274,  281,  274,  270,  271,  275,
-      279,  384,  384,  274,  384,  281,  294,  283,  291,  283,
-      295,  300,  297,  301,  310,  298,  306,  316,  384,  318,
-      315,  384,  384,  310,  319,  384,  325,  317,  325,  384,
-      317,  330,  337,  331,  384,  339,  334,  345,  340,  384,
-      384,  384
+        0,    0,  374,  391,   51,   53,  391,  391,  391,   48,
+      362,   57,  391,   41,   41,   52,   49,   42,   59,   50,
+       49,   56,   55,   76,  361,    0,   96,  391,  106,  109,
+       54,   62,   61,   80,   86,   91,   97,   97,  101,  103,
+      101,  106,  391,  193,  126,  113,  110,  107,  111,  123,
+      132,  121,  149,  127,  122,  143,  391,  147,  132,  138,
+      147,  133,  150,  140,  151,  391,  144,  156,  189,  153,
+      156,  150,  160,  391,  160,  161,  196,  391,  169,  182,
+      192,  186,  193,  184,  187,  186,  188,  186,  196,  195,
+      191,  199,  210,  180,   76,  207,  203,  218,  217,  213,
+      226,  221,  227,  231,  228,  391,  229,  240,  230,  245,
+      229,  247,  239,  233,  249,  245,  238,  256,  265,  391,
+      256,  257,  269,  266,  273,  276,  267,  267,  278,  284,
+      278,  274,  275,  278,  282,  391,  391,  277,  391,  284,
+      295,  286,  298,  294,  303,  306,  304,  308,  316,  305,
+      312,  320,  391,  321,  319,  391,  391,  314,  323,  391,
+      328,  320,  328,  391,  320,  331,  340,  338,  391,  350,
+      342,  351,  347,  391,  391,  391
-static const flex_int16_t yy_def[173] =
+static yyconst flex_int16_t yy_def[177] =
     {   0,
-      172,    1,  172,  172,  172,  172,  172,  172,  172,  172,
-      172,  172,  172,  172,  172,  172,  172,  172,  172,  172,
-      172,  172,  172,  172,   12,  172,  172,  172,  172,  172,
-      172,    0
+      176,    1,  176,  176,  176,  176,  176,  176,  176,  176,
+      176,  176,  176,  176,  176,  176,  176,  176,  176,  176,
+      176,  176,  176,  176,  176,   12,  176,  176,  176,  176,
+      176,  176,  176,  176,  176,    0
-static const flex_int16_t yy_nxt[437] =
+static yyconst flex_int16_t yy_nxt[444] =
     {   0,
         4,    5,    6,    7,    8,    4,    9,   10,   11,   12,
        13,    4,    4,   14,    4,   15,    4,   16,    4,    4,
-       17,   18,    4,    4,   19,    4,   20,   21,    4,    4,
-        4,   22,    4,   14,    4,   15,    4,   16,    4,    4,
-        4,   22,   23,   23,   23,   23,   24,   25,   27,   27,
-       30,   27,   33,   27,   31,   28,   25,   34,   35,   32,
-       36,   37,   29,   38,   41,   39,   23,   23,   91,   44,
-       30,   40,   33,   45,   31,   91,   46,   34,   35,   32,
-       36,   37,   29,   38,   41,   39,   77,   27,   27,   44,
-       27,   40,   27,   45,   47,   26,   46,   27,   27,   48,
-       27,   29,   27,   49,   42,   26,   42,   50,   43,   51,
-       52,   53,   54,   55,   47,   56,   57,   27,   27,   48,
-       27,   29,   27,   49,   58,   43,   59,   50,   60,   51,
-       52,   53,   54,   55,   61,   56,   57,   62,   63,   64,
-       65,   66,   67,   68,   58,   69,   59,   70,   60,   71,
-       72,   73,   74,   78,   61,   75,   76,   62,   63,   64,
-       65,   66,   67,   68,   79,   69,   80,   70,   81,   71,
-       72,   73,   74,   78,   82,   75,   76,   83,   43,   88,
-       89,   90,   92,   91,   79,   26,   80,   93,   81,   26,
-       94,  172,   95,   96,   82,   97,   98,   83,   84,   88,
-       89,   99,   92,  100,  101,   85,  102,   93,  103,   86,
-       94,   87,   95,   96,  104,   97,   98,  105,   84,  106,
-      107,   99,  108,  100,  101,   85,  102,  109,  103,   86,
-      110,   87,  111,  114,  104,  112,  113,  105,  115,  106,
-      107,  116,  108,  117,  118,  119,  120,  109,  121,  122,
-      110,  123,  111,  114,  124,  112,  113,  125,  115,  126,
-      127,  116,  128,  117,  118,  119,  120,  129,  121,  122,
-      130,  123,  131,  132,  124,  133,  134,  125,  135,  126,
-      127,  136,  128,  137,  138,  139,  140,  129,  141,  142,
-      130,  143,  131,  132,  144,  133,  134,  145,  135,  146,
-      147,  136,  148,  137,  138,  139,  140,  149,  141,  142,
-      150,  143,  151,  152,  144,  153,  154,  145,  155,  146,
-      147,  156,  148,  157,  158,  159,  160,  149,  161,  162,
-      150,  163,  151,  152,  164,  153,  154,  165,  155,  166,
-      167,  156,  168,  157,  158,  159,  160,  169,  161,  162,
-      170,  163,  171,  172,  164,  172,  172,  165,  172,  166,
-      167,  172,  168,  172,  172,  172,  172,  169,  172,  172,
-      170,  172,  171,    3,  172,  172,  172,  172,  172,  172,
+       17,   18,   19,    4,   20,    4,   21,   22,    4,    4,
+        4,   23,    4,   14,    4,   15,    4,   16,    4,    4,
+        4,   23,   24,   24,   24,   24,   25,   26,   28,   28,
+       31,   28,   34,   28,   32,   29,   26,   35,   36,   33,
+       37,   38,   30,   39,   40,   41,   43,   24,   24,   46,
+       31,   42,   34,   47,   32,   95,   48,   35,   36,   33,
+       37,   38,   30,   39,   40,   41,   43,   28,   28,   46,
+       28,   42,   28,   47,   49,   27,   48,   28,   28,   50,
+       28,   30,   28,   51,   44,   27,   44,   52,   45,   53,
+       54,   55,   56,   57,   49,   58,   59,   28,   28,   50,
+       28,   30,   28,   51,   60,   45,   61,   52,   62,   53,
+       54,   55,   56,   57,   63,   58,   59,   64,   65,   67,
+       66,   66,   68,   66,   60,   66,   61,   69,   62,   70,
+       71,   72,   73,   74,   63,   75,   76,   64,   65,   67,
+       77,   78,   68,   79,   80,   82,   83,   69,   84,   70,
+       71,   72,   73,   74,   85,   75,   76,   86,   87,   95,
+       77,   78,   92,   79,   80,   82,   83,   93,   84,   94,
+       81,   95,   45,   96,   85,   97,   98,   86,   87,   88,
+       99,  100,   92,  101,  102,  103,   89,   93,  104,  105,
+       90,  106,   91,   96,  107,   97,   98,  108,  109,   88,
+       99,  100,  110,  101,  102,  103,   89,  111,  104,  105,
+       90,  106,   91,  112,  107,  113,  114,  108,  109,  115,
+      116,  117,  110,  118,  119,  120,  121,  111,  122,  123,
+      124,  125,  126,  112,  127,  113,  114,  128,  129,  115,
+      116,  117,  130,  118,  119,  120,  121,  131,  122,  123,
+      124,  125,  126,  132,  127,  133,  134,  128,  129,  135,
+      136,  137,  130,  138,  139,  140,  141,  131,  142,  143,
+      144,  145,  146,  132,  147,  133,  134,  148,  149,  135,
+      136,  137,  150,  138,  139,  140,  141,  151,  142,  143,
+      144,  145,  146,  152,  147,  153,  154,  148,  149,  155,
+      156,  157,  150,  158,  159,  160,  161,  151,  162,  163,
+      164,  165,  166,  152,  167,  153,  154,  168,  169,  155,
+      156,  157,  170,  158,  159,  160,  161,  171,  162,  163,
+      164,  165,  166,  172,  167,  173,  174,  168,  169,  175,
+       27,   27,  170,  176,  176,  176,  176,  171,  176,  176,
+      176,  176,  176,  172,  176,  173,  174,  176,  176,  175,
+        3,  176,  176,  176,  176,  176,  176,  176,  176,  176,
+      176,  176,  176
-static const flex_int16_t yy_chk[437] =
+static yyconst flex_int16_t yy_chk[444] =
     {   0,
@@ -795,54 +565,55 @@ static const flex_int16_t yy_chk[437] =
         1,    1,    5,    5,    6,    6,   10,   10,   12,   12,
        14,   12,   15,   12,   14,   12,   12,   16,   17,   14,
-       18,   19,   12,   20,   22,   21,   23,   23,   91,   30,
-       14,   21,   15,   31,   14,   90,   32,   16,   17,   14,
-       18,   19,   12,   20,   22,   21,   65,   26,   26,   30,
-       26,   21,   26,   31,   33,   26,   32,   28,   28,   34,
-       28,   26,   28,   35,   29,   28,   29,   36,   29,   37,
-       37,   38,   39,   40,   33,   44,   45,   43,   43,   34,
-       43,   26,   43,   35,   46,   43,   47,   36,   48,   37,
-       37,   38,   39,   40,   49,   44,   45,   50,   51,   52,
-       53,   55,   56,   57,   46,   58,   47,   59,   48,   60,
-       61,   62,   63,   66,   49,   64,   64,   50,   51,   52,
-       53,   55,   56,   57,   67,   58,   68,   59,   69,   60,
-       61,   62,   63,   66,   71,   64,   64,   72,   42,   75,
-       76,   77,   78,   77,   67,   24,   68,   79,   69,   11,
-       80,    3,   81,   82,   71,   83,   84,   72,   73,   75,
-       76,   85,   78,   86,   87,   73,   88,   79,   89,   73,
-       80,   73,   81,   82,   92,   83,   84,   93,   73,   94,
-       95,   85,   96,   86,   87,   73,   88,   97,   89,   73,
-       98,   73,   99,  101,   92,  100,  100,   93,  103,   94,
-       95,  104,   96,  105,  106,  107,  108,   97,  109,  110,
-       98,  111,   99,  101,  112,  100,  100,  113,  103,  114,
-      115,  104,  117,  105,  106,  107,  108,  118,  109,  110,
-      119,  111,  120,  121,  112,  122,  123,  113,  124,  114,
-      115,  125,  117,  126,  127,  128,  129,  118,  130,  131,
-      119,  134,  120,  121,  136,  122,  123,  137,  124,  138,
-      139,  125,  140,  126,  127,  128,  129,  141,  130,  131,
-      142,  134,  143,  144,  136,  145,  146,  137,  147,  138,
-      139,  148,  140,  150,  151,  154,  155,  141,  157,  158,
-      142,  159,  143,  144,  161,  145,  146,  162,  147,  163,
-      164,  148,  166,  150,  151,  154,  155,  167,  157,  158,
-      168,  159,  169,    0,  161,    0,    0,  162,    0,  163,
-      164,    0,  166,    0,    0,    0,    0,  167,    0,    0,
-      168,    0,  169,  172,  172,  172,  172,  172,  172,  172,
+       18,   19,   12,   20,   21,   22,   23,   24,   24,   31,
+       14,   22,   15,   32,   14,   95,   33,   16,   17,   14,
+       18,   19,   12,   20,   21,   22,   23,   27,   27,   31,
+       27,   22,   27,   32,   34,   27,   33,   29,   29,   35,
+       29,   27,   29,   36,   30,   29,   30,   37,   30,   38,
+       39,   39,   40,   41,   34,   42,   46,   45,   45,   35,
+       45,   27,   45,   36,   47,   45,   48,   37,   49,   38,
+       39,   39,   40,   41,   50,   42,   46,   51,   52,   54,
+       53,   53,   55,   53,   47,   53,   48,   56,   49,   58,
+       59,   60,   61,   62,   50,   63,   64,   51,   52,   54,
+       65,   67,   55,   68,   68,   70,   71,   56,   72,   58,
+       59,   60,   61,   62,   73,   63,   64,   75,   76,   94,
+       65,   67,   79,   68,   68,   70,   71,   80,   72,   81,
+       69,   81,   44,   82,   73,   83,   84,   75,   76,   77,
+       85,   86,   79,   87,   88,   89,   77,   80,   90,   91,
+       77,   92,   77,   82,   93,   83,   84,   96,   97,   77,
+       85,   86,   98,   87,   88,   89,   77,   99,   90,   91,
+       77,   92,   77,  100,   93,  101,  102,   96,   97,  103,
+      104,  104,   98,  105,  107,  108,  109,   99,  110,  111,
+      112,  113,  114,  100,  115,  101,  102,  116,  117,  103,
+      104,  104,  118,  105,  107,  108,  109,  119,  110,  111,
+      112,  113,  114,  121,  115,  122,  123,  116,  117,  124,
+      125,  126,  118,  127,  128,  129,  130,  119,  131,  132,
+      133,  134,  135,  121,  138,  122,  123,  140,  141,  124,
+      125,  126,  142,  127,  128,  129,  130,  143,  131,  132,
+      133,  134,  135,  144,  138,  145,  146,  140,  141,  147,
+      148,  149,  142,  150,  151,  152,  154,  143,  155,  158,
+      159,  161,  162,  144,  163,  145,  146,  165,  166,  147,
+      148,  149,  167,  150,  151,  152,  154,  168,  155,  158,
+      159,  161,  162,  170,  163,  171,  172,  165,  166,  173,
+       25,   11,  167,    3,    0,    0,    0,  168,    0,    0,
+        0,    0,    0,  170,    0,  171,  172,    0,    0,  173,
+      176,  176,  176
 static yy_state_type yy_last_accepting_state;
 static char *yy_last_accepting_cpos;
-extern int yy_flex_debug;
-int yy_flex_debug = 0;
+extern int wkt_yy_flex_debug;
+int wkt_yy_flex_debug = 0;
 /* The intent behind this definition is that it'll catch
  * any uses of REJECT which flex missed.
@@ -851,7 +622,7 @@ int yy_flex_debug = 0;
 #define yymore() yymore_used_but_not_detected
 #define YY_MORE_ADJ 0
 #define YY_RESTORE_YY_MORE_OFFSET
-char *yytext;
+char *wkt_yytext;
 #line 1 "lwin_wkt_lex.l"
 #line 2 "lwin_wkt_lex.l"
@@ -883,17 +654,16 @@ static void wkt_lexer_unknown()
 * debugging info.
 #define YY_USER_ACTION do { \
-	wkt_yylloc.first_line = wkt_yylloc.last_line = yylineno; \
+	wkt_yylloc.first_line = wkt_yylloc.last_line = wkt_yylineno; \
 	wkt_yylloc.first_column = wkt_yylloc.last_column; \
-	wkt_yylloc.last_column += yyleng; \
+	wkt_yylloc.last_column += wkt_yyleng; \
 	LWDEBUGF(5,"lex: %s", wkt_yytext); \
 	} while (0);
-#line 893 "lwin_wkt_lex.c"
 #define YY_NO_INPUT 1
 /* Suppress the default implementations. */
-#line 896 "lwin_wkt_lex.c"
+#line 667 "lwin_wkt_lex.c"
 #define INITIAL 0
@@ -909,36 +679,36 @@ static void wkt_lexer_unknown()
 #define YY_EXTRA_TYPE void *
 #endif
-static int yy_init_globals ( void );
+static int yy_init_globals (void );
 /* Accessor methods to globals.
    These are made visible to non-reentrant scanners for convenience. */
-int yylex_destroy ( void );
+int wkt_yylex_destroy (void );
-int yyget_debug ( void );
+int wkt_yyget_debug (void );
-void yyset_debug ( int debug_flag  );
+void wkt_yyset_debug (int debug_flag  );
-YY_EXTRA_TYPE yyget_extra ( void );
+YY_EXTRA_TYPE wkt_yyget_extra (void );
-void yyset_extra ( YY_EXTRA_TYPE user_defined  );
+void wkt_yyset_extra (YY_EXTRA_TYPE user_defined  );
-FILE *yyget_in ( void );
+FILE *wkt_yyget_in (void );
-void yyset_in  ( FILE * _in_str  );
+void wkt_yyset_in  (FILE * in_str  );
-FILE *yyget_out ( void );
+FILE *wkt_yyget_out (void );
-void yyset_out  ( FILE * _out_str  );
+void wkt_yyset_out  (FILE * out_str  );
-			int yyget_leng ( void );
+yy_size_t wkt_yyget_leng (void );
-char *yyget_text ( void );
+char *wkt_yyget_text (void );
-int yyget_lineno ( void );
+int wkt_yyget_lineno (void );
-void yyset_lineno ( int _line_number  );
+void wkt_yyset_lineno (int line_number  );
 /* Macros after this point can all be overridden by user definitions in
  * section 1.
@@ -946,41 +716,33 @@ void yyset_lineno ( int _line_number  );
 #ifndef YY_SKIP_YYWRAP
 #ifdef __cplusplus
-extern "C" int yywrap ( void );
+extern "C" int wkt_yywrap (void );
 #else
-extern int yywrap ( void );
+extern int wkt_yywrap (void );
 #endif
 #endif
-#ifndef YY_NO_UNPUT
-#endif
 #ifndef yytext_ptr
-static void yy_flex_strncpy ( char *, const char *, int );
+static void yy_flex_strncpy (char *,yyconst char *,int );
 #endif
 #ifdef YY_NEED_STRLEN
-static int yy_flex_strlen ( const char * );
+static int yy_flex_strlen (yyconst char * );
 #endif
 #ifndef YY_NO_INPUT
 #ifdef __cplusplus
-static int yyinput ( void );
+static int yyinput (void );
 #else
-static int input ( void );
+static int input (void );
 #endif
 #endif
 /* Amount of stuff to slurp up with each read. */
 #ifndef YY_READ_BUF_SIZE
-#ifdef __ia64__
-/* On IA-64, the buffer size is 16k, not 8k */
-#define YY_READ_BUF_SIZE 16384
-#else
 #define YY_READ_BUF_SIZE 8192
 #endif
 /* Copy whatever the last rule matched to the standard output. */
@@ -988,7 +750,7 @@ static int input ( void );
 /* This used to be an fputs(), but since the string might contain NUL's,
  * we now use fwrite().
-#define ECHO do { if (fwrite( yytext, (size_t) yyleng, 1, yyout )) {} } while (0)
+#define ECHO fwrite( wkt_yytext, wkt_yyleng, 1, wkt_yyout )
 #endif
 /* Gets input and stuffs it into "buf".  number of characters read, or YY_NULL,
@@ -999,20 +761,20 @@ static int input ( void );
 	if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \
 		int c = '*'; \
-		int n; \
+		yy_size_t n; \
 		for ( n = 0; n < max_size && \
-			     (c = getc( yyin )) != EOF && c != '\n'; ++n ) \
+			     (c = getc( wkt_yyin )) != EOF && c != '\n'; ++n ) \
 			buf[n] = (char) c; \
 		if ( c == '\n' ) \
 			buf[n++] = (char) c; \
-		if ( c == EOF && ferror( yyin ) ) \
+		if ( c == EOF && ferror( wkt_yyin ) ) \
 			YY_FATAL_ERROR( "input in flex scanner failed" ); \
 		result = n; \
 	else \
 		errno=0; \
-		while ( (result = (int) fread(buf, 1, (yy_size_t) max_size, yyin)) == 0 && ferror(yyin)) \
+		while ( (result = fread(buf, 1, max_size, wkt_yyin))==0 && ferror(wkt_yyin)) \
 			if( errno != EINTR) \
@@ -1020,7 +782,7 @@ static int input ( void );
 				break; \
 			errno=0; \
-			clearerr(yyin); \
+			clearerr(wkt_yyin); \
@@ -1053,12 +815,12 @@ static int input ( void );
 #ifndef YY_DECL
 #define YY_DECL_IS_OURS 1
-extern int yylex (void);
+extern int wkt_yylex (void);
-#define YY_DECL int yylex (void)
+#define YY_DECL int wkt_yylex (void)
 #endif /* !YY_DECL */
-/* Code executed at the beginning of each rule, after yytext and yyleng
+/* Code executed at the beginning of each rule, after wkt_yytext and wkt_yyleng
  * have been set up.
 #ifndef YY_USER_ACTION
@@ -1067,7 +829,7 @@ extern int yylex (void);
 /* Code executed at the end of each rule. */
 #ifndef YY_BREAK
-#define YY_BREAK /*LINTED*/break;
+#define YY_BREAK break;
 #endif
 #define YY_RULE_SETUP \
@@ -1077,10 +839,15 @@ extern int yylex (void);
 YY_DECL
-	yy_state_type yy_current_state;
-	char *yy_cp, *yy_bp;
-	int yy_act;
+	register yy_state_type yy_current_state;
+	register char *yy_cp, *yy_bp;
+	register int yy_act;
+#line 49 "lwin_wkt_lex.l"
+#line 850 "lwin_wkt_lex.c"
 	if ( !(yy_init) )
 		(yy_init) = 1;
@@ -1092,32 +859,26 @@ YY_DECL
 		if ( ! (yy_start) )
 			(yy_start) = 1;	/* first start state */
-		if ( ! yyin )
-			yyin = stdin;
+		if ( ! wkt_yyin )
+			wkt_yyin = stdin;
-		if ( ! yyout )
-			yyout = stdout;
+		if ( ! wkt_yyout )
+			wkt_yyout = stdout;
 		if ( ! YY_CURRENT_BUFFER ) {
-		yy_load_buffer_state(  );
+		wkt_yy_load_buffer_state( );
-#line 49 "lwin_wkt_lex.l"
-#line 1114 "lwin_wkt_lex.c"
-	while ( /*CONSTCOND*/1 )		/* loops until end-of-file is reached */
+	while ( 1 )		/* loops until end-of-file is reached */
 		yy_cp = (yy_c_buf_p);
-		/* Support of yytext. */
+		/* Support of wkt_yytext. */
 		/* yy_bp points to the position in yy_ch_buf of the start of
@@ -1129,7 +890,7 @@ YY_DECL
 yy_match:
 		do
-			YY_CHAR yy_c = yy_ec[YY_SC_TO_UI(*yy_cp)] ;
+			register YY_CHAR yy_c = yy_ec[YY_SC_TO_UI(*yy_cp)];
 			if ( yy_accept[yy_current_state] )
 				(yy_last_accepting_state) = yy_current_state;
@@ -1138,13 +899,13 @@ yy_match:
 			while ( yy_chk[yy_base[yy_current_state] + yy_c] != yy_current_state )
 				yy_current_state = (int) yy_def[yy_current_state];
-				if ( yy_current_state >= 173 )
-					yy_c = yy_meta[yy_c];
+				if ( yy_current_state >= 177 )
+					yy_c = yy_meta[(unsigned int) yy_c];
-			yy_current_state = yy_nxt[yy_base[yy_current_state] + yy_c];
+			yy_current_state = yy_nxt[yy_base[yy_current_state] + (unsigned int) yy_c];
 			++yy_cp;
-		while ( yy_current_state != 172 );
+		while ( yy_current_state != 176 );
 		yy_cp = (yy_last_accepting_cpos);
 		yy_current_state = (yy_last_accepting_state);
@@ -1176,144 +937,155 @@ YY_RULE_SETUP
 	YY_BREAK
 case 2:
+/* rule 2 can match eol */
 YY_RULE_SETUP
 #line 58 "lwin_wkt_lex.l"
+	LWDEBUG(5,"DOUBLE NAN");
+	wkt_yylval.doublevalue = atof(wkt_yytext);
+	yyless(wkt_yyleng-1);
+	return DOUBLE_TOK;
+	YY_BREAK
+case 3:
+YY_RULE_SETUP
+#line 65 "lwin_wkt_lex.l"
 	LWDEBUG(5,"SRID");
 	wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
 	return SRID_TOK;
 	YY_BREAK
-case 3:
+case 4:
 YY_RULE_SETUP
-#line 64 "lwin_wkt_lex.l"
+#line 71 "lwin_wkt_lex.l"
 { return COLLECTION_TOK; }
 	YY_BREAK
-case 4:
+case 5:
 YY_RULE_SETUP
-#line 65 "lwin_wkt_lex.l"
+#line 72 "lwin_wkt_lex.l"
 { return MSURFACE_TOK; }
 	YY_BREAK
-case 5:
+case 6:
 YY_RULE_SETUP
-#line 66 "lwin_wkt_lex.l"
+#line 73 "lwin_wkt_lex.l"
 { return MPOLYGON_TOK; }
 	YY_BREAK
-case 6:
+case 7:
 YY_RULE_SETUP
-#line 67 "lwin_wkt_lex.l"
+#line 74 "lwin_wkt_lex.l"
 { return MCURVE_TOK; }
 	YY_BREAK
-case 7:
+case 8:
 YY_RULE_SETUP
-#line 68 "lwin_wkt_lex.l"
+#line 75 "lwin_wkt_lex.l"
 { return MLINESTRING_TOK; }
 	YY_BREAK
-case 8:
+case 9:
 YY_RULE_SETUP
-#line 69 "lwin_wkt_lex.l"
+#line 76 "lwin_wkt_lex.l"
 { return MPOINT_TOK; }
 	YY_BREAK
-case 9:
+case 10:
 YY_RULE_SETUP
-#line 70 "lwin_wkt_lex.l"
+#line 77 "lwin_wkt_lex.l"
 { return CURVEPOLYGON_TOK; }
 	YY_BREAK
-case 10:
+case 11:
 YY_RULE_SETUP
-#line 71 "lwin_wkt_lex.l"
+#line 78 "lwin_wkt_lex.l"
 { return POLYGON_TOK; }
 	YY_BREAK
-case 11:
+case 12:
 YY_RULE_SETUP
-#line 72 "lwin_wkt_lex.l"
+#line 79 "lwin_wkt_lex.l"
 { return COMPOUNDCURVE_TOK; }
 	YY_BREAK
-case 12:
+case 13:
 YY_RULE_SETUP
-#line 73 "lwin_wkt_lex.l"
+#line 80 "lwin_wkt_lex.l"
 { return CIRCULARSTRING_TOK; }
 	YY_BREAK
-case 13:
+case 14:
 YY_RULE_SETUP
-#line 74 "lwin_wkt_lex.l"
+#line 81 "lwin_wkt_lex.l"
 { return LINESTRING_TOK; }
 	YY_BREAK
-case 14:
+case 15:
 YY_RULE_SETUP
-#line 75 "lwin_wkt_lex.l"
+#line 82 "lwin_wkt_lex.l"
 { return POLYHEDRALSURFACE_TOK; }
 	YY_BREAK
-case 15:
+case 16:
 YY_RULE_SETUP
-#line 76 "lwin_wkt_lex.l"
+#line 83 "lwin_wkt_lex.l"
 { return TRIANGLE_TOK; }
 	YY_BREAK
-case 16:
+case 17:
 YY_RULE_SETUP
-#line 77 "lwin_wkt_lex.l"
+#line 84 "lwin_wkt_lex.l"
 { return TIN_TOK; }
 	YY_BREAK
-case 17:
+case 18:
 YY_RULE_SETUP
-#line 78 "lwin_wkt_lex.l"
+#line 85 "lwin_wkt_lex.l"
 { return POINT_TOK; }
 	YY_BREAK
-case 18:
+case 19:
 YY_RULE_SETUP
-#line 79 "lwin_wkt_lex.l"
+#line 86 "lwin_wkt_lex.l"
 { return EMPTY_TOK; }
 	YY_BREAK
-case 19:
+case 20:
 YY_RULE_SETUP
-#line 81 "lwin_wkt_lex.l"
+#line 88 "lwin_wkt_lex.l"
 	LWDEBUG(5,"DIMENSIONALITY");
 	wkt_yylval.stringvalue = wkt_yytext;
 	return DIMENSIONALITY_TOK;
 	YY_BREAK
-case 20:
+case 21:
 YY_RULE_SETUP
-#line 87 "lwin_wkt_lex.l"
+#line 94 "lwin_wkt_lex.l"
 { LWDEBUG(5,"LBRACKET"); return LBRACKET_TOK; }
 	YY_BREAK
-case 21:
+case 22:
 YY_RULE_SETUP
-#line 88 "lwin_wkt_lex.l"
+#line 95 "lwin_wkt_lex.l"
 { LWDEBUG(5,"RBRACKET"); return RBRACKET_TOK; }
 	YY_BREAK
-case 22:
+case 23:
 YY_RULE_SETUP
-#line 89 "lwin_wkt_lex.l"
+#line 96 "lwin_wkt_lex.l"
 { LWDEBUG(5,"COMMA"); return COMMA_TOK; }
 	YY_BREAK
-case 23:
+case 24:
 YY_RULE_SETUP
-#line 90 "lwin_wkt_lex.l"
+#line 97 "lwin_wkt_lex.l"
 { LWDEBUG(5,"SEMICOLON"); return SEMICOLON_TOK; }
 	YY_BREAK
-case 24:
-/* rule 24 can match eol */
+case 25:
+/* rule 25 can match eol */
 YY_RULE_SETUP
-#line 92 "lwin_wkt_lex.l"
+#line 99 "lwin_wkt_lex.l"
 { /* ignore whitespace */ LWDEBUG(5,"WHITESPACE"); }
 	YY_BREAK
-case 25:
+case 26:
 YY_RULE_SETUP
-#line 94 "lwin_wkt_lex.l"
+#line 101 "lwin_wkt_lex.l"
 { /* Error out and stop parsing on unknown/unexpected characters */
 	LWDEBUG(5,"UNKNOWN");
 	wkt_lexer_unknown();
 	yyterminate();
 	YY_BREAK
-case 26:
+case 27:
 YY_RULE_SETUP
-#line 100 "lwin_wkt_lex.l"
+#line 107 "lwin_wkt_lex.l"
 ECHO;
 	YY_BREAK
-#line 1316 "lwin_wkt_lex.c"
+#line 1089 "lwin_wkt_lex.c"
 case YY_STATE_EOF(INITIAL):
 	yyterminate();
@@ -1330,15 +1102,15 @@ case YY_STATE_EOF(INITIAL):
 			/* We're scanning a new file or input source.  It's
 			 * possible that this happened because the user
-			 * just pointed yyin at a new source and called
-			 * yylex().  If so, then we have to assure
+			 * just pointed wkt_yyin at a new source and called
+			 * wkt_yylex().  If so, then we have to assure
 			 * consistency between YY_CURRENT_BUFFER and our
 			 * globals.  Here is the right place to do so, because
 			 * this is the first action (other than possibly a
 			 * back-up) that will match for the new input source.
 			(yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_n_chars;
-			YY_CURRENT_BUFFER_LVALUE->yy_input_file = yyin;
+			YY_CURRENT_BUFFER_LVALUE->yy_input_file = wkt_yyin;
 			YY_CURRENT_BUFFER_LVALUE->yy_buffer_status = YY_BUFFER_NORMAL;
@@ -1392,11 +1164,11 @@ case YY_STATE_EOF(INITIAL):
 				(yy_did_buffer_switch_on_eof) = 0;
-				if ( yywrap(  ) )
+				if ( wkt_yywrap( ) )
 					/* Note: because we've taken care in
 					 * yy_get_next_buffer() to have set up
-					 * yytext, we can now set up
+					 * wkt_yytext, we can now set up
 					 * yy_c_buf_p so that if some total
 					 * hoser (like flex itself) wants to
 					 * call the scanner after we return the
@@ -1445,8 +1217,7 @@ case YY_STATE_EOF(INITIAL):
 			"fatal flex scanner internal error--no action found" );
 	} /* end of action switch */
 		} /* end of scanning one token */
-	} /* end of user's declarations */
-} /* end of yylex */
+} /* end of wkt_yylex */
 /* yy_get_next_buffer - try to read in a new buffer
@@ -1457,9 +1228,9 @@ case YY_STATE_EOF(INITIAL):
 static int yy_get_next_buffer (void)
-    	char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf;
-	char *source = (yytext_ptr);
-	int number_to_move, i;
+    	register char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf;
+	register char *source = (yytext_ptr);
+	register int number_to_move, i;
 	int ret_val;
 	if ( (yy_c_buf_p) > &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] )
@@ -1488,7 +1259,7 @@ static int yy_get_next_buffer (void)
 	/* Try to read more data. */
 	/* First move last chars to start of buffer. */
-	number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr) - 1);
+	number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr)) - 1;
 	for ( i = 0; i < number_to_move; ++i )
 		*(dest++) = *(source++);
@@ -1501,21 +1272,21 @@ static int yy_get_next_buffer (void)
 	else
-			int num_to_read =
+			yy_size_t num_to_read =
 			YY_CURRENT_BUFFER_LVALUE->yy_buf_size - number_to_move - 1;
 		while ( num_to_read <= 0 )
 			{ /* Not enough room in the buffer - grow it. */
 			/* just a shorter name for the current buffer */
-			YY_BUFFER_STATE b = YY_CURRENT_BUFFER_LVALUE;
+			YY_BUFFER_STATE b = YY_CURRENT_BUFFER;
 			int yy_c_buf_p_offset =
 				(int) ((yy_c_buf_p) - b->yy_ch_buf);
 			if ( b->yy_is_our_buffer )
-				int new_size = b->yy_buf_size * 2;
+				yy_size_t new_size = b->yy_buf_size * 2;
 				if ( new_size <= 0 )
 					b->yy_buf_size += b->yy_buf_size / 8;
@@ -1524,12 +1295,11 @@ static int yy_get_next_buffer (void)
 				b->yy_ch_buf = (char *)
 					/* Include room in for 2 EOB chars. */
-					yyrealloc( (void *) b->yy_ch_buf,
-							 (yy_size_t) (b->yy_buf_size + 2)  );
+					wkt_yyrealloc((void *) b->yy_ch_buf,b->yy_buf_size + 2  );
 			else
 				/* Can't grow it, we don't own it. */
-				b->yy_ch_buf = NULL;
+				b->yy_ch_buf = 0;
 			if ( ! b->yy_ch_buf )
 				YY_FATAL_ERROR(
@@ -1557,7 +1327,7 @@ static int yy_get_next_buffer (void)
 		if ( number_to_move == YY_MORE_ADJ )
 			ret_val = EOB_ACT_END_OF_FILE;
-			yyrestart( yyin  );
+			wkt_yyrestart(wkt_yyin  );
 		else
@@ -1571,15 +1341,12 @@ static int yy_get_next_buffer (void)
 	else
 		ret_val = EOB_ACT_CONTINUE_SCAN;
-	if (((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) {
+	if ((yy_size_t) ((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) {
 		/* Extend the array by 50%, plus the number we really need. */
-		int new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1);
-		YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) yyrealloc(
-			(void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf, (yy_size_t) new_size  );
+		yy_size_t new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1);
+		YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) wkt_yyrealloc((void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf,new_size  );
 		if ( ! YY_CURRENT_BUFFER_LVALUE->yy_ch_buf )
 			YY_FATAL_ERROR( "out of dynamic memory in yy_get_next_buffer()" );
-		/* "- 2" to take care of EOB's */
-		YY_CURRENT_BUFFER_LVALUE->yy_buf_size = (int) (new_size - 2);
 	(yy_n_chars) += number_to_move;
@@ -1595,14 +1362,14 @@ static int yy_get_next_buffer (void)
     static yy_state_type yy_get_previous_state (void)
-	char *yy_cp;
+	register char *yy_cp;
 	yy_current_state = (yy_start);
 	for ( yy_cp = (yytext_ptr) + YY_MORE_ADJ; yy_cp < (yy_c_buf_p); ++yy_cp )
-		YY_CHAR yy_c = (*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1);
+		register YY_CHAR yy_c = (*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1);
@@ -1611,10 +1378,10 @@ static int yy_get_next_buffer (void)
 	return yy_current_state;
@@ -1627,10 +1394,10 @@ static int yy_get_next_buffer (void)
     static yy_state_type yy_try_NUL_trans  (yy_state_type yy_current_state )
-	int yy_is_jam;
-    	char *yy_cp = (yy_c_buf_p);
+	register int yy_is_jam;
+    	register char *yy_cp = (yy_c_buf_p);
-	YY_CHAR yy_c = 1;
+	register YY_CHAR yy_c = 1;
@@ -1639,19 +1406,15 @@ static int yy_get_next_buffer (void)
-	yy_is_jam = (yy_current_state == 172);
+	yy_is_jam = (yy_current_state == 176);
-		return yy_is_jam ? 0 : yy_current_state;
+	return yy_is_jam ? 0 : yy_current_state;
-#endif
 #ifndef YY_NO_INPUT
 #ifdef __cplusplus
     static int yyinput (void)
@@ -1676,7 +1439,7 @@ static int yy_get_next_buffer (void)
 		else
 			{ /* need more input */
-			int offset = (int) ((yy_c_buf_p) - (yytext_ptr));
+			yy_size_t offset = (yy_c_buf_p) - (yytext_ptr);
 			++(yy_c_buf_p);
 			switch ( yy_get_next_buffer(  ) )
@@ -1693,13 +1456,13 @@ static int yy_get_next_buffer (void)
 					/* Reset buffer status. */
 					/*FALLTHROUGH*/
 				case EOB_ACT_END_OF_FILE:
-					if ( yywrap(  ) )
 						return 0;
 					if ( ! (yy_did_buffer_switch_on_eof) )
@@ -1719,7 +1482,7 @@ static int yy_get_next_buffer (void)
 	c = *(unsigned char *) (yy_c_buf_p);	/* cast for 8-bit char's */
-	*(yy_c_buf_p) = '\0';	/* preserve yytext */
+	*(yy_c_buf_p) = '\0';	/* preserve wkt_yytext */
 	(yy_hold_char) = *++(yy_c_buf_p);
 	return c;
@@ -1731,32 +1494,32 @@ static int yy_get_next_buffer (void)
  * @note This function does not reset the start condition to @c INITIAL .
-    void yyrestart  (FILE * input_file )
+    void wkt_yyrestart  (FILE * input_file )
-	yy_init_buffer( YY_CURRENT_BUFFER, input_file );
+	wkt_yy_init_buffer(YY_CURRENT_BUFFER,input_file );
 /** Switch to a different input buffer.
  * @param new_buffer The new input buffer.
-    void yy_switch_to_buffer  (YY_BUFFER_STATE  new_buffer )
+    void wkt_yy_switch_to_buffer  (YY_BUFFER_STATE  new_buffer )
 	/* TODO. We should be able to replace this entire function body
 	 * with
-	 *		yypop_buffer_state();
-	 *		yypush_buffer_state(new_buffer);
+	 *		wkt_yypop_buffer_state();
+	 *		wkt_yypush_buffer_state(new_buffer);
 	if ( YY_CURRENT_BUFFER == new_buffer )
 		return;
@@ -1769,21 +1532,21 @@ static int yy_get_next_buffer (void)
 	YY_CURRENT_BUFFER_LVALUE = new_buffer;
 	/* We don't actually know whether we did this switch during
-	 * EOF (yywrap()) processing, but the only time this flag
-	 * is looked at is after yywrap() is called, so it's safe
+	 * EOF (wkt_yywrap()) processing, but the only time this flag
+	 * is looked at is after wkt_yywrap() is called, so it's safe
 	 * to go ahead and always set it.
 	(yy_did_buffer_switch_on_eof) = 1;
-static void yy_load_buffer_state  (void)
+static void wkt_yy_load_buffer_state  (void)
 	(yytext_ptr) = (yy_c_buf_p) = YY_CURRENT_BUFFER_LVALUE->yy_buf_pos;
-	yyin = YY_CURRENT_BUFFER_LVALUE->yy_input_file;
+	wkt_yyin = YY_CURRENT_BUFFER_LVALUE->yy_input_file;
 	(yy_hold_char) = *(yy_c_buf_p);
@@ -1793,35 +1556,35 @@ static void yy_load_buffer_state  (void)
  * @return the allocated buffer state.
-    YY_BUFFER_STATE yy_create_buffer  (FILE * file, int  size )
+    YY_BUFFER_STATE wkt_yy_create_buffer  (FILE * file, int  size )
 	YY_BUFFER_STATE b;
-	b = (YY_BUFFER_STATE) yyalloc( sizeof( struct yy_buffer_state )  );
+	b = (YY_BUFFER_STATE) wkt_yyalloc(sizeof( struct yy_buffer_state )  );
 	if ( ! b )
-		YY_FATAL_ERROR( "out of dynamic memory in yy_create_buffer()" );
+		YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_create_buffer()" );
 	b->yy_buf_size = size;
 	/* yy_ch_buf has to be 2 characters longer than the size given because
 	 * we need to put in 2 end-of-buffer characters.
-	b->yy_ch_buf = (char *) yyalloc( (yy_size_t) (b->yy_buf_size + 2)  );
+	b->yy_ch_buf = (char *) wkt_yyalloc(b->yy_buf_size + 2  );
 	b->yy_is_our_buffer = 1;
-	yy_init_buffer( b, file );
+	wkt_yy_init_buffer(b,file );
 	return b;
 /** Destroy the buffer.
- * @param b a buffer created with yy_create_buffer()
+ * @param b a buffer created with wkt_yy_create_buffer()
-    void yy_delete_buffer (YY_BUFFER_STATE  b )
+    void wkt_yy_delete_buffer (YY_BUFFER_STATE  b )
 	if ( ! b )
@@ -1831,27 +1594,27 @@ static void yy_load_buffer_state  (void)
 		YY_CURRENT_BUFFER_LVALUE = (YY_BUFFER_STATE) 0;
-		yyfree( (void *) b->yy_ch_buf  );
+		wkt_yyfree((void *) b->yy_ch_buf  );
-	yyfree( (void *) b  );
+	wkt_yyfree((void *) b  );
 /* Initializes or reinitializes a buffer.
  * This function is sometimes called more than once on the same buffer,
- * such as during a yyrestart() or at EOF.
+ * such as during a wkt_yyrestart() or at EOF.
-    static void yy_init_buffer  (YY_BUFFER_STATE  b, FILE * file )
+    static void wkt_yy_init_buffer  (YY_BUFFER_STATE  b, FILE * file )
 	int oerrno = errno;
-	yy_flush_buffer( b );
+	wkt_yy_flush_buffer(b );
 	b->yy_input_file = file;
 	b->yy_fill_buffer = 1;
-    /* If b is the current buffer, then yy_init_buffer was _probably_
-     * called from yyrestart() or through yy_get_next_buffer.
+    /* If b is the current buffer, then wkt_yy_init_buffer was _probably_
+     * called from wkt_yyrestart() or through yy_get_next_buffer.
      * In that case, we don't want to reset the lineno or column.
     if (b != YY_CURRENT_BUFFER){
@@ -1868,7 +1631,7 @@ static void yy_load_buffer_state  (void)
  * @param b the buffer state to be flushed, usually @c YY_CURRENT_BUFFER.
-    void yy_flush_buffer (YY_BUFFER_STATE  b )
+    void wkt_yy_flush_buffer (YY_BUFFER_STATE  b )
     	if ( ! b )
 		return;
@@ -1888,7 +1651,7 @@ static void yy_load_buffer_state  (void)
 	b->yy_buffer_status = YY_BUFFER_NEW;
 	if ( b == YY_CURRENT_BUFFER )
 /** Pushes the new state onto the stack. The new state becomes
@@ -1897,14 +1660,14 @@ static void yy_load_buffer_state  (void)
  *  @param new_buffer The new state.
-void yypush_buffer_state (YY_BUFFER_STATE new_buffer )
     	if (new_buffer == NULL)
 		return;
-	yyensure_buffer_stack();
+	wkt_yyensure_buffer_stack();
-	/* This block is copied from yy_switch_to_buffer. */
+	/* This block is copied from wkt_yy_switch_to_buffer. */
 	if ( YY_CURRENT_BUFFER )
 		/* Flush out information for old buffer. */
@@ -1918,8 +1681,8 @@ void yypush_buffer_state (YY_BUFFER_STATE new_buffer )
 		(yy_buffer_stack_top)++;
-	/* copied from yy_switch_to_buffer. */
+	/* copied from wkt_yy_switch_to_buffer. */
@@ -1927,18 +1690,18 @@ void yypush_buffer_state (YY_BUFFER_STATE new_buffer )
  *  The next element becomes the new top.
-void yypop_buffer_state (void)
+void wkt_yypop_buffer_state (void)
     	if (!YY_CURRENT_BUFFER)
 		return;
-	yy_delete_buffer(YY_CURRENT_BUFFER );
+	wkt_yy_delete_buffer(YY_CURRENT_BUFFER );
 	YY_CURRENT_BUFFER_LVALUE = NULL;
 	if ((yy_buffer_stack_top) > 0)
 		--(yy_buffer_stack_top);
 	if (YY_CURRENT_BUFFER) {
@@ -1946,7 +1709,7 @@ void yypop_buffer_state (void)
 /* Allocates the stack if it does not exist.
  *  Guarantees space for at least one push.
-static void yyensure_buffer_stack (void)
+static void wkt_yyensure_buffer_stack (void)
 	yy_size_t num_to_alloc;
@@ -1956,15 +1719,15 @@ static void yyensure_buffer_stack (void)
 		 * scanner will even need a stack. We use 2 instead of 1 to avoid an
 		 * immediate realloc on the next call.
-      num_to_alloc = 1; /* After all that talk, this was set to 1 anyways... */
-		(yy_buffer_stack) = (struct yy_buffer_state**)yyalloc
+		num_to_alloc = 1;
+		(yy_buffer_stack) = (struct yy_buffer_state**)wkt_yyalloc
 								(num_to_alloc * sizeof(struct yy_buffer_state*)
 		if ( ! (yy_buffer_stack) )
-			YY_FATAL_ERROR( "out of dynamic memory in yyensure_buffer_stack()" );
+			YY_FATAL_ERROR( "out of dynamic memory in wkt_yyensure_buffer_stack()" );
 		memset((yy_buffer_stack), 0, num_to_alloc * sizeof(struct yy_buffer_state*));
 		(yy_buffer_stack_max) = num_to_alloc;
 		(yy_buffer_stack_top) = 0;
 		return;
@@ -1973,15 +1736,15 @@ static void yyensure_buffer_stack (void)
 	if ((yy_buffer_stack_top) >= ((yy_buffer_stack_max)) - 1){
 		/* Increase the buffer to prepare for a possible push. */
-		yy_size_t grow_size = 8 /* arbitrary grow size */;
+		int grow_size = 8 /* arbitrary grow size */;
 		num_to_alloc = (yy_buffer_stack_max) + grow_size;
-		(yy_buffer_stack) = (struct yy_buffer_state**)yyrealloc
+		(yy_buffer_stack) = (struct yy_buffer_state**)wkt_yyrealloc
 								((yy_buffer_stack),
 		/* zero only the new slots.*/
 		memset((yy_buffer_stack) + (yy_buffer_stack_max), 0, grow_size * sizeof(struct yy_buffer_state*));
@@ -1993,9 +1756,9 @@ static void yyensure_buffer_stack (void)
  * @param base the character buffer
  * @param size the size in bytes of the character buffer
- * @return the newly allocated buffer state object.
+ * @return the newly allocated buffer state object.
-YY_BUFFER_STATE yy_scan_buffer  (char * base, yy_size_t  size )
+YY_BUFFER_STATE wkt_yy_scan_buffer  (char * base, yy_size_t  size )
 	YY_BUFFER_STATE b;
@@ -2003,69 +1766,68 @@ YY_BUFFER_STATE yy_scan_buffer  (char * base, yy_size_t  size )
 	     base[size-2] != YY_END_OF_BUFFER_CHAR ||
 	     base[size-1] != YY_END_OF_BUFFER_CHAR )
 		/* They forgot to leave room for the EOB's. */
-		return NULL;
+		return 0;
 	if ( ! b )
-		YY_FATAL_ERROR( "out of dynamic memory in yy_scan_buffer()" );
+		YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_scan_buffer()" );
-	b->yy_buf_size = (int) (size - 2);	/* "- 2" to take care of EOB's */
+	b->yy_buf_size = size - 2;	/* "- 2" to take care of EOB's */
 	b->yy_buf_pos = b->yy_ch_buf = base;
 	b->yy_is_our_buffer = 0;
-	b->yy_input_file = NULL;
+	b->yy_input_file = 0;
 	b->yy_n_chars = b->yy_buf_size;
 	b->yy_is_interactive = 0;
 	b->yy_at_bol = 1;
 	b->yy_fill_buffer = 0;
-	yy_switch_to_buffer( b  );
+	wkt_yy_switch_to_buffer(b  );
 	return b;
-/** Setup the input buffer state to scan a string. The next call to yylex() will
+/** Setup the input buffer state to scan a string. The next call to wkt_yylex() will
  * scan from a @e copy of @a str.
  * @param yystr a NUL-terminated string to scan
  * @note If you want to scan bytes that may contain NUL values, then use
- *       yy_scan_bytes() instead.
+ *       wkt_yy_scan_bytes() instead.
-YY_BUFFER_STATE yy_scan_string (const char * yystr )
+YY_BUFFER_STATE wkt_yy_scan_string (yyconst char * yystr )
-	return yy_scan_bytes( yystr, (int) strlen(yystr) );
+	return wkt_yy_scan_bytes(yystr,strlen(yystr) );
-/** Setup the input buffer state to scan the given bytes. The next call to yylex() will
+/** Setup the input buffer state to scan the given bytes. The next call to wkt_yylex() will
  * scan from a @e copy of @a bytes.
- * @param yybytes the byte buffer to scan
- * @param _yybytes_len the number of bytes in the buffer pointed to by @a bytes.
+ * @param bytes the byte buffer to scan
+ * @param len the number of bytes in the buffer pointed to by @a bytes.
-YY_BUFFER_STATE yy_scan_bytes  (const char * yybytes, int  _yybytes_len )
+YY_BUFFER_STATE wkt_yy_scan_bytes  (yyconst char * yybytes, yy_size_t  _yybytes_len )
 	YY_BUFFER_STATE b;
 	char *buf;
-	yy_size_t n;
-	int i;
+	yy_size_t n, i;
 	/* Get memory for full buffer, including space for trailing EOB's. */
-	n = (yy_size_t) (_yybytes_len + 2);
-	buf = (char *) yyalloc( n  );
+	n = _yybytes_len + 2;
+	buf = (char *) wkt_yyalloc(n  );
 	if ( ! buf )
-		YY_FATAL_ERROR( "out of dynamic memory in yy_scan_bytes()" );
+		YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_scan_bytes()" );
 	for ( i = 0; i < _yybytes_len; ++i )
 		buf[i] = yybytes[i];
 	buf[_yybytes_len] = buf[_yybytes_len+1] = YY_END_OF_BUFFER_CHAR;
-	b = yy_scan_buffer( buf, n );
+	b = wkt_yy_scan_buffer(buf,n );
 	if ( ! b )
-		YY_FATAL_ERROR( "bad buffer in yy_scan_bytes()" );
+		YY_FATAL_ERROR( "bad buffer in wkt_yy_scan_bytes()" );
 	/* It's okay to grow etc. this buffer, and we should throw it
 	 * away when we're done.
@@ -2079,9 +1841,9 @@ YY_BUFFER_STATE yy_scan_bytes  (const char * yybytes, int  _yybytes_len )
 #define YY_EXIT_FAILURE 2
 #endif
-static void yynoreturn yy_fatal_error (const char* msg )
+static void yy_fatal_error (yyconst char* msg )
-			fprintf( stderr, "%s\n", msg );
+    	(void) fprintf( stderr, "%s\n", msg );
 	exit( YY_EXIT_FAILURE );
@@ -2091,14 +1853,14 @@ static void yynoreturn yy_fatal_error (const char* msg )
 #define yyless(n) \
 	do \
-		yytext[yyleng] = (yy_hold_char); \
-		(yy_c_buf_p) = yytext + yyless_macro_arg; \
+		wkt_yytext[wkt_yyleng] = (yy_hold_char); \
+		(yy_c_buf_p) = wkt_yytext + yyless_macro_arg; \
 		(yy_hold_char) = *(yy_c_buf_p); \
 		*(yy_c_buf_p) = '\0'; \
-		yyleng = yyless_macro_arg; \
+		wkt_yyleng = yyless_macro_arg; \
 	while ( 0 )
@@ -2107,126 +1869,126 @@ static void yynoreturn yy_fatal_error (const char* msg )
 /** Get the current line number.
-int yyget_lineno  (void)
+int wkt_yyget_lineno  (void)
-    return yylineno;
+    return wkt_yylineno;
 /** Get the input stream.
-FILE *yyget_in  (void)
+FILE *wkt_yyget_in  (void)
-        return yyin;
+        return wkt_yyin;
 /** Get the output stream.
-FILE *yyget_out  (void)
+FILE *wkt_yyget_out  (void)
-        return yyout;
+        return wkt_yyout;
 /** Get the length of the current token.
-int yyget_leng  (void)
+yy_size_t wkt_yyget_leng  (void)
-        return yyleng;
+        return wkt_yyleng;
 /** Get the current token.
-char *yyget_text  (void)
+char *wkt_yyget_text  (void)
-        return yytext;
+        return wkt_yytext;
 /** Set the current line number.
- * @param _line_number line number
+ * @param line_number
-void yyset_lineno (int  _line_number )
-    yylineno = _line_number;
+    wkt_yylineno = line_number;
 /** Set the input stream. This does not discard the current
  * input buffer.
- * @param _in_str A readable stream.
+ * @param in_str A readable stream.
- * @see yy_switch_to_buffer
+ * @see wkt_yy_switch_to_buffer
-void yyset_in (FILE *  _in_str )
-        yyin = _in_str ;
+        wkt_yyin = in_str ;
-void yyset_out (FILE *  _out_str )
-        yyout = _out_str ;
+        wkt_yyout = out_str ;
-int yyget_debug  (void)
+int wkt_yyget_debug  (void)
-        return yy_flex_debug;
+        return wkt_yy_flex_debug;
-void yyset_debug (int  _bdebug )
+void wkt_yyset_debug (int  bdebug )
-        yy_flex_debug = _bdebug ;
+        wkt_yy_flex_debug = bdebug ;
 static int yy_init_globals (void)
         /* Initialization is the same as for the non-reentrant scanner.
-     * This function is called from yylex_destroy(), so don't allocate here.
+     * This function is called from wkt_yylex_destroy(), so don't allocate here.
-    (yy_buffer_stack) = NULL;
+    (yy_buffer_stack) = 0;
     (yy_buffer_stack_max) = 0;
-    (yy_c_buf_p) = NULL;
+    (yy_c_buf_p) = (char *) 0;
     (yy_init) = 0;
     (yy_start) = 0;
 /* Defined in main.c */
 #ifdef YY_STDINIT
-    yyin = stdin;
-    yyout = stdout;
+    wkt_yyin = stdin;
 #else
-    yyin = NULL;
-    yyout = NULL;
+    wkt_yyin = (FILE *) 0;
+    wkt_yyout = (FILE *) 0;
 #endif
     /* For future reference: Set errno on error, since we are called by
-     * yylex_init()
+     * wkt_yylex_init()
     return 0;
-/* yylex_destroy is for both reentrant and non-reentrant scanners. */
-int yylex_destroy  (void)
+/* wkt_yylex_destroy is for both reentrant and non-reentrant scanners. */
+int wkt_yylex_destroy  (void)
     /* Pop the buffer stack, destroying each element. */
 	while(YY_CURRENT_BUFFER){
-		yy_delete_buffer( YY_CURRENT_BUFFER  );
-		yypop_buffer_state();
+		wkt_yypop_buffer_state();
 	/* Destroy the stack itself. */
-	yyfree((yy_buffer_stack) );
+	wkt_yyfree((yy_buffer_stack) );
     /* Reset the globals. This is important in a non-reentrant scanner so the next time
-     * yylex() is called, initialization will occur. */
+     * wkt_yylex() is called, initialization will occur. */
     yy_init_globals( );
     return 0;
@@ -2237,19 +1999,18 @@ int yylex_destroy  (void)
 #ifndef yytext_ptr
-static void yy_flex_strncpy (char* s1, const char * s2, int n )
+static void yy_flex_strncpy (char* s1, yyconst char * s2, int n )
-	int i;
+	register int i;
 	for ( i = 0; i < n; ++i )
 		s1[i] = s2[i];
 #endif
-static int yy_flex_strlen (const char * s )
+static int yy_flex_strlen (yyconst char * s )
-	int n;
+	register int n;
 	for ( n = 0; s[n]; ++n )
@@ -2259,7 +2020,8 @@ static int yy_flex_strlen (const char * s )
 #define YYTABLES_NAME "yytables"
 void *wkt_yyalloc (yy_size_t  size )
diff --git a/liblwgeom/lwin_wkt_lex.l b/liblwgeom/lwin_wkt_lex.l
index 9ea931e..273a979 100644
--- a/liblwgeom/lwin_wkt_lex.l
+++ b/liblwgeom/lwin_wkt_lex.l
@@ -55,6 +55,13 @@ static void wkt_lexer_unknown()
 	return DOUBLE_TOK;
+([Nn][Aa][Nn])[ \,\)\t\n\r] {
 SRID=-?[0-9]+ {
 	LWDEBUG(5,"SRID");
Summary of changes:
 NEWS                        |    1 +
 liblwgeom/cunit/cu_in_wkt.c |   16 +-
 liblwgeom/lwin_wkt_lex.c    | 1280 ++++++++++++++++++-------------------------
 liblwgeom/lwin_wkt_lex.l    |    7 +
 4 files changed, 544 insertions(+), 760 deletions(-)
hooks/post-receive
