[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-85-g86df398
Wed Feb 17 23:16:33 PST 2021
the project "PostGIS".
       via  86df398fcfced629460c0f03f8fb6691da405b26 (commit)
      from  4b0e00a4e28013f9c3575532524fe2a6653f0658 (commit)
revisions in full, below.
commit 86df398fcfced629460c0f03f8fb6691da405b26
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Feb 17 23:16:23 2021 -0800
    Improve  doc Ref section for accessors
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 17e92bb..5384309 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -86,6 +86,7 @@
 		<para><xref linkend="ST_GeometryType" /></para>
 	  </refsection>
 	</refentry>
 	<refentry id="ST_Boundary">
 	  <refnamediv>
 		<refname>ST_Boundary</refname>
@@ -202,6 +203,85 @@ MULTIPOINT(-1 1 1,1 1 0.75)
 		</refsection>
 	</refentry>
+	<refentry id="ST_BoundingDiagonal">
+		  <refnamediv>
+			<refname>ST_BoundingDiagonal</refname>
+			<refpurpose>Returns the diagonal of a geometry's bounding box.</refpurpose>
+		  </refnamediv>
+		  <refsynopsisdiv>
+			<funcsynopsis>
+			  <funcprototype>
+				<funcdef>geometry <function>ST_BoundingDiagonal</function></funcdef>
+				<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+				<paramdef choice="opt"><type>boolean </type> <parameter>fits=false</parameter></paramdef>
+			  </funcprototype>
+			</funcsynopsis>
+		  </refsynopsisdiv>
+		  <refsection>
+			<title>Description</title>
+			<para>
+Returns the diagonal of the supplied geometry's bounding box as a LineString.
+The diagonal is a 2-point LineString with the minimum values of each dimension in its
+start point and the maximum values in its end point.
+If the input geometry is empty, the diagonal line is a LINESTRING EMPTY.
+			</para>
+			<para>
+The optional <varname>fits</varname> parameter specifies if the best fit is needed.
+If false, the diagonal of a somewhat larger bounding box can be accepted
+(which is faster to compute for geometries with many vertices). In either case,
+the bounding box of the returned diagonal line always covers the input
+geometry.
+			</para>
+			<para>
+The returned geometry retains the SRID and dimensionality
+(Z and M presence) of the input geometry.
+			</para>
+			<note><para>
+In degenerate cases (i.e. a single vertex in input) the returned linestring
+will be formally invalid (no interior).
+The result is still topologically valid.
+			</para></note>
+			<para>Availability: 2.2.0</para>
+			<para>&Z_support;</para>
+			<para>&M_support;</para>
+		</refsection>
+	  <refsection>
+		<title>Examples</title>
+		<programlisting>
+-- Get the minimum X in a buffer around a point
+SELECT ST_X(ST_StartPoint(ST_BoundingDiagonal(
+  ST_Buffer(ST_MakePoint(0,0),10)
+ st_x
+  -10
+		</programlisting>
+		</refsection>
+	  <refsection>
+		<title>See Also</title>
+		<para>
+<xref linkend="ST_StartPoint" />,
+<xref linkend="ST_EndPoint" />,
+<xref linkend="ST_X" />,
+<xref linkend="ST_Y" />,
+<xref linkend="ST_Z" />,
+<xref linkend="ST_M" />,
+<xref linkend="ST_Envelope" />
+		</para>
+	  </refsection>
+	</refentry>
 	<refentry id="ST_CoordDim">
 	  <refnamediv>
 		<refname>ST_CoordDim</refname>
@@ -324,26 +404,29 @@ ST_Dimension
 	  <refsection>
-			<para>This is a set-returning function (SRF). It returns a set of
-			geometry_dump rows, formed by a geometry (geom) and an array of
-			integers (path). When the input geometry is a simple type
-			(POINT,LINESTRING,POLYGON) a single record will be returned with
-			an empty path array and the input geometry as geom. When the input
-			geometry is a collection or multi it will return a record for each
-			of the collection components, and the path will express the
+			<para>A set-returning function (SRF) that extracts the components of a geometry.
+            It returns a set of
+			<varname><xref linkend="geometry_dump" /></varname> rows,
+            each containing a geometry (<parameter>geom</parameter> field)
+            and an array of integers (<parameter>path</parameter> field).
+            </para>
+            <para>For an atomic geometry type
+			(POINT,LINESTRING,POLYGON) a single record is returned with
+			an empty <parameter>path</parameter> array and the input geometry as <parameter>geom</parameter>.
+            For a collection or multi-geometry a record is returned for each
+			of the collection components, and the <parameter>path</parameter> denotes the
 			position of the component inside the collection.</para>
 			<para>ST_Dump is useful for expanding geometries. It is the
-			reverse of a GROUP BY in that it creates new rows. For example it
-			can be use to expand MULTIPOLYGONS into POLYGONS.</para>
+			inverse of a <xref linkend="ST_Collect" /> / GROUP BY, in that it creates new rows.
+            For example it can be use to expand MULTIPOLYGONS into POLYGONS.</para>
 			<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
 			<para>Availability: PostGIS 1.0.0RC1. Requires PostgreSQL 7.3 or higher.</para>
 			<note><para>Prior to 1.3.4, this function crashes if used with geometries that contain CURVES.  This is fixed in 1.3.4+</para></note>
             <para>&curve_support;</para>
             <para>&P_support;</para>
             <para>&T_support;</para>
@@ -412,20 +495,20 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
 	  </refsection>
 	  <refsection>
-		<para><xref linkend="geometry_dump" />, <xref linkend="PostGIS_Geometry_DumpFunctions" />, <xref linkend="ST_Collect" />, <xref linkend="ST_Collect" />, <xref linkend="ST_GeometryN" /></para>
+		<para><xref linkend="geometry_dump" />, <xref linkend="PostGIS_Geometry_DumpFunctions" />, <xref linkend="ST_Collect" />, <xref linkend="ST_GeometryN" /></para>
 	  </refsection>
 	</refentry>
 	<refentry id="ST_DumpPoints">
 		<refnamediv>
 			<refname>ST_DumpPoints</refname>
-			<refpurpose>Returns a set of <varname>geometry_dump</varname> rows for the points in a geometry.</refpurpose>
+			<refpurpose>Returns a set of <varname>geometry_dump</varname> rows for the coordinates in a geometry.</refpurpose>
 		</refnamediv>
 		<refsynopsisdiv>
 			<funcsynopsis>
 				<funcprototype>
-				<funcdef>geometry_dump[]<function>ST_DumpPoints</function></funcdef>
+				<funcdef>geometry_dump[] <function>ST_DumpPoints</function></funcdef>
 			</funcprototype>
 		</funcsynopsis>
@@ -433,27 +516,44 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
 		<refsection>
-				<para>This set-returning function (SRF) returns a set of <varname>geometry_dump</varname> rows formed
-				    by a geometry (<varname>geom</varname>) and an array of integers (<varname>path</varname>).</para>
-				<para>The <parameter>geom</parameter> component of <varname>geometry_dump</varname> are
-				    all the <varname>POINT</varname>s that make up the supplied geometry</para>
-				<para>The <parameter>path</parameter> component of <varname>geometry_dump</varname> (an <varname>integer[]</varname>)
-				    is an index reference enumerating the <varname>POINT</varname>s of the supplied geometry.
-					For example, if a <varname>LINESTRING</varname> is supplied, a path of <varname>{i}</varname> is
-					returned where <varname>i</varname> is the <varname>nth</varname> coordinate in the <varname>LINESTRING</varname>.
-					If a <varname>POLYGON</varname> is supplied, a path of <varname>{i,j}</varname> is returned where
-					<varname>i</varname> is the ring number (1 is outer; inner rings follow) and <varname>j</varname>
-					enumerates the <varname>POINT</varname>s (again 1-based index).
-				</para>
-				<para>Enhanced: 2.1.0 Faster speed. Reimplemented as native-C.</para>
-				<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
-				<para>Availability: 1.5.0</para>
-				<para>&curve_support;</para>
-				<para>&P_support;</para>
-				<para>&T_support;</para>
-				<para>&Z_support;</para>
+			<para>A set-returning function (SRF) that extracts the coordinates (vertices) of a geometry.
+            </para>
+            <itemizedlist>
+            <listitem>
+                <para>the <parameter>geom</parameter> field
+                    <varname>POINT</varname>s represent the coordinates of the supplied geometry.
+                </para>
+            </listitem>
+            <listitem>
+                <para>the <parameter>path</parameter> field (an <varname>integer[]</varname>)
+                    is an index enumerating the coordinate positions in the elements of the supplied geometry.
+                    The indices are 1-based.
+                    For example, for a <varname>LINESTRING</varname> the paths are <varname>{i}</varname>
+                    where <varname>i</varname> is the <varname>nth</varname>
+                    coordinate in the <varname>LINESTRING</varname>.
+                    For a <varname>POLYGON</varname> the paths are <varname>{i,j}</varname> where
+                    <varname>i</varname> is the ring number (1 is outer; inner rings follow)
+                    and <varname>j</varname> is the coordinate position in the ring.
+                </para>
+            </listitem>
+            </itemizedlist>
+            <para>
+            To obtain a single geometry containing the coordinates use <xref linkend="ST_Points" />.
+            </para>
+            <para>Enhanced: 2.1.0 Faster speed. Reimplemented as native-C.</para>
+            <para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
+            <para>Availability: 1.5.0</para>
+            <para>&curve_support;</para>
+            <para>&P_support;</para>
+            <para>&T_support;</para>
 		</refsection>
 		<refsection><title>Classic Explode a Table of LineStrings into nodes</title>
@@ -634,7 +734,8 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
 		</refsection>
 			<refsection>
-			<para><xref linkend="geometry_dump" />, <xref linkend="PostGIS_Geometry_DumpFunctions" />, <xref linkend="ST_Dump" />, <xref linkend="ST_DumpRings" /></para>
+            <xref linkend="ST_Dump" />, <xref linkend="ST_DumpRings" />, <xref linkend="ST_Points" /></para>
 		</refsection>
 	</refentry>
 	<refentry id="ST_DumpRings">
@@ -657,26 +758,31 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
 	  <refsection>
-			<varname>geometry_dump</varname> rows, defined as an <varname>integer[]</varname>
-			and a <varname>geometry</varname>, aliased "path" and "geom" respectively.
-			The "path" field holds the polygon ring index containing a single integer: 0 for the shell, >0 for holes.
-			The "geom" field contains the corresponding ring as a polygon.</para>
+        <para>A set-returning function (SRF) that extracts the rings of a polygon.
+            It returns a set of <varname><xref linkend="geometry_dump" /></varname> rows,
+        </para>
+        <para>
+		The <parameter>geom</parameter> field contains each ring as a POLYGON.</para>
+	    The <parameter>path</parameter> field is an integer array of length 1 containing the polygon ring index.
+        The exterior ring (shell) has index 0.  The interior rings (holes) have indices of 1 and higher.
+		<note><para>This only works for POLYGON geometries. It does not work for MULTIPOLYGONS</para></note>
 		<para>Availability: PostGIS 1.1.3. Requires PostgreSQL 7.3 or higher.</para>
-		<note><para>This only works for POLYGON geometries. It will not work for MULTIPOLYGONS</para></note>
 	  </refsection>
 	  <refsection>
-		<programlisting>SELECT sometable.field1, sometable.field1,
-	  (ST_DumpRings(sometable.the_geom)).geom As the_geom
-FROM sometableOfpolys;
-SELECT ST_AsEWKT(geom) As the_geom, path
+        <para>General form of query.</para>
+		<programlisting>SELECT polyTable.field1, polyTable.field1,
+	  (ST_DumpRings(polyTable.the_geom)).geom As the_geom
+FROM polyTable;
+</programlisting>
+        <para>A polygon with a single hole.</para>
+<programlisting>SELECT path, ST_AsEWKT(geom) As the_geom
 	FROM ST_DumpRings(
 		ST_GeomFromEWKT('POLYGON((-8149064 5133092 1,-8149064 5132986 1,-8148996 5132839 1,-8148972 5132767 1,-8148958 5132508 1,-8148941 5132466 1,-8148924 5132394 1,
 		-8148903 5132210 1,-8148930 5131967 1,-8148992 5131978 1,-8149237 5132093 1,-8149404 5132211 1,-8149647 5132310 1,-8149757 5132394 1,
@@ -882,85 +988,6 @@ POLYGON((20 75,20 150,125 150,125 75,20 75))</programlisting>
 	  </refsection>
 	</refentry>
-	<refentry id="ST_BoundingDiagonal">
-		  <refnamediv>
-			<refname>ST_BoundingDiagonal</refname>
-			<refpurpose>Returns the diagonal of a geometry's bounding box.</refpurpose>
-		  </refnamediv>
-		  <refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>geometry <function>ST_BoundingDiagonal</function></funcdef>
-				<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
-				<paramdef choice="opt"><type>boolean </type> <parameter>fits=false</parameter></paramdef>
-			  </funcprototype>
-			</funcsynopsis>
-		  </refsynopsisdiv>
-		  <refsection>
-			<title>Description</title>
-			<para>
-Returns the diagonal of the supplied geometry's bounding box as a LineString.
-If the input geometry is empty, the diagonal line is also empty, otherwise
-it is a 2-point LineString with the minimum values of each dimension in its
-start point and the maximum values in its end point.
-			</para>
-			<para>
-The returned linestring geometry always retains SRID and dimensionality
-(Z and M presence) of the input geometry.
-			</para>
-			<para>
-The <varname>fits</varname> parameter specifies if the best fit is needed.
-If false, the diagonal of a somewhat larger bounding box can be accepted
-(is faster to obtain for geometries with a lot of vertices). In any case
-the bounding box of the returned diagonal line always covers the input
-geometry.
-			</para>
-			<note><para>
-In degenerate cases (a single vertex in input) the returned linestring
-will be topologically invalid (no interior). This does not make the
-return semantically invalid.
-			</para></note>
-			<para>Availability: 2.2.0</para>
-			<para>&M_support;</para>
-		</refsection>
-	  <refsection>
-		<title>Examples</title>
-		<programlisting>
--- Get the minimum X in a buffer around a point
-SELECT ST_X(ST_StartPoint(ST_BoundingDiagonal(
-  ST_Buffer(ST_MakePoint(0,0),10)
- st_x
-  -10
-		</programlisting>
-		</refsection>
-	  <refsection>
-		<title>See Also</title>
-		<para>
-<xref linkend="ST_StartPoint" />,
-<xref linkend="ST_EndPoint" />,
-<xref linkend="ST_X" />,
-<xref linkend="ST_Y" />,
-<xref linkend="ST_Z" />,
-<xref linkend="ST_M" />,
-<xref linkend="geometry_overlaps_nd" />
-		</para>
-	  </refsection>
-	</refentry>
 	<refentry id="ST_ExteriorRing">
 	  <refnamediv>
 		<refname>ST_ExteriorRing</refname>
@@ -981,10 +1008,13 @@ SELECT ST_X(ST_StartPoint(ST_BoundingDiagonal(
 	  <refsection>
-		<para>Returns a line string representing the exterior ring of the <varname>POLYGON</varname> geometry. Return
-				NULL if the geometry is not a polygon.</para>
+		<para>Returns a LINESTRING representing the exterior ring (shell) of a POLYGON.
+        Returns	NULL if the geometry is not a polygon.</para>
-		<note><para>Only works with POLYGON geometry types</para></note>
+		<note>
+		  <para>This function does not support MULTIPOLYGONs.
+          For MULTIPOLYGONs use in conjunction with <xref linkend="ST_GeometryN" /> or <xref linkend="ST_Dump" /> </para>
+        </note>
 		<para>&sfs_compliant; 2.1.5.1</para>
 		<para>&sqlmm_compliant; SQL-MM 3: 8.2.3, 8.3.3</para>
@@ -1034,7 +1064,7 @@ LINESTRING(0 0 1,1 1 1,1 2 1,1 1 1,0 0 1)
 	  <refnamediv>
 		<refname>ST_GeometryN</refname>
-		<refpurpose>Return the Nth geometry element of a geometry collection.</refpurpose>
+		<refpurpose>Return an element of a geometry collection.</refpurpose>
 	  </refnamediv>
 	  <refsynopsisdiv>
@@ -1050,9 +1080,9 @@ LINESTRING(0 0 1,1 1 1,1 2 1,1 1 1,0 0 1)
 	  <refsection>
-		<para>Return the 1-based Nth geometry if the geometry is a
-			GEOMETRYCOLLECTION, (MULTI)POINT, (MULTI)LINESTRING, MULTICURVE or (MULTI)POLYGON, POLYHEDRALSURFACE
-			Otherwise, return NULL</para>
+		<para>Return the 1-based Nth element geometry of an input geometry which is a
+			GEOMETRYCOLLECTION, MULTIPOINT, MULTILINESTRING, MULTICURVE, MULTI)POLYGON, or POLYHEDRALSURFACE.
+			Otherwise, returns NULL.</para>
 		<note>
 		  <para>Index is 1-based as for OGC specs since version 0.8.0.
@@ -1060,7 +1090,7 @@ LINESTRING(0 0 1,1 1 1,1 2 1,1 1 1,0 0 1)
 		</note>
 		<note>
-		  <para>If you want to extract all geometries, of a geometry, <xref linkend="ST_Dump" /> is more efficient, and also works for singular geoms.</para>
+		  <para>To extract all elements of a geometry, <xref linkend="ST_Dump" /> is more efficient and works for atomoic geometrie.</para>
 		</note>
 		<para>Changed: 2.0.0 Prior versions would return NULL for singular geometries.  This was changed to return the geometry for ST_GeometryN(..,1) case.</para>
@@ -1289,13 +1319,15 @@ SELECT ST_AsEWKT(ST_GeometryN(geom,2)) as wkt
 	  <refsection>
-		<para>Returns the Nth interior linestring ring of the polygon geometry.
-			Returns NULL if the geometry is not a polygon or the given N is out
-			of range.  The index starts at 1.</para>
+		<para>Returns the Nth interior ring (hole) of a POLYGON geometry as a LINESTRING.
+			The index starts at 1.
+            Returns NULL if the geometry is not a polygon or the index is out
+			of range.  </para>
 		<!-- optionally mention that this function uses indexes if appropriate -->
 		<note>
-		  <para>This function does not support for MULTIPOLYGONs.  Use in conjunction with <xref linkend="ST_Dump" /> for MULTIPOLYGONS</para>
 		</note>
 		<para>&sfs_compliant;</para>
@@ -1313,7 +1345,7 @@ SELECT ST_AsText(ST_InteriorRingN(the_geom, 1)) As the_geom
 FROM (SELECT ST_BuildArea(
 		ST_Collect(ST_Buffer(ST_Point(1,2), 20,3),
 			ST_Buffer(ST_Point(1, 2), 10,3))) As the_geom
-		)  as foo
+		)  as foo;
 		</programlisting>
 	  </refsection>
@@ -1322,155 +1354,16 @@ FROM (SELECT ST_BuildArea(
 		<para>
-<xref linkend="ST_ExteriorRing" />
-<xref linkend="ST_BuildArea" />,
-<xref linkend="ST_Collect" />,
-<xref linkend="ST_Dump" />,
-<xref linkend="ST_NumInteriorRing" />,
-<xref linkend="ST_NumInteriorRings" />
+            <xref linkend="ST_ExteriorRing" />,
+            <xref linkend="ST_BuildArea" />,
+            <xref linkend="ST_Collect" />,
+            <xref linkend="ST_NumInteriorRing" />,
+            <xref linkend="ST_NumInteriorRings" />
 		</para>
 	  </refsection>
 	</refentry>
-	<refentry id="ST_IsPolygonCCW">
-		<refnamediv>
-			<refname>
-				ST_IsPolygonCCW
-			</refname>
-			<refpurpose>Tests if Polygons have exterior rings oriented counter-clockwise and interior rings oriented clockwise.
-			</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-			<funcsynopsis>
-				<funcprototype>
-					<funcdef>
-						boolean
-						<function>ST_IsPolygonCCW</function>
-					</funcdef>
-					<paramdef>
-						<type>geometry</type>
-						<parameter>geom</parameter>
-					</paramdef>
-				</funcprototype>
-			</funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<para>
-				Returns true if all polygonal components of the input geometry use a counter-clockwise
-				orientation for their exterior ring, and a clockwise direction
-				for all interior rings.
-			</para>
-			<para>
-				Returns true if the geometry has no polygonal components.
-			</para>
-			<note>
-				<para>
-					Closed linestrings are not considered polygonal components,
-					so you would still get a true return by passing
-          a single closed linestring no matter its orientation.
-				</para>
-			</note>
-			<note>
-				<para>
-					If a polygonal geometry does not use reversed orientation
-					for interior rings (i.e., if one or more interior rings
-					are oriented in the same direction as an exterior ring)
-					then both ST_IsPolygonCW and ST_IsPolygonCCW will return false.
-				</para>
-			</note>
-			<para>Availability: 2.4.0</para>
-		</refsection>
-		<refsection>
-			<para>
-				<xref linkend="ST_ForcePolygonCW" />,
-				<xref linkend="ST_ForcePolygonCCW" />,
-				<xref linkend="ST_IsPolygonCW" />
-			</para>
-		</refsection>
-	</refentry>
-	<refentry id="ST_IsPolygonCW">
-		<refnamediv>
-			<refname>
-				ST_IsPolygonCW
-			</refname>
-			<refpurpose>Tests if Polygons have exterior rings oriented clockwise and interior rings oriented counter-clockwise.
-			</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-			<funcsynopsis>
-				<funcprototype>
-					<funcdef>
-						boolean
-						<function>ST_IsPolygonCW</function>
-					</funcdef>
-					<paramdef>
-					</paramdef>
-				</funcprototype>
-			</funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<para>
-				Returns true if all polygonal components of the input geometry use a clockwise
-				orientation for their exterior ring, and a counter-clockwise direction
-			</para>
-			<para>
-			</para>
-			<note>
-				<para>
-				</para>
-			</note>
-			<note>
-				<para>
-				</para>
-			</note>
-		</refsection>
-		<refsection>
-			<para>
-			</para>
-		</refsection>
-	</refentry>
 	<refentry id="ST_IsClosed">
 	  <refnamediv>
 		<refname>ST_IsClosed</refname>
@@ -1738,6 +1631,145 @@ SELECT ST_IsEmpty(ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))'));
 	</refentry>
+	<refentry id="ST_IsPolygonCCW">
+		<refnamediv>
+			<refname>
+				ST_IsPolygonCCW
+			</refname>
+			<refpurpose>Tests if Polygons have exterior rings oriented counter-clockwise and interior rings oriented clockwise.
+			</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+			<funcsynopsis>
+				<funcprototype>
+					<funcdef>
+						boolean
+						<function>ST_IsPolygonCCW</function>
+					</funcdef>
+					<paramdef>
+						<type>geometry</type>
+						<parameter>geom</parameter>
+					</paramdef>
+				</funcprototype>
+			</funcsynopsis>
+		</refsynopsisdiv>
+		<refsection>
+			<para>
+				Returns true if all polygonal components of the input geometry use a counter-clockwise
+				orientation for their exterior ring, and a clockwise direction
+				for all interior rings.
+			</para>
+			<para>
+				Returns true if the geometry has no polygonal components.
+			</para>
+			<note>
+				<para>
+					Closed linestrings are not considered polygonal components,
+					so you would still get a true return by passing
+          a single closed linestring no matter its orientation.
+				</para>
+			</note>
+			<note>
+				<para>
+					If a polygonal geometry does not use reversed orientation
+					for interior rings (i.e., if one or more interior rings
+					are oriented in the same direction as an exterior ring)
+					then both ST_IsPolygonCW and ST_IsPolygonCCW will return false.
+				</para>
+			</note>
+			<para>Availability: 2.4.0</para>
+		</refsection>
+		<refsection>
+			<para>
+				<xref linkend="ST_ForcePolygonCW" />,
+				<xref linkend="ST_ForcePolygonCCW" />,
+				<xref linkend="ST_IsPolygonCW" />
+			</para>
+		</refsection>
+	</refentry>
+	<refentry id="ST_IsPolygonCW">
+		<refnamediv>
+			<refname>
+				ST_IsPolygonCW
+			</refname>
+			<refpurpose>Tests if Polygons have exterior rings oriented clockwise and interior rings oriented counter-clockwise.
+			</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+			<funcsynopsis>
+				<funcprototype>
+					<funcdef>
+						boolean
+						<function>ST_IsPolygonCW</function>
+					</funcdef>
+					<paramdef>
+					</paramdef>
+				</funcprototype>
+			</funcsynopsis>
+		</refsynopsisdiv>
+		<refsection>
+			<para>
+				Returns true if all polygonal components of the input geometry use a clockwise
+				orientation for their exterior ring, and a counter-clockwise direction
+			</para>
+			<para>
+			</para>
+			<note>
+				<para>
+				</para>
+			</note>
+			<note>
+				<para>
+				</para>
+			</note>
+		</refsection>
+		<refsection>
+			<para>
+			</para>
+		</refsection>
+	</refentry>
   <refentry id="ST_IsRing">
 	<refnamediv>
 	  <refname>ST_IsRing</refname>
@@ -2214,7 +2246,7 @@ GROUP BY gid, field1,field2;
 	  <refsection>
-		<para><xref linkend="ST_NumInteriorRing" /></para>
+		<para><xref linkend="ST_NumInteriorRing" />, <xref linkend="ST_InteriorRingN" /></para>
 	  </refsection>
 	</refentry>
@@ -2236,7 +2268,7 @@ GROUP BY gid, field1,field2;
 	  <refsection>
-		<para><xref linkend="ST_NumInteriorRings" /></para>
+		<para><xref linkend="ST_NumInteriorRings" />, <xref linkend="ST_InteriorRingN" /></para>
 	  </refsection>
 	</refentry>
@@ -2495,7 +2527,7 @@ FROM ST_GeomFromText('LINESTRING(0 0 0, 1 1 1, 2 2 2)') AS g
 	<refentry id="ST_Points">
 		<refnamediv>
 			<refname>ST_Points</refname>
-			<refpurpose>Returns a MultiPoint containing all the coordinates of a geometry.
+			<refpurpose>Returns a MultiPoint containing the coordinates of a geometry.
 			</refpurpose>
 		</refnamediv>
@@ -2515,13 +2547,18 @@ FROM ST_GeomFromText('LINESTRING(0 0 0, 1 1 1, 2 2 2)') AS g
 			<para>
-				Returns a MultiPoint containing all of the coordinates of a
-				geometry.  Does not remove points that are duplicated in
-				the input geometry, including start and end points of ring geometries.
+				Returns a MultiPoint containing all the coordinates of a
+				geometry.  Does not remove points that are repeated in
+				the geometry, including the start and end points of ring geometries.
 				(If this behavior is undesired, duplicates may be removed using
 				<xref linkend="ST_RemoveRepeatedPoints" />).
 			</para>
+            <para>
+            To obtain information about the position of each coordinate in the parent geometry
+            use <xref linkend="ST_DumpPoints" />.
+            </para>
 			<para>
 				M and Z coordinates will be preserved if present.
 			</para>
@@ -2545,7 +2582,7 @@ MULTIPOINT Z (30 10 4,10 30 5,40 40 6, 30 10 4)
 		<refsection>
-			<para><xref linkend="ST_RemoveRepeatedPoints" /></para>
+			<para><xref linkend="ST_RemoveRepeatedPoints" />, <xref linkend="ST_DumpPoints" /></para>
 		</refsection>
 	</refentry>
diff --git a/doc/reference_type.xml b/doc/reference_type.xml
index c91be1c..c23b8d7 100644
--- a/doc/reference_type.xml
+++ b/doc/reference_type.xml
@@ -171,12 +171,13 @@
 		containing the fields:</para>
 		<itemizedlist>
 		<listitem>
-			<para><varname>geom</varname> - a references to a component geometry</para>
+			<para><varname>geom</varname> - a geometry representing a component of the dumped geometry.
+                The geometry type depends on the originating function.</para>
 			</listitem>
 		<listitem>
-			<para><varname>path[]</varname> - a 1-dimensional integer array
+			<para><varname>path[]</varname> - an integer array
 			that defines the navigation path within the dumped geometry to the <varname>geom</varname> component.
-			The path array starts at 1 (e.g. <varname>path[1]</varname> is the first element.)</para>
+			The path array is 1-based (i.e. <varname>path[1]</varname> is the first element.)</para>
 			</listitem>
 		</itemizedlist>
 		<para>
Summary of changes:
 doc/reference_accessor.xml | 623 ++++++++++++++++++++++++---------------------
 doc/reference_type.xml     |   7 +-
 2 files changed, 334 insertions(+), 296 deletions(-)
hooks/post-receive
