[postgis-tickets] [PostGIS] #4856: ST_Intersection error
PostGIS trac at osgeo.org
Thu Feb 18 09:38:28 PST 2021
 Reporter:  ezimanyi  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 2.5.6
Component:  postgis   |    Version:  2.5.x
 Keywords:            |
 I obtained the following error when I apply twice the ST_Intersection
 function
 select st_astext(st_intersection(geometry 'Linestring(1 1,3 3.5,3 3)',
 geometry 'Polygon((0 0,0 3,3 3,3 0,0 0))'));
 -- GEOMETRYCOLLECTION(POINT(3 3),LINESTRING(1 1,2.6 3))
 geometry 'GEOMETRYCOLLECTION(POINT(3 3),LINESTRING(1 1,2.6 3))'));
 -- MULTIPOINT(1 1,3 3)
 select postgis_full_version();
 POSTGIS="3.0.3 6660953" [EXTENSION] PGSQL="130" GEOS="3.9.1dev-
 CAPI-1.14.1" PROJ="7.0.0" LIBXML="2.9.4" LIBJSON="0.12.1"
 The result above `MULTIPOINT(1 1,3 3)` is an error. I have tested also
 with 2.5.5 and GEOS 3.8 and the result is the same.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4856>
