[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-18-g9b78c9c
Thu Feb 18 10:16:31 PST 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  9b78c9c4209126e371751da17277813ebda83f09 (commit)
       via  4845b918c3d36d591cd55dd583cbcd28c65e52b1 (commit)
       via  4ba2883a45efee98b0ae9aec3c8868856a478ac1 (commit)
      from  517e07fb99e7a2b2c1849256f8fa950ab3295b02 (commit)
revisions in full, below.
commit 9b78c9c4209126e371751da17277813ebda83f09
Merge: 4845b91 517e07f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Feb 18 10:16:24 2021 -0800
    Merge branch 'stable-3.1' of https://git.osgeo.org/gitea/postgis/postgis into stable-3.1
diff --cc NEWS
index e303908,799458f..67a4bd4
--- a/NEWS
+++ b/NEWS
@@@ -9,7 -9,7 +9,8 @@@ PostGIS 3.1.
    - #4842, Only do axis flips on CRS that have a "Lat" as the first column (Paul Ramsey)
    - Support recent Proj versions that have removed pj_get_release (Paul Ramsey)
    - #4835, Adjust tolerance for geodetic calculations (Paul Ramsey)
 +  - #4840, Improper conversion of negative geographic azimuth to positive (Paul Ramsey)
+   - #4853, DBSCAN cluster not formed when recordset length equal to minPoints (Dan Baston)
  PostGIS 3.1.1
diff --cc regress/core/tickets.sql
index e1b5686,a9b357b..14bb61b
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@@ -1319,24 -1319,5 +1319,26 @@@ SELECT '#4796', st_astext(st_snaptogrid
  SELECT '#4812', st_srid('SRID=999999;POINT(1 1)'::geometry);
 +SELECT
 +'#4840',
 +round(degrees(ST_azimuth(C,N)))  AS az_n,
 +round(degrees(ST_azimuth(C,NE))) AS az_ne,
 +round(degrees(ST_azimuth(C,E)))  AS az_e,
 +round(degrees(ST_azimuth(C,SE))) AS az_se,
 +round(degrees(ST_azimuth(C,S)))  AS az_s,
 +round(degrees(ST_azimuth(C,SW))) AS az_sw,
 +round(degrees(ST_azimuth(C,W)))  AS az_w,
 +round(degrees(ST_azimuth(C,NW))) AS az_nw
 +FROM (SELECT
 +'POINT(5 55)'::geography AS C,
 +'POINT(5 56)'::geography AS N,
 +'POINT(6 56)'::geography AS NE,
 +'POINT(6 55)'::geography AS E,
 +'POINT(6 54)'::geography AS SE,
 +'POINT(5 54)'::geography AS S,
 +'POINT(4 54)'::geography AS SW,
 +'POINT(4 55)'::geography AS W,
 +'POINT(4 56)'::geography AS NW ) points;
+ SELECT '#4853', ST_ClusterDBSCAN(geom,  eps := 0.000906495804256269, minpoints := 4) OVER() AS cid FROM (VALUES ('0101000020E6100000E4141DC9E5934B40D235936FB6193940'::geometry), ('0101000020E6100000C746205ED7934B40191C25AFCE193940'::geometry), ('0101000020E6100000C780ECF5EE934B40B6BE4868CB193940'::geometry), ('0101000020E6100000ABB2EF8AE0934B404451A04FE4193940'::geometry)) AS t(geom);
diff --cc regress/core/tickets_expected
index 7acf4e9,f35829f..08b46aa
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@@ -440,4 -440,7 +440,8 @@@ ERROR:  LWGEOM_addpoint: Invalid offse
  #4727|0
  #4796|POLYGON((178632 397744,178738 397769,178745 397741,178749 397742,178752 397727,178748 397726,178759 397684,178699 397669,178694 397691,178646 397680,178632 397744))
  #4812|999999
 +#4840|0|29|90|149|180|211|270|331
+ #4853|0
+ #4853|0
+ #4853|0
+ #4853|0
commit 4845b918c3d36d591cd55dd583cbcd28c65e52b1
Date:   Thu Feb 18 10:15:15 2021 -0800
    Add NEWS entry for #4840
diff --git a/NEWS b/NEWS
index 44d0283..e303908 100644
--- a/NEWS
+++ b/NEWS
@@ -8,7 +8,8 @@ PostGIS 3.1.2
   - #4817, handle more complex compound coordinate dystems (Paul Ramsey)
-  - $4835, Adjust tolerance for geodetic calculations (Paul Ramsey)
+  - #4835, Adjust tolerance for geodetic calculations (Paul Ramsey)
 PostGIS 3.1.1
commit 4ba2883a45efee98b0ae9aec3c8868856a478ac1
Date:   Thu Feb 18 09:46:52 2021 -0800
    Mistake in converting negative azimuth values to positive
    results in incorrect azimuths in geography.
    Closes #4840
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index cac4310..f847bb4 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -2177,7 +2177,8 @@ double lwgeom_azumith_spheroid(const LWPOINT *r, const LWPOINT *s, const SPHEROI
 	/* Do the direction calculation */
 	az = spheroid_direction(&g1, &g2, spheroid);
 	/* Ensure result is positive */
-	return az > 0 ? az : M_PI - az;
+	return az < -0 ? 2*M_PI + az : az;
+	// return az;
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index da3ea27..e1b5686 100644
@@ -1318,3 +1318,25 @@ SELECT '#4727', _ST_DistanceTree('SRID=4326;POLYGON((-179.9 -85.05112877980659,
 SELECT '#4796', st_astext(st_snaptogrid(st_normalize(st_simplifypreservetopology('MULTISURFACE(((178632.044 397744.007,178631.118 397743.786,178646.399 397679.574,178693.864 397690.889,178698.958 397669.487,178700.206 397669.784,178758.532 397683.689,178748.351 397726.468,178752.199 397727.384,178748.782 397741.904,178744.897 397740.98,178738.157 397769.303,178632.044 397744.007)))'::geometry,1)),1));
+SELECT
+'#4840',
+FROM (SELECT
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 181f22f..7acf4e9 100644
@@ -440,3 +440,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4727|0
 #4812|999999
Summary of changes:
 NEWS                          |  1 +
 liblwgeom/lwgeodetic.c        |  3 ++-
 regress/core/tickets.sql      | 21 +++++++++++++++++++++
 regress/core/tickets_expected |  1 +
 4 files changed, 25 insertions(+), 1 deletion(-)
hooks/post-receive
