[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-96-gd17abd3
Thu Feb 18 15:28:58 PST 2021
the project "PostGIS".
       via  d17abd3bc43e3ba9521d66d6ea3676c92062734a (commit)
      from  b108f45d25abf4360da449bd9f876c421eab9ed1 (commit)
revisions in full, below.
commit d17abd3bc43e3ba9521d66d6ea3676c92062734a
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Feb 18 15:28:43 2021 -0800
    Change docs to use ST_Point where possible
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 1ad25f4..5b06a58 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -261,7 +261,7 @@ The result is still topologically valid.
 		<programlisting>
 -- Get the minimum X in a buffer around a point
 SELECT ST_X(ST_StartPoint(ST_BoundingDiagonal(
-  ST_Buffer(ST_MakePoint(0,0),10)
+  ST_Buffer(ST_Point(0,0),10)
  st_x
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index 6b01777..15055ce 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -449,7 +449,7 @@ FROM (SELECT ST_MakePoint(x,y,z) As the_geom
 --Get the extent of various elevated circular strings
 SELECT ST_3DExtent(foo.the_geom) As b3extent
-FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_MakePoint(x,y),1))),0,0,z) As the_geom
+FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1))),0,0,z) As the_geom
 	FROM generate_series(1,3) As x
 		CROSS JOIN generate_series(1,2) As y
 		CROSS JOIN generate_series(0,2) As Z) As foo;
@@ -507,7 +507,7 @@ WHERE the_geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-989502.1875, 528439.
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="ST_MakePoint" />, <xref linkend="ST_Point" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" /></para>
+		<para><xref linkend="ST_Point" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" /></para>
 	  </refsection>
 	</refentry>
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 4b3ff05..8d80ee0 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -278,7 +278,7 @@ POLYGON((10 10, 10 11, 11 11, 11 10, 10 10))
 <para>Create a line composed of two points.</para>
 <programlisting>
-SELECT ST_AsText( ST_MakeLine(ST_MakePoint(1,2), ST_MakePoint(3,4)) );
+SELECT ST_AsText( ST_MakeLine(ST_Point(1,2), ST_Point(3,4)) );
 	  st_astext
@@ -346,7 +346,13 @@ SELECT gps.track_id, ST_MakeLine(gps.geom) As geom
 		<refsection>
-			<para><xref linkend="ST_RemoveRepeatedPoints" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_AsText" />, <xref linkend="ST_GeomFromText" />, <xref linkend="ST_MakePoint" /></para>
+			<para><xref linkend="ST_RemoveRepeatedPoints" />,
+            <xref linkend="ST_AsEWKT" />,
+            <xref linkend="ST_AsText" />,
+            <xref linkend="ST_GeomFromText" />,
+            <xref linkend="ST_MakePoint" />,
+            <xref linkend="ST_Point" />
+            </para>
 		</refsection>
 	</refentry>
@@ -573,10 +579,10 @@ POLYGONM((75.15 29.53 1,77 29 1,77.6 29.5 2,75.15 29.53 2))
 		   <programlisting>
 SELECT ST_MakePolygon( ST_ExteriorRing( ST_Buffer(ring.line,10)),
 	ARRAY[  ST_Translate(ring.line, 1, 1),
-		ST_ExteriorRing(ST_Buffer(ST_MakePoint(20,20),1)) ]
+		ST_ExteriorRing(ST_Buffer(ST_Point(20,20),1)) ]
 FROM (SELECT ST_ExteriorRing(
-	ST_Buffer(ST_MakePoint(10,10),10,10)) AS line ) AS ring;
+	ST_Buffer(ST_Point(10,10),10,10)) AS line ) AS ring;
 </programlisting>
     <para>Create a set of province boundaries with holes
     representing lakes.  The input is a table of
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 671235b..77c0fea 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1542,8 +1542,8 @@ UPDATE sometable
 		<programlisting>
 SELECT ST_AsText(the_geom) as line, ST_AsText(ST_Reverse(the_geom)) As reverseline
 FROM
-(SELECT ST_MakeLine(ST_MakePoint(1,2),
-		ST_MakePoint(1,10)) As the_geom) as foo;
+(SELECT ST_MakeLine(ST_Point(1,2),
+		ST_Point(1,10)) As the_geom) as foo;
 --result
 		line         |     reverseline
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 5fff62a..54ba9bb 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -277,7 +277,7 @@ SELECT ST_AsText(house_loc) As as_text_house_loc,
 			* ST_LineLocatePoint(street_line, house_loc) As integer) As street_num
 FROM
 (SELECT ST_GeomFromText('LINESTRING(1 2, 3 4)') As street_line,
-	ST_MakePoint(x*1.01,y*1.03) As house_loc, 10 As startstreet_num,
+	ST_Point(x*1.01,y*1.03) As house_loc, 10 As startstreet_num,
 		20 As endstreet_num
 FROM generate_series(1,3) x CROSS JOIN generate_series(2,4) As y)
 As foo
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 416e259..7f93c67 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -244,7 +244,7 @@ SELECT degrees(ST_Azimuth(ST_Point(25, 45), ST_Point(75, 100))) AS degA_B,
 		FROM  generate_series(1,2,2) AS s
 	 , points AS (
-		SELECT s, rad1,rad2, ST_MakePoint(cos1+s,sin1+s) as p1, ST_MakePoint(s,s) AS p2, ST_MakePoint(cos2+s,sin2+s) as p3
+		SELECT s, rad1,rad2, ST_Point(cos1+s,sin1+s) as p1, ST_Point(s,s) AS p2, ST_Point(cos2+s,sin2+s) as p3
 		FROM rand
 			,cos(rad1) cos1, sin(rad1) sin1
 			,cos(rad2) cos2, sin(rad2) sin2
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index c40b075..dd75bb5 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1572,13 +1572,13 @@ x3dfrag
 	  <refsection>
 		<title>Examples</title>
-		<programlisting><![CDATA[SELECT ST_GeoHash(ST_SetSRID(ST_MakePoint(-126,48),4326));
+		<programlisting><![CDATA[SELECT ST_GeoHash(ST_SetSRID(ST_Point(-126,48),4326));
 	 st_geohash
  c0w3hf1s70w3hf1s70w3
-SELECT ST_GeoHash(ST_SetSRID(ST_MakePoint(-126,48),4326),5);
+SELECT ST_GeoHash(ST_SetSRID(ST_Point(-126,48),4326),5);
  st_geohash
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 67c57d9..928b7df 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -513,7 +513,7 @@ When a (multi)polygon is passed as as the blade, its linear component
 -- this is similar to the example we demonstrated in ST_BuildArea
 SELECT ST_Split(circle, line)
 FROM (SELECT
-    ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(190, 190)) As line,
+    ST_MakeLine(ST_Point(10, 10),ST_Point(190, 190)) As line,
     ST_Buffer(ST_GeomFromText('POINT(100 90)'), 50) As circle) As foo;
 -- result --
@@ -522,7 +522,7 @@ FROM (SELECT
 -- To convert to individual polygons, you can use ST_Dump or ST_GeometryN
 SELECT ST_AsText((ST_Dump(ST_Split(circle, line))).geom) As wkt
 FROM (SELECT
 -- result --
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 2284c95..f1260a3 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -362,7 +362,7 @@ promisingcircle_pcount | lamecircle_pcount
 to Mass state plane meter and then buffer to get measurements in meters;
 SELECT ST_AsText(ST_Buffer(
 ST_Transform(
-ST_SetSRID(ST_MakePoint(-71.063526, 42.35785),4269), 26986)
+ST_SetSRID(ST_Point(-71.063526, 42.35785),4269), 26986)
 ,100,2)) As octagon;
 POLYGON((236057.59057465 900908.759918696,236028.301252769 900838.049240578,235
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index ef1633c..f4e5557 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -419,7 +419,7 @@ around ST_StraightSkeleton (slower case).
             <programlisting>
 SELECT ST_MinkowskiSum(line, circle))
 FROM (SELECT
-    ST_MakeLine(ST_MakePoint(10, 10),ST_MakePoint(100, 100)) As line,
+    ST_MakeLine(ST_Point(10, 10),ST_Point(100, 100)) As line,
     ST_Buffer(ST_GeomFromText('POINT(50 50)'), 30) As circle) As foo;
 -- wkt --
@@ -511,7 +511,7 @@ Output is a TIN.
 			<informaltable>
 				  <tgroup cols="2">
 					<tbody>
-					  <row>
+					  <row>
 						  <entry><para><informalfigure>
 							<mediaobject>
 							  <imageobject>
@@ -545,7 +545,7 @@ select ST_DelaunayTriangles(
 </programlisting>
-						  </para></entry>
+						  </para></entry>
 			 </row>
 		</tbody>
 	</tgroup>
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index dc9d960..9299250 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -158,12 +158,12 @@ The optional <varname>flags</varname> parameter is a bitfield. It can have the f
 SELECT gid, reason(ST_IsValidDetail(the_geom)), ST_AsText(location(ST_IsValidDetail(the_geom))) as location
 FROM
 (SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), array_agg(f.line)) As the_geom, gid
-FROM (SELECT ST_Buffer(ST_MakePoint(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000 As gid
+FROM (SELECT ST_Buffer(ST_Point(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000 As gid
 	FROM generate_series(-4,6) x1
 	CROSS JOIN generate_series(2,5) y1
 	CROSS JOIN generate_series(1,8) z1
 	WHERE x1 > y1*0.5 AND z1 < x1*y1) As e
-	INNER JOIN (SELECT ST_Translate(ST_ExteriorRing(ST_Buffer(ST_MakePoint(x1*10,y1), z1)),y1*1, z1*2) As line
+	INNER JOIN (SELECT ST_Translate(ST_ExteriorRing(ST_Buffer(ST_Point(x1*10,y1), z1)),y1*1, z1*2) As line
 	FROM generate_series(-3,6) x1
 	CROSS JOIN generate_series(1,10) z1
@@ -253,12 +253,12 @@ Self-intersection[150 150]
 SELECT gid, ST_IsValidReason(the_geom) as validity_info
 FROM
Summary of changes:
 doc/reference_accessor.xml    |  2 +-
 doc/reference_bbox.xml        |  4 ++--
 doc/reference_constructor.xml | 14 ++++++++++----
 doc/reference_editor.xml      |  4 ++--
 doc/reference_lrs.xml         |  2 +-
 doc/reference_measure.xml     |  2 +-
 doc/reference_output.xml      |  4 ++--
 doc/reference_overlay.xml     |  4 ++--
 doc/reference_processing.xml  |  2 +-
 doc/reference_sfcgal.xml      |  6 +++---
 doc/reference_validation.xml  |  8 ++++----
 11 files changed, 29 insertions(+), 23 deletions(-)
hooks/post-receive
